Question about Nintendo GameCube Console
Controller Issue I have a wavebird and now when I play games the game has trouble reading left/right movements on my control stick. Up/down seems to work fine though. How do I fix this?
  • 152 Answers
Can you sync the controller? If so, try to sync it. If you can't, then maybe the controller isn't functional and might need a cleaning. Try opening it up and cleaning it out.
Posted on Dec 24, 2007
SOURCE:
Analog stick are doing the opposite of what they should
I had this problem also on my sons xbox.. You must go into profile and then edit the settings.. In the default game setting you select the actions tba and have movement set as the left thumb stick.. His was set to the right thumb stick.. All sorted now.
Jul 03, 2012 | Microsoft Xbox 360 Controller
Controller wont turn right
Man this is an old question, but as luck would have it, I am facing the same issue with 2 controllers.
This seems to be a known issue with some of the controllers and some sites I have read say it is a 50/50 thing. So buying a new one (which I did) might not solve the problem (which it didn't).
I bought the version that will work with Windows and on the PC it works great. But now that I am playing more on the 360 I have noticed, that in some games at least, I cannot turn right consistently.
Needless to say it is very annoying when trying to drive or shoot someone in game. But as far as I know, there is no "fix" for this problem.
May 04, 2012 | Microsoft Xbox 360 Controller
When using my PS3 COD Black Ops precision controller on other games,... movement of the left analogue stick to the Northwest position has no effect in game , neither does movement of the right analogue...
It sound like the controller is faulty. I suggest returning it. with PS3 controllers 3 party brands tend to be cheaply built. Its best to buy sony's controllers.
Mar 02, 2011 | Mad Catz Call of Duty Black Ops...
I can't get any game to work. We used to be able to wiggle the game or take it out and put it into the console on a different angle, but now it won;t work at all. The power light still comes on on the...
Note: It is possible that the problem you have may be game play related. For example, if you cannot defeat a particular enemy, or are missing an item you need to complete an area, the problem is likely game play related and there is nothing wrong with your game. Please check our game play help for assistance.
  1. Insert the Game Pak into the system. The Game Pak label should be facing the front of the Nintendo 64.
  2. Make sure the Game Pak firmly clicks down into place.
  3. Remove all accessories (with the exception of the N64 Expansion Pak) to see if the Game Pak works correctly without the accessory. If the game does work correctly once the accessory is removed, then the game pak and the accessory may not be compatible. Check the game pak instruction manual.
  4. Check the instruction manual for the game to see if it requires any special accessories, such as the Expansion Pak, to operate.
  5. Check the list of specific game issues to see if there are any known problems for the game you are playing.
Due to the age of the system, we no longer offer factory repairs directly from Nintendo. Please click here to find out what options are available for repair or replacement of your product.
  • Controller Error Messages (e.g. No Controller Detected)
    1. Make sure you are using all licensed accessories with your system. Make sure both the controller is licensed and any accessories you are using with the controller (Rumble Pak, Controller Pak) are licensed as well. Unlicensed products may not be fully compatible with our systems.
    2. Slide the Power Switch on the control deck to the OFF position and unplug the controller. Plug the controller back in, making sure the controller-plug is firmly inserted into socket one (on the left front ofthe control deck). Slide the power switch on the control deck to the ON position.
    3. If possible, try another controller in the left-hand port. If you have a second controller, repeat Steps 1 through 3. If the trouble disappears, the first controller may need to be replaced. For information on locating replacements for older products, please click here.
  • Character Won't Move or Moves on its Own
    1. The most common cause of this problem is when the control stick on the controller is not in the neutral position when the N64 system is turned on. The neutral position is when the control stick is centered, as it is when you hold the controller while not touching the control stick. Recalibrate the Controller by using one of the following methods:
      • Turn the power off on the system. Make sure the control stick on the controller is in the neutral (center) position, and slide the power switch to the ON position. Be sure not to touch the control stick for the first few seconds.
      • During game play you can press the L+R+START simultaneously while the control stick on the controller is in a neutral (center) position.
    2. Consult the Game Pak manual for information on the primary directional control for the game. Some game paks use the control pad rather than the control stick for character movement.
    3. Try cleaning the controller (See Below).
    4. If possible, try another controller in the left-hand port. If you have a second Controller, repeat Steps 1 through 3. If the trouble disappears, the first controller may need to be replaced. For information on locating replacements for older products, please click here..
