Question about Zenith R40W46 40" Rear Projection HDTV-Ready Television
Computer connection to T.V
How do I connect the audio cables from computer to T.V. to watch vidoe's
on T.V. and listen through the T.V .Speakers
I tried VGA connection also, but could not get the DVI-HDTV Input adapter,
because it did not fit. I was told that it should have fit. Its suppose to
fit al TV'S. Except mine. Could you please help me,
Thanks,
Rosalee
You need to get a grapics card for your pc insall it run the software that came with the card and use the s video to the tv
Posted on Dec 19, 2007
Can I use the speakers for my projectors
Generally, projectors don't have speaker inputs.
If you want to avoid an A/V receiver, connect the PC speakers directly to the DVD player.
Connecting a computer to the projector
Connect the projector to a computer using a VGA cable (included with the projector). In addition, you can connect an audio cable from the computer to the projector if you with to use the internal speaker of the projector. An optional USB cable connection is also available.
1 - VGA cable connection
2 - Optional audio cable connection
3 - Optional USB cable connection
Mar 21, 2011 | iSymphony W2 Audio Shelf System
My speakers dont work
Check the following,
  • Speakers, connecting cables and Sound Card are working fine by connecting to another computer.
  • OR
  • If the connection ok increase your volume and open the cable from the pc.
    Now you will touch the stereo jack, can you can listen a sound when touch the jack. If you will not get any sound, think there is the problem in your amplifier or audio system has not any voltage. To confirm the voltage check by multi miter or can go any local Technician .If the voltage is ok, think your sound system defected and should go to Technician.
  • If your sound system is ok
  • Speaker Cable connect to an audio port (Audio/Video port in system box).
  • Ensure Volume is not in MUTE / Low (in Volume Controller).
  • Audio drivers have installed.
  • To confirm follow next step or ROLL BACK THE DRIVER
http://technet.microsoft.com/hi-in/library/bb457021%28en-us%29.aspx For another check follow the Steps:
• Go to Start>
• Control panel>
• Double click on "System" Icon> (it shows the System PropertiesWindow)
• Select "Hardware" Tab>
• Select "Device Manager" Tab> (it shows the Device Manager Window)
• Select "Sound, video and game controllers">
• Expand "+" symbol> (check the audio Codec's, Legacy Audio Drivers andothers are not in Questioned Mark (?) symbol with yellow color. If there needto install the drivers). So please go there website>supports>download
Hope this helps.
Shibuda,
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Jan 18, 2011 | JBL (JBLONTOUR) Computer Speakers
Is there any way to use headphones on the HP 2159m computer monitor? possibly external computer speakers? I have a desktop computer connected to the monitor by a HDMI cable.
There is no audio output on that monitor. So decoding the HDMI into analog is out. However, the simple fix is to plug your speakers or headphones into the green 3.5mm headphone jack on the back of your computer, and change the default audio device in windows. You can use both audio cards at once for different tasks, such as having someones voice come over your HDMI cable on the monitor, while listening to music on the audio out of your computer.
If you need any help setting the audio card, let me know.
~KenjiFox
Jan 07, 2011 | HP 2159M Monitor
Hi. How do i download from my digital vidoe camera onto my computer
First get your data cable for your digital camcorder . Then connect your data cable with the camcorder and another end to the computer. Now computer says Found new hardware .now you can watch your videos in the computer
Aug 30, 2010 | JVC GR-D53 Mini DV Digital Camcorder
No sound when my computer is connected to my Sony Bravia TV
If your computer has a svga output use input 7 on tv with vga to vga cable and 3.5-3.5 Radioshack 42-2387 cable for audio for best results. If you use the dvi to hdmi on input 6 on tv use 3.5- rca Radioshack part number 42-2551 1/8=3.5mm.
Apr 20, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Compaq wf 1907 monitor speakers--no sound
No sound from monitor speakers
If the built-in speakers on the monitor do not produce sound, perform each step that follows, testing for sound after each step, until you can hear sound:
  1. Close the software program you are using that is experiencing the sound problems. Test for audio using another software program.
    If the volume is adequate using another software program, the issue is with the computer, not the monitor. If the volume is still low, continue with this procedure.
