Question about Microsoft Xbox 360 Console
XBOX with HDMI
Hi I have a HDMI cable Just the HDMI cable not the one with DVI converted and stuff.....
this is how my XBOX looks like at the back panel i dono if its a older version or something
http://www.ixbt.com/consoles/images/info...
How will i connect HDMI please help,,,,
  • 119 Answers
Hdmi only works on the premium, older ones don't support it, there you should use scart
Posted on Dec 08, 2007
  • Dick van Zalinge Dec 08, 2007
    i mean, a normal cable, i was wrong, it wasn't scart, ehh, you need the standard xbox 360 cable atleast
SOURCE:
HDMI&DVI ports already used on LG HDTV.I have X BOX 360 S,has a HDMI plug, can I use a HDMI splitter to plug in the X BOX in the DVI port ?receiving computer via HDMI now
You will not be able to split them, but they do make a HDMI Switcher, allowing you to use your Xbox 360 as number one and your PC as number 2, w you cannot mix both at the same time.
May 02, 2016 | LG Televison & Video
How should I connect a Sony Wega KF-50WE620 to an XBox360 ?
Since the TV accepts HD signals only via DVI and component inputs, the only logical way is to use the "Xbox 360 Component HD AV Cable" as show in the link below:
How to hook up your Xbox 360 or Xbox 360 to TV
The TV will not accept a VGA input. A cable converting HDMI to DVI would also require that you break out the L + R audio channels, too. The one I mentioned above does this all for you with no degradation in video signals.
Mar 26, 2015 | Sony Grand WEGA KF-50WE620 Television
Using with a laptop
Connection the monitor depends on the connections you have out of your Toshiba laptop.
The monitor has both VGA and DVI.
If the Toshiba has a VGA out, all you need is a VGA cable available online, computer or electronics store.
If the Toshiba has an HDMI out, you can connect it to the DVI on the monitor with an HDMI cable and an HDMI to DVI Adapter.
You can also use USB out with either a VGA converter or a DVI converter (go with DVI for the better picture). Converters can be found online at Amazon, you may also need a standard male to male DVI cable to use with the converter.
Amazon com uxcell Black Blue VGA 15 Pin Male to Male Plug Computer Monitor...
Amazon com 5m High Speed HDMI Cable Ultra HD 4k 2k HDMI Cable HDMI to HDMI...
Amazon com Rankie Gold Plated DVI to HDMI HDTV Male to Female Adapter...
Amazon com StarTech com USB to DVI External Video Card Multi Monitor...
Apr 05, 2014 | HP Pavilion F1903 19" Flat Panel LCD...
I have a 2002 Mitsubishi Medallion TV. The only input for HD is DTV (no DVI or HDMI inputs). Is there a converter box from HDMI to DTV that will allow for 1080i resolution?
From looking at the back panel of the TV, the DTV input can be configured as a component video. The M-Link/DVI-HD port is also a DVI with HDCP port and maximum signal handled is 1080i. The M-Link should work with an HDMI to DVI cable or adapter. For this to work, the source must not be a computer or another device using the default computer video output (computers give RGB output). The DTV port would need an HDMI to Component video converter. See this page for some examples: http://www.hdtvsupply.com/hdtocoad.html . The first one in the list (for Netflix and Boxee among others) will give 1080i out if the source is set correctly.
Most DVI-HDMI cables are single link. I've seen some examples where DVI-I (single link) and DVI-D (dual link) cables are not interchangeable. If you have video problems, check your cable. An HDMI to DVI adapters will let you run an HDMI cable up to the TV and then converter at the TV as a separate connection.
I hope this helps.
Nov 17, 2010 | Mitsubishi WS-65613 65" Rear Projection...
Can you use an xbox arcade on flatron LG L1810T? If so which setting does it have to be on as the tv is not recognising the xbox at all
HI,
Your LG LCD monitor has a white DVI connector for connecting the signal cable.
You would reqire either an HDMI to DVI(male connector cable for the xbox) so that you can hook the hdmi cable to the xbox and other end to your monitor.
The cable would look something like this
http://hardware.teamxbox.com/reviews/xbox-360/40/Xbox-360-VGA-HD-AV-Cable/p1/
Thanks
proton
Jun 06, 2010 | LG Flatron L1810T 18.1" LCD Monitor
What cables do I need to connect my toshiba satellite m55 laptop to my hi def tv?
This really depends on the connectsionon your hi def TV. The laptop doesn't have an HDMI port (these ports carry sound and video in one cable), but it does have a VGA out port as well as a s-video out.
You can connect an s-video cable from your laptop to your hi-def TV, if the TV has an s-video input port.
You can also purchase a VGA to Component converter if your hi-def TV has component inputs, these are the Red, Green, Blue inputs. Amazon sells these, here is a link: http://www.amazon.com/Premium-VGA-Component-Cable-Black/dp/B000RJLSZU
If you have a DVI input you can purchase a VGA to DVI converter as well. These are very inexpensive and you can find a wide selection on Amazon, here: http://www.amazon.com/s/ref=nb_ss?url=search-alias%3Delectronics&field-keywords=vga+to+dvi
Finally, you can also purchase a VGA to HDMI converter. This would be the most expensive option, but you can use this box to put both sound and video from the laptop onto the HDMI cable. YOu would need both the converter and cable for this to work. Converter is here: http://www.amazon.com/VGA-Audio-HDMI-Converter-Adapter/dp/B0015YWV1G/ref=sr_1_3?ie=UTF8&s=electronics&qid=1263068538&sr=1-3
Cable is here: http://www.amazon.com/HDMI-meter-foot-cable-1080P/dp/B0002L5R78/ref=pd_bxgy_e_img_b
Jan 09, 2010 | Toshiba Satellite M55-S325 Notebook
Connecting my laptop to my new TV
Hi there.
Check on the back of the TV for a VGA input port, if it has what you will need is a male to male VGA lead and a mini stereo to mini stereo audio lead to plug into the headphone port on the laptop to audio in on the TV.
Good luck and thanks for using Fixya!!!
Feb 23, 2009 | Compaq Computers & Internet
Sony KF50we60 hdmi-dvi sound cuts when plugging into a ht-sf2300
DVI = HDMI without the audio connectors. So basically you need to connect your audio in some different way, PS3s allow you to keep your video signal as HDMI and change the Audio signal to component, so that is one way or doing it, not sure if the blue ray players allow you to do this though.
Nov 22, 2008 | Sony Grand WEGA KF-50WE620 Television
Microsoft Xbox 360 Console Logo
90 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