  • N64 Sticky Buttons or Control Stick, or other controller problems Try the following cleaning procedures:
    1. Unplug the controller from the control deck.
    2. Get a clean toothbrush (no toothpaste) and a cup of warm tap water (not too hot). Do NOT pour or submerge the controller in any type of liquid.
    3. Slightly dip the toothbrush in the water (the toothbrush should not be dripping wet) and scrub the area of the controller around the buttons and control stick.
    4. Work the bristles down around the sides of the buttons and the control stick.
    5. After cleaning the controller, dry it off with a paper towel.
    6. Let the controller air dry for at least a couple of hours.
    7. Test the controller for proper response.
    If possible, try another controller in the left-hand port. If you have a second controller, repeat Steps 1 through 7. If the trouble disappears, the first controller may need to be replaced. For information on locating replacements for older products, please click here.
Transfer Pak
  1. Verify that only licensed accessories are being used with the system. Unlicensed products are not fully compatible with Nintendo systems, and may not work correctly.
  2. Check the game pak manual or packaging to verify that the game is designed to be used with the N64 Transfer Pak.
  3. Make sure the Game Boy game pak works properly in a Game Boy system. It may be a problem with the Game Boy game pak and not the Transfer Pak.
  4. Verify that the game paks are inserted in both the control deck and the N64 Transfer Pak. If they are not, insert them and then turn the control deck power off and back on again.
  5. Verify that the controller is plugged into the proper controller socket on the front of the control deck. If it is not, secure it and then press reset on your control deck.
  6. Remove and re-insert the N64 Transfer Pak, making sure the pak is fully inserted into the bottom of the controller. If it is not, secure it and then press reset on the control deck.
  7. If possible, try another controller. If the Transfer Pak works in another controller, it may be the controller that is having a problem. Check out controller troubleshooting (click here).
If the issue persists, the Transfer Pak may need to be replaced. For information on locating replacements for older products, please click here.
Controller Pak
  • Deleting Saved Information From Controller Paks Depending on the game you own, there are a couple of different ways to delete the saved information on a Controller Pak.
    1. While turning on the Control Deck, hold down the START button on Controller #1. If the programmers utilized this feature, a Controller Pak menu should appear. This menu will allow you to view and delete the contents of the Controller Pak.
    2. If the first option doesn't work, then the game pak will have a feature that can only be accessed from a game menu. For example, in Wayne Gretzky's 3D Hockey, you delete saved info from the Options screen.
    To find out the specifics of how the Controller Pak works with a particular game, check the game's instruction manual.
Expansion Pak
  • For assistance with installing the Expansion Pak, click here.
Jan 19, 2011 | Nintendo 64 Console
How can I re-connect wavebird remotes to my Wii?
Well you should but new battery's or you you could just change the channel and put the same channel on the controller it will work
Jul 10, 2009 | Nintendo Wii Console
Cant make the analogue sticks to move character in game
open up the controller and tact the anolage stick off and clean it.
Jun 20, 2009 | Logitech Rumblepad 2 Game Pad
The left analog stick on my xbox 360 controller is faulty
In this game you must check your settings, you may be set to right handed in which case movement/advance is on the right side and attack is on the left. You should be able to go to settings and change the settings to make the left analog control your movement. Hope this helped and if it does, don't forget to leave feedback....FIXYA!
Feb 14, 2009 | Microsoft Xbox 360 Controller
Wavebird control stick sticks
You wash your hands after you eat right? I had a friend come over once, he had some chips, and then used my wavebird and... must I go on?
Jan 18, 2009 | Nintendo GameCube Console
Wii classic controller
no it wont play gamecube games, but you can buy a nintendo wavebird wireless gc controller and it will play gc games and Wii classic console games
Feb 16, 2008 | Nintendo Wii Console
Gamecube controller [suddenly] not working with Wii
logic 3 controllers are not good, return the logic 3 controller to the store and buy a NINTENDO wavebird instead, i bought mine used and it is perfectly fine. you might have the controller plugged into port (....[4]) instead of port ( . [1]) so try that or buy a wavebird instead ( if you ask me , buy the wavebird). I think my sister's friend's brother had the same problem. But he gave up on it. Probably faulty. Third party gamecube and wii accessories (excluding nyko) are bad or do not last very long.
Sep 19, 2007 | Nintendo Wii Console
Nintendo GameCube Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
