Rear projection tv coolent replacement
Directions on how to replace coolent ona philips MX5471C
  • jmbmicro Dec 01, 2007
    I am not shure what problem you are addressing, The problem I have is a hazy picture caused by bacteria in the cooling flued I need directions for replacing it
    or a service manual for philips MX5471C
    I have a philips 54" rear projection tv I need directions on replacing the crt coolent it has bacteria in it causing the picture to be hazy
    model # MX5471C
    Novelist:
    Champion:
  • 232 Answers
JMB, your diagnosis is correct, you need a fluid change, you WILL need the service manual and even with it this is a formidable job for a lay person, not to say you can`t do it but it is a major job. manual can be purchased here www.partstore.com by consumers. There are several steps that will speed up the job that are not listed in SM, And I strongly suggest when you get ready to purchase the fluid you DO NOT buy Philips fluid because the bacteria will come back again in several years, I purchase RCA`s fluid as it is cheaper and won`t cause the bacteria problem in the future. When you buy SM ask the parts person to send you a bottle or two of RCA or any other brand of fluid other than Philips. When you have the manual & fluid in hand get back on here before doing anything and I`ll give you some tips that will make this a LITTLE easier and faster, one more thing, which tube is cloudy Blue or Green? BMW Rider
Posted on Dec 01, 2007
  • 83 Answers
If you're NOT still under warrantee you should at least open the TV and look for a blown fuse near where the power cable enters the set. A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace.
Check the fuse. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs.
You can also check the board where the components are mounted and resoled any that look bad. Brief power outages may cause the TV to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet.
In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer.
All can be replaced at a local electronic or hardware store and they're easy to replace
If this does not correct the problem, you may need to have your TV serviced.
good luck!
Philips 46 in rear projection tv has too much green. The bulbs are good but adjusting the color does not help.
this models have coolent issues. I would tke off the front screen very carefully , as it may seperate , get a friend . Do not scrach the screen. then look down inside the units CRT's (Cathode Ray Tube) and see if its cloudy or fuzzy looking . While there look at the blue tube as well. If its fuzzy replace the coolent.
Jul 08, 2010 | Philips 43P8341 43" Rear Projection...
Change coolent in projction tv
This is not something the average user should try to accomplish. The old coolant needs to be disposed of properly. The CRT's and cooling chambers needs to be cleaned and then new cooling fluid needs to be placed in the TV. I recommend having a technician do this for you...
Nov 11, 2009 | Philips Magnavox 51MP392H Rear Projection...
Replacement Lamps/Bulbs for Philips 50P8341 Rear Projection TV
These are both CRT type TV's(3 picture tubes drive the image) with different screen sizes and the CRT's are not interchangeable
Oct 24, 2009 | Philips 50P8341 50" Rear Projection...
Need a remote for philips 43pp92 0217 rear projection tv.
Here's a link to order the original Philips remote control for this model (43PP920217) from a major parts distributor:
Philips 43PP9202 17 Replacement Part Remote Control
Feb 17, 2009 | Philips 43PP9202 43" Rear Projection...
Nothing but Red Screen
check to see if you noticed some liquid on some of the wires on the red crt could the crt coolent be leaking onto the board under the crt and the blue crt is missing alot of coolent!!!
Jan 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Replacing Coolent
I have the service manual, and it looks like this is a bit of a job. You also need a special coolant fluid, not water. Still, I can't think why this would need replacement unless it has leaked out or you were replacing the picture tube. Are you sure it's not a focus problem?
Jan 13, 2008 | Philips 60PP9202 60" Rear Projection...
Directions on replacing coolent
  1. Must be careful, projection coolent must not get on circuit board. It will short out. You must have a pump to suck coolent out of tv. Use alot of towels to catch dripping fluid.
  2. first take off lense
  3. then take out drain plug
  4. suck out coolent, be sure to either raise tv up to level off or have towel out to capture all fluid lost.
5 then when all out, clean all parts with windex or glass cleaner.
6 check gasket if bad replace.
7 refill with new coolent, remember to fill all the way.
Dec 01, 2007 | Philips MX5471C 54 in. Rear Projection...
Philips 55PP9401 55 in. Rear Projection
First, repair convergence problem = replace both convergence
IC's ....STK392-110 sub to upgrade STK394-160E....I use
Hitachi part # CZ 01341.......next, look for discolored resistor
near IC's.....replace with exact value......last = activate
Auto-Intellisense.....................T.
Sep 25, 2007 | Philips 55PP9401 55" Rear Projection...
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
