MSI MS-6523 Motherboard Logo
Posted on Aug 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Problem with power
I have a ms-6523 ver.1 motherboard, Intel Pentium 4 1.3 GHz processor, and the can not to run computer.
Ben Wabnick
Level 3:
  • Master 2,404 Answers
  • Posted on Aug 16, 2009
Ben Wabnick
Master
Level 3:
Answers
2404
Questions
Helped
883847
Points
7655
Make sure the power cables are plugged into the pins properly on the motherboard.
Once you do this then go ahead and reseat the power supply connectors to the motherboard. Only hook up these two connectors from the power supply for now.
Try turning on the computer and hopefully you will get it to turn on now. If you can't then make sure the switch on the power supply is set to 115v. Once this is done try turning on the computer again.
If you still can't get it to turn on then try a known good working power supply or new power supply. If it still doesn't turn on then you know at this point that the motherboard is bad.
Is it possible to replace a celeron 2.7 ghz 400 mhz processor with a pentium 4 2.66 ghz 533 mhz processor without replacing the motherboard?
this depends on your motherboard, and on the processor mounting. But yes it can be done, eg on MS-6577V2.1 m/b, with certain Pentium processors (not all)
Motherboard details will be needed for more detailed advice
10.December.2014
1helpful
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
3helpful
I just need to figure out what the socket type this motherboard has for the processor so that I can find what processors I can upgrade my computer with. It's a g45t/g43t AM 3 V: 1.1 motherboard made by...
The socket type of ACER G45T/G43T - AM3 V1.1 motherboard is LGA 775. Here are the compatible processors you can use for this motherboard :
Intel Pentium 4 (2.60 - 3.80 GHz)
Intel Celeron D (2.53 - 3.60 GHz )
Intel Pentium 4 Extreme Edition
(3.20 - 3.73 GHz)
Intel Pentium D (2.66 - 3.60 GHz)
Pentium Extreme Edition
(3.20 - 3.73 GHz)
Pentium Dual-Core (1.40 - 3.33 GHz)
Intel Core 2 Duo (1.60 - 3.33 GHz)
Intel Core 2 Extreme (2.66 - 3.20 GHz)
Intel Core 2 Quad (2.33 - 3.00 GHz)
Intel Xeon (1.86-3.40 GHz)
Intel Celeron (1.60 - 2.40 GHz)
2helpful
3answers
Does Intel Pentium 4, 2 GHz Processor support 2GB DDR1 RAM..?
Type of RAM supported has nothing to do with the processor make & type in most cases. It is more important to verify that the motherboard supports this kind of RAM.
In general, most motherboards supporting the Intel Pentium 4 2.0 GHz processor support also DDR1 RAM.
2helpful
4answers
Can i up grade my single core cpu pen4 550 3,4GHz to a Quad core or dual core either one would help
Depends on the socket type.. Socket 423 and 478 do not support core duo or quad core processor types. However, if you have LGA 775 (aka socket T) your motherboard will support the following:
Intel Pentium 4 Extreme Edition (3.20 - 3.73 GHz)
Pentium Extreme Edition (3.20 - 3.73 GHz)
1helpful
Hi.. I have a server system having Intel Pentium 4 processor. The following details are written on the Processor. Intel (m) (c) '03 PENTIUM (R) 4 2.8 GHz, IM1800, jl79k MALAY, Q417A92 t417b040 ...
hi,
you can on this motherboard models for your intel Pentium 4 processor,
1. ASUS P4P800 Deluxe
2.MSI Neo2-FIS2R
3.ASUS P4C800 Deluxe
4.Intel D865PERL
5. ABIT IS7
1helpful
2answers
Need a prossesor for motherboard
You can also use any other intel 775 socket processor as well. The dual cores are at the top of the list for performance that are compatible with that board, but if you're looking for a cheaper solution, I have that board with a 3GHz pentium 4 and it runs great. Here's a list of all the processors you can use.
Intel Pentium 4 (2.66 - 3.80 GHz)
(3.20 - 3.73 GHz)
Intel Pentium Extreme Edition
(3.20 - 3.73 GHz)
Pentium Dual-Core (1.40 - 2.80 GHz)
Intel 'Core' Celeron (1.60 - 2.40 GHz)
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
