Question about Sharp R-1480 Microwave Oven
Sharp Carousel Microwave R-1601
The door is cracked and we purchased the new part/frame. How do you disassemle the door? How do you remove it from the door from the microwave and take it apart?
  • 1 more comment
  • Anonymous Jan 28, 2009
    The same thing happened to mine when I was cooking 2 baked potatoes. Hasn't turned on since.
  • JCASTRO114 Mar 19, 2009
    DOOR WILL NOT LOCK CLOSE
  • Anonymous Mar 13, 2014
    door is craced need to remove it and reple with new one
  • Sharp Master
  • 9,098 Answers
We have the service manual for the R1750-series ovens available at our Web site.
It's not exactly the same, but it should be generally close enough to help you.
It's at http://microwavedisplay.com/r1750_r1751_r1752_r1754_sm.pdf
Most door panels separate like the one in the example photo below.
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 01, 2007
2 Suggested Answers
SOURCE: Sharp Carousel Microwave R-1601 - Need to Replace Door
we cannot get our light options to work. We changed the light bulbs and had no success. Any suggestions?
needing light!
Posted on Feb 17, 2008
Anyone perhaps know why my LG microwave LMV1683ST will not function with a new door assembly?
I hate to be the bearer or conduit of bad news, but IF the old (broken) door works, but the new door does not, the new door may not be the exact replacement part! Otherwise, the operation would be identical. Clearly, the problem is not with the microwave circuits because they work fine with the original door! Is there a flexible circuit strip that plugs to or from the door, to the control board in the main unit? If so, does it look any different than the original counterpart to it?
Apr 18, 2017 | LG Microwave Ovens
How to remove the outter door frame on the GE Microwave
http://www.repairfaq.org/sam/micfaq.htm
for both queries this site would help somethin i think.. tpugh information is very huge please see if it is useful for u
Dec 25, 2007 | GE Advantium 120 Convection/Microwave Oven
Microwave wont heat
We would need to know the full model number from the tag in the cooking cavity or elsewhere on the microwave, such as the door frame, controller frame, etc.
Please post a new help request with that and more detailed symptoms, such as when it occurs.
When you hit "Start" to microwave, do the inside light, cooling fan, and turntable all come on?
Any unusual noises? Is it louder or quieter than usual?
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
Apr 15, 2013 | Sharp Carousel 1.5 cu. ft. Countertop...
My sharp carousel microwave only works when I depress the door knob halfway down. What could be wrong ?
All microwaves have a safety lever or switch that prevents the unit from working if door is not closed all the way. Most of them you have to take the unit apart as access to it is from inside--what happens is when door is closed the latch or door moves the lever--seen a number where lever is loose or even the holder for it cracked.
Most shops are familiar with this and it should if the problem not be a real expensive repair.
Jun 16, 2012 | Sharp Carousel R530EST Microwave Oven
There is a whirlpool Microwave (model:MH1150XMB4) in our apartment. Unfortunately, there is a crack in the door. Although the crack is only in the plastic frame of the door, the landlord asked us to...
Got the same problem. Still inquiring but I might have found a solution here : http://midwestapplianceparts.com/microwave-parts-537/whirlpool-microwave-parts-648/microwave-door-panel-663/whirlpool-microwave-door-panel-w-glass-4212.html
$79 for the panel only
Jul 01, 2010 | Whirlpool MH1150XMQ Microwave Oven
Wattage Sharp Microwave Ovens Carousel Model R-3A35
i just checked my R-3A36 manual to find out the wattage. it's 800 watts. i make pralines in my microwave. i am always asked for the recipe. so i needed to be able to tell people the wattage of my oven so they can adjust the recipe to their oven.
garry, metairie,la.
Oct 06, 2009 | Sharp Microwave Ovens
Sharp Carousel Microwave R-1460A no power, door switch went first
You will want to replace the fuse and door switches. You will not be able to run it without replacing door switches. You do not need a new microwave. Door switches go bad, it has nothing to do with radiation.
Feb 19, 2009 | Sharp R-1460 Microwave Oven
Microwave Sharp carousel Model R3A36 keypad not working. We had a brown out due to a recent storm and the microwave keypad didn't work anymore after that. We unplugged and replugged and the light inside is...
Your keypad has failed.
It would need a new control panel frame, which comes with the keypad.
You simply remove the circuit board and plug it into the new frame.
It is part # FPNLCB070WRK0 and the best place to order Sharp parts is Tritronics.
Sep 03, 2008 | Sharp Microwave Ovens
It's at http://microwavedisplay.com/r1750_r1751_...
Dec 01, 2007 | Sharp R-1480 Microwave Oven
You need to use the entire correct model number at their site, but you can find a helpful exploded view PDF diagram by searching for "Repair Part" at the GE parts site: http://www.geappliances.com/shop/prts/ Normally you can separate the door panels without removing the door. I've included a diagram from a Sharp model that might help. If you do have to remove the door, you have to be sure you reinstall it exactly where and how it was, or you may get microwave leakage. You should definititely mark the locations of all the hardware before disassembly.
Nov 06, 2006 | GE JVM1650 1000 Watts Microwave Oven
Sharp R-1480 Microwave Oven Logo
401 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
