Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
HElp Dishes not coming clean
Dishwasher not cleaning dishes. Casade cleaner not disolving.???
Water not hot enough or not enough water pressure?? Don't know who to call Kitchenaid or plumber. New dishwasher.
  • Anonymous Dec 30, 2007
    dishes have dirt and soap stuck on them
  • heremego May 22, 2008
    I don't really have a film. I have dishwashing powder that is still in gradular form. Can anyone help me??? Is is water pressure, which I have a problem with since a slab leak repair or is it not enough hot water.
    Help!!!!
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
Www.dishwasherfilter.com has a great new product out that filters the water going into your dishwasher. it reduces minerals that cause that white build up or residue. it goes under the sink and doesnt take up much room at all. my dishes looked terrible until i put this filter in. it is very affordable and works great.
Posted on Apr 03, 2008
  • Mike May 21, 2008
    the is a new product out called the dishwasher filtration system. it actually filters the water going into your dishwasher and leaves your dishes spot free. after the first load i was amazed that the white film was gone and my dishes were sparkling. you can get it at www.dishwasherfilter.com.
  • 83 Answers
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Posted on Dec 07, 2007
Dishes aren't cleaning. Filling with water, rinsing then draining, refilling with water -- hot, soap released. When dishes come out, barely clean. Used to work like a charm... Thoughts?
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Feb 16, 2011 | Miele 23 in. Novotronic G841 Built-In...
When wash dishes, there is gritty like food on all the dishes and we use liquid for cleaning dishes. I rinse all dishes before I place in unit.....what is the problem?
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.The water temperature should be minimum of 140 degree Fahrenheit.
Also check the filter in your dishwasher for any debris accumulation.
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes.
Dec 09, 2010 | Maytag Dishwashers
It' no longer cleaning my dishes
hello,
If your dishes are coming out of the dishwasher covered by a removable dirty film, your water may not be hot enough, or you could be using an inferior brand of automatic dishwashing detergent. If you have tested your hot water and find it is between 140 degrees and 160 degrees Fahrenheit, consider how long it takes for the hot water to reach the dirty dishes in the dishwasher. If the hot water has to travel a long distance to reach the dishwasher, chances are the water filling the dishwasher starts out cold. To alleviate this problem, run the hot water nearest to your dishwasher until the water coming out is hot. This will guarantee the water filling the dishwasher is as hot as it should be to properly clean dirty dishes.
To remove this type of film from dirty dishes, after running the dishes through a basic rinse cycle, set a bowl filled with a cup or two of white vinegar on the lowest rack of the dishwasher. Remove any metal pans or utensils, and with the vinegar on the bottom rack, wash the dishes as usual. Dirty dishes that were once covered in film should come out squeaky clean
thanks.
Oct 23, 2010 | Dishwashers
Dishes are still dirty at the end of the cycle
hello,
hope this help?
thanks.
Oct 23, 2010 | Kenmore Dishwashers
My Frididaire Dishwasher Model FDB1250REC1 is discolored inside. Its a browninsh color and it has gotten on my Corningware dishes and stained some of them. I can get most of the color off the dishes if I...
so you need to install a water filter, before you connect water supplie, then you need a special soap to clean wachine (Calgonit diswasher cleaner powder ) use-it without dishes. then use a dishwasher salt (to disolve all water dirt and colour) and rinse liquid (to give a clean glass dimond finish ).
use Calgonit Brand is the most trush, on the masket
Feb 14, 2010 | Dishwashers
GE Quiet Wash 3, top arm does not spin
It sounds like you don't have enough water. Your water inlet valve may be not letting in enough water or the plastic pump inlet screen located on the bottom of your dishwasher had something blocking it.
  1. Check to see if there is something blocking the plastic screen on the bottom of your dishwasher.
  2. When your dishwasher is in the final cycle add a pot of hot water to the dishwasher and see if your dishes come out cleaner.
If the dishes come out cleaner you may need a new water inlet valve.
Dec 29, 2009 | General Electric Adora GHDA670N Built-in...
Dwu7400aax - dishes do not come clean eough
make sure you water is hot enough, manufactures reccommened 120 degrees to the dishwasher, i advise all customers to run hot water at sink til you get hot water then turn dishwasher on, also fill both compartments of sopa, also use rinse aid or jet dry, do not use gel packets. use cascade powder or liquid only.also run the unit through a clean cycle this should be done once or twice a year. letdishwasher fill with hot water. when starts to wash, open door and add 2 cups of white distiilled vinegar and close door and let it go throughas cycle. no dishes. also i reccommened dish majic cleaner sold at walmart or grocery stores. if this dont help then youw wash syatem could be bad or going bad.hope this helps you. try all these things first befor you re[lace uniy or pay to have it looked at.
Sep 17, 2009 | Maytag 24 in. DWU7402 Built-in Dishwasher
Dihes not clean
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwasher not cleaning dishes. Casade cleaner not disolved.???
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
588 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
