Question about Maytag MFI2568AE Side by Side French Door Refrigerator
Control panel doesn't work
Can't change temp or use any controls
Meee Tooo :/?
Posted on Jan 17, 2008
SOURCE:
Heater doesn t work
Your control panel might be broke..
Sep 25, 2013 | 2002 Pontiac Sunfire
Automatic temperature control it's bad burn on me, I order a used "ATC" automatic temperature control and still doesn't work check the fuses and relays still doesn't work
There should be some kind of valve that controlls the actual amount of coolant running through the heater core and there for controlls the temp. There may also be a door that might be stuck that controlls the amount of air traveling through the heater core.
Jan 31, 2013 | Cars & Trucks
I have a Bosch SHU9955US/14 (Integra) dishwasher. There is currently a 0 with and asterisk showing on the display and the unit will not run.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 29, 2012 | Bosch Dishwashers
PSS23SGSSS Front Door Controls not working
if you have replaced the mainboard in the rear of the unit,and it still doesn't change temps then you need to replace the interface control that your using trying to reset the temps
May 02, 2012 | GE Profile¿ Energy Star® 22.6...
My thermador double ovens is not working the control board is not on. it is dead. It is about 8or 9 yrs old.
SUSAN!!!!!!!!! This is EXACTLY what happened to mine! The control panel doesn't show the time or temp or anything! I am going to watch for an answer!!!
Nov 18, 2011 | Thermador Ovens
I can't unmute my speakers. The sound icon is crossed out and clicking on it doesn't change it. Clicking the sound buttons on the keyboard doesn't change the icon either, it remains crossed...
It seems to me that the problem might be a driver issue. Try to restart it, if the problem remains, go to control panel, disable the driver, reboot again and return to control panel and enable the driver again. That might work.
Aug 10, 2011 | Dell Inspiron Mini 10 Notebook
Oven doesn' t work F2 code comes up
F2 is either a temp sensor or control pannel. If it is the control panel, I would suggest buying it online and they will send instructions on how to install. This will save you over half the cost of a service person fixing it.
Aug 01, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Maytag MFI2568AE Side by Side French Door Refrigerator Logo
80 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
