Question about Philips Magnavox 27MS343S 27" TV
Trying to get channels above 42 to 99
As many others have, I bought a good cond. Phillips hotel TV. Turned it on, good picture and sound. I knew there was no remote so set up a universal remote.
What I didn't know was even though it is on my cable system, I can't get any channel above 42.
Any tricks ot ideas or solutions?
Thanks.
I had the same problem the solution is you have to get institutional remote and reset the tv from commercial mode to consumer mode and then you will have access to the full menu. go to www.phillipsitv.com to get the directions. I actually asked a Hotel could I borrow their master remote used it and took it back and my tv works fine. Hope this helps.
Posted on Jul 24, 2008
  • SMOOOV2 Jul 24, 2008
    In the above post the website is www.philipsitv.com or just look up RC2573GR that is the institutional remotes model number.
    Genius:
  • 1,694 Answers
Many older sets have an upper channel limit = 42,46,54,64,etc.
If you can't dial direct ...4-3 enter, 4-4 enter,etc...........
If you CAN dial direct, then you would need a service remote
to program.............becuz it's a hotel TV.........
Posted on Dec 01, 2007
SOURCE:
I have a Phillips Tv That I have bought off of my employer (Hotel Industry) with the Model # 32HF7544D/27 and I'm unable to get it programmed to channel 73 which is what my Satalite company uses (
Hotel sets use a special remote with specific instructions--you need to get that remote and the instructions---hotel knows that..........
Apr 08, 2012 | Televison & Video
Phillips 42PFP53320 42" Plasma TV. No picture,
Hello jporter...
welcome here in fixya..
That problem is one of the common problems of plasma TV (have sounds but no picture)..As a expert of flat panel for more than 5 years I already encounter that kind of problem many times..
Actually that problem is caused of either X,Y or Z sustain board or even both 3 boards are faulty..Because some models when the one of those boards have short circuit or bad there are possibility that other sustain board are affected..But most the problem like yours is "Y-SUSTAIN" board..
I can't find your model online please double check it it either Phillips 42PFP5332D/37 or 42PFP5532D/05
And for specific and easy way to find replacement please try to look at the part # of that board (it is usually printed on the sticker attach to the board itself..
Hope it helps and please don't forget to rate my answer..
Have a nice day!!!
regards,
Chester.
Feb 04, 2012 | Philips Televison & Video
I have a Zenith Tv that I bought from a resale store after it had been used by a hotel. When the hotel had owned it they had programmed it to return to a specified channel every time that it is turned off...
there should be an auto program on the menu, but you can also download the complete manual for this model here http://www.retrevo.com/support/Zenith-B27A11Z-TVs-manual/id/277dj086/t/2/
Jan 13, 2011 | Zenith B27A11Z 27" TV
CANNOT RETUNE THIS TV BUSH TV DVD COMBO LY2211WCW
Press menu button then press 7935, if like me you bought a display model it will be set to hotel mode, this hides all the menus, once accessed switch hotel mode off, job done x
Jun 11, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
Trying to connect Phillips surround sound to Sony Wega Trinitron
u go for different music modes of ur home theatre... say 5 channel stereo or something other. u can get the sound. better luck.. if not clearly mail me about the problem...
[email protected]
www.kanny-sounds.blogspot.com
Jan 25, 2009 | Audio Players & Recorders
Bought TV from hotel not getting channels and not playing dvds
in the menu usually a button on tv switch from antenna to cable or catv
if you remote won't work there are 7 or 8 different code choices go through them till it does work
most unversals need tv on and will turn off when code is right
also in menu is audio choices stereo on /off and so on play in there till you get it
Dec 26, 2008 | Philips TV Tuner Video Capture PCI Card -...
Hotel TV remote
for phillips tvs that come out of a hotel try this code with RCA universal remote. the big remote not a small remote. 319753 followed immediately by the mute button. this will pull up the tv setup menu.
Jul 31, 2008 | Philips Magnavox REM-350 Remote Control
Phillips tv 32pf77320A/37
problem was with the FIOS Box not the phillips TV. The box appeared to be working but would not respond to channel changes and is being replaced.
Jul 12, 2008 | Philips TV Tuner Video Capture PCI Card -...
Sound bar only goes to #5 (low sound)
It maybe a model that is used in hotels and has a volume lock on it.You need to contact the manufacturer, or read the instructions on how to override it.
Jul 11, 2008 | Philips TP2784C TV
TV channels
If cable is hooked through cable box with a coaxial cable, then turn tv to ch 3 or ch 4 as appropriate.
If cable is hooked through any other type of cord (red/green/blue or red/white/yellow) use the AV+ or Source button to change your source to Av1, AV2, HDMI, or however you have the cable box hooked to TV (I am assuming your TV is a Philips).
Feb 24, 2008 | Philips TV Tuner Video Capture PCI Card -...
Philips Magnavox 27MS343S 27" TV Logo
553 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
