Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
Posted on Aug 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Removing 12.5 briggs&stratton engine,central bolt WON'T come out!
The central bolt that goes from the engine and works the cutting arms, just will not come out!
I have tried everything I can think of including turning it on it's side and useing wood & a metal bar to try and prise it off, it just won't budge.
I am trying to remove the engine to replace it.
Any ideas anyone?
Anonymous
Level 2:
Sniper:
  • Expert 95 Answers
  • Posted on Aug 16, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
95
Questions
0
Helped
100492
Points
321
The easiest way is to use an electric or air powered 1/2 inch impact gun to get the bolt loose.
Briggs & Stratton model 13A8693F190. Torque settings?
Torque setting briggs stratton model 13A8693F190
Fixya https://www.fixya.com > Forum > Garden > Briggs
7 days ago - Need head bolt torque for Brigges Stratton 18 Hp ... 210 to 230 inch pounds. Torque in a crisscross pattern upper left lower right upper right or left or right.
Torque for briggs and stratton 6.5 mower engine
1 answer
Aug 15, 2019
I'm trying to find torque specs for the head on a - Briggs
1 answer
May 6, 2022
I need the engine torque specs for a Briggs and
1 answer
May 30, 2009
What are head bolt torque specs. for briggs and
1 answer
Aug 20, 2008
More results from www.fixya.com
How do I Find my engine specifications?
Briggs & Stratton https://www.briggsandstratton.com > faqs > browse > e...
To find basic small engine specs like torque, fuel & oil type, filter or cylinder info, check out specific product pages for your snow blower, lawn mower ...
and also
https://www.google.com/search?q=briggs+%26+stratton+13a8693f190+service+manual
HOW DO I GET A REPAIR MANUEL FOR A BRIGGS AND STRATTON 12 HP IC QUIET ENGINE
Try website for Briggs & Stratton. Or use Google Search for Briggs & Stratton 12 HP IC Quiet Engine Manual.
How to change blade boss on briggs &stratton sp 470
Unscrew the central bolt (9/16") - remove blade and any washers etc. It's a conventional right hand thread (anti-clockwise to remove), but may well be extremely tight. If necessary, grind the head of the bolt off and replace it.
The blade boss slides off the shaft - in theory. In practice, you will probably have to use a puller bearing on the blade bolt to pull it off. Remove the drive belt first!
What are the torque specs on intake manifold on Briggs & stratton
if there is thread locking compound on bolt or threads it must be removed, use a tap to clean the threads and a wire brush to clean the bolts. Use a thread locking compound (blue) when reassembling, torque the bolts to 30 ft. lbs. alternating bolt to bolt in 7-10 lb. increments. Recheck the torque after the engine has been ran up to op temp.
18.5 hp Briggs & Stratton putting in rocker arms back, one goes in to far?
turn the crank see if it rises back up you may have droped one of the guides that ride the cam because youll have to tear her back down
3helpful
Briggs and Stratton Intek V twin 22HP motor misfires.
Misfiring could be caused by simple things like fouled or worn out sparkplugs or an ignition system that is slightly faulty or Fuel problems such as dirty or stale fuel or clogged filter causing a leam mixture. Some B & S motors have an switch that cuts the Ignition if the oil pressure or oil level is low.
Another cause could be the Valve clearances are out of adjustment.
Armed with your Engine Number, visit the B & S Website for comprehensive information and specifications as well as a good FAQ listing.
2helpful
3answers
Remove motor from generator
aramature must be removed to get to the mounting plate it will slide out off case loosen long bolt in center of armature hold armature and hit bolt briskley will pop off be careful putting arm back may be 2 brushes inside have a helper hold brushes back
Engine races
One thing I read is that on some the arm from the govenor shaft can slip on the shaft so the arm is rotated on the shaft to a point the govenor isn't even in contact with the internals driving the shaft. On those units a clamp bolt becomes loose causing the problem.
I suspect if there IS an internal problem it is severe and one would have to disassemble the engine before operating it lest damage occur from loose parts.
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