  2. Check the cable connection. If the monitor-to-computer connection is a VGA cable (usually blue on both ends), an additional audio cable is needed between the monitor and the computer. Check that the audio cable is connected properly.
  3. Try to adjust the volume higher using the monitor front-panel volume button.
  4. Using the buttons on the monitor, navigate through the onscreen display (OSD) menu to find audio or speaker settings and enable the speakers.
  5. Click Start c01292216.gif , Control Panel , and then click Sounds and Audio Devices .
  6. From the Volume tab, check the Device volume, and make sure it is not muted.
  7. From the Audio tab, in the Sound playback field, click the Volume button. Make sure the audio device is not muted and the volume outputs are at adequate levels.
  8. If the monitor-to-computer connection is an HDMI cable, an additional audio cable might be needed, depending on the setup and configuration of the system. To find out whether an additional audio cable is needed, go to
HP and Compaq Desktop PCs - Using HDMI Audio with a Desktop Computer
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector.
HDMI sends both audio and video through the same connection. If you want to hear audio from an HDMI connection, HDMI audio must be set through Windows . For example, if a computer is connected via HDMI to a monitor or TV and the proper HDMI audio settings are made, both audio and video will be sent to the display device.
Use the following steps to activate HDMI audio on your computer:
    NOTE: If you are setting up your computer for the first time, it may be easier to use a DVI connection or DVI-to-VGA adapter connection for the initial setup. Then, if you want to use an HDMI connection to connect a TV or monitor, activate sound for the HDMI connector using the steps that follow before connecting the HDMI cable to the TV or monitor.
    NOTE: After recovering the computer using the Recovery Manager, repeat this procedure to activate sound for the HDMI connector.
Step 1: Enabling HDMI sound in the BIOS
To hear audio through the HDMI connector to a monitor or display, enable the Onboard Audio setting in the computer BIOS settings by completing the following steps.
    NOTE: If you choose the default BIOS Setup options or upgrade the BIOS, you must repeat this procedure to enable audio for the HDMI connector.
  1. Turn off the computer.
  2. To enter the BIOS, turn on the computer and press the F10 key repeatedly until a BIOS Setup screen opens.
    A BIOS Setup screen opens.
  3. Press the right arrow key on the keyboard to select the Advanced tab.
  4. Press the down arrow key to select Onboard Audio , and then press the Enter key.
    Figure 1: Example of Onboard Audio menu
    An option window opens.
  5. Press the down arrow key to select Enabled , and then press the Enter key.
    Figure 2: Onboard Audio Enabled
  6. Press the F10 key. Select Yes to save the default settings, and then press the Enter key.
  7. The computer restarts. HDMI sound is now enabled.
Jan 03, 2008 | HP Compaq WF1907 Monitor
Boston Acoustic Speakers from Gateway to Pacer7720-4438 laptop
The laptop should have a speaker output the same size as that plug. This is the size of most small computer speaker systems.
Jan 01, 2008 | Audio Players & Recorders
Connect BX8A speaker to PC
Hello waddragon,
First, let's start with the BX8a. Those are powered speakers (built-in amplifier in each) so, you do not need a pre-amp. What you need to connect them to your computer is a 3.5mm to XLR cable OR a 3.5mm to 1/4" TRS cable, also known as 3.5mm to two 1/4" mono plugs (the back of the BX8a has inputs that accept either type). Cables are available at most any electronics stores. Make sure you buy a long enough cable to run from the back of the computer to where the speakers will be.
It sounds that you only have one BX8a which means you'll be listening to only one channel of the stereo output. In any case, make sure before connecting the speaker(s) to the computer that speaker power is off and volume control is at minimum. Connect the 3.5mm cable end to Line Out 1 jack of the X-Fi sound card and either the XLT or TRS ends to the speaker(s) input(s). Play some audio content on your computer, turn on speaker(s) and slowly increase volume to a safe level. Everything should work fine.
Let me know how it goes.
cancerags
Dec 28, 2007 | M-Audio Studiophile BX8a Speaker
Zenith R40W46 40" Rear Projection HDTV-Ready Television Logo
49 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
