Question about Sharp R-1480 Microwave Oven
Sharp Carousel Microwave R-1601 - Need to Replace Door
The door is cracked and we purchased the new part/frame. How do you disassemle the door? How do you remove it from the microwave and then how do you take it apart. The only screws showing are on the back of the handle.
  • 1 more comment
  • Cam56 Dec 02, 2007
    Thank you it worked.
  • Anonymous Dec 17, 2007
    I am going to order a new door and will need to know how to replaced it also.
    Thanks~
  • Anonymous Jan 24, 2008
    I have a Sharp Microwave R1481. It has a cracked door and I want to replace it. When you pry off the door cover to get to the screws that hold the door handle on the door, does that affect the latch mechanisms that appear to be spring loaded?
  • Sharp Master
  • 9,098 Answers
We have the service manual for the R1750-series ovens available at our Web site.
It's not exactly the same, but it should be generally close enough to help you.
It's at http://microwavedisplay.com/r1750_r1751_...
Most door panels separate like the one in the example photo below.
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 01, 2007
We cannot get our light options to work. We changed the light bulbs and had no success. Any suggestions?
needing light!
Posted on Feb 17, 2008
5 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Door Removal Sharp Microwave Model R-1611
The door comes off in a very simple way. Now...I'm speaking from the perspective of MOST microwave ovens. All you should have to do is open the door all the way to the left and lift straight up. The door has mounting pins that fit into a couple of hinge pin holes. If your oven is equipped with an upper panel grid, you may have to remove it, so the door will have more clearance. Putting the new door on is just as simple as lining up the pins in the door with the hinge pin holes and setting the door in place. Close the door slowly to make sure the pins are aligned with the holes properly. If not, the door will fall off while attempting to close. Let me know if this is helpful to you.
Posted on Aug 10, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Sharp Carousel Microwave R-1601
It's at http://microwavedisplay.com/r1750_r1751_r1752_r1754_sm.pdf
MicrowaveSvc
  • 9098 Answers
SOURCE: Sharp R-1480 replacment door handle
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and even part numbers.
Most computers will open this document automatically, but you may need the free Adobe Reader.
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
Posted on Jun 16, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Re: Sharp carousel microwave oven minute display light out
Hello there
To replace the light you will first have to remove the outer shell.
To do this
(1). Remove all of the screws on the back of the microwave that hold on the shell
(2) Remove the screws that are on the bottom.
(3) now the shell should slide off towards the back of the microvave.
Note : this may take a little bit of pressure to get it off ok?
(4) Once the cover is off look towards the fromt of the microwave and
you will see the bulb. now just replace the bulb and reinsert the cover and the screws and you are all done ok? pretty easy ha/
best regards michael
Posted on Sep 28, 2009
Anyone perhaps know why my LG microwave LMV1683ST will not function with a new door assembly?
I hate to be the bearer or conduit of bad news, but IF the old (broken) door works, but the new door does not, the new door may not be the exact replacement part! Otherwise, the operation would be identical. Clearly, the problem is not with the microwave circuits because they work fine with the original door! Is there a flexible circuit strip that plugs to or from the door, to the control board in the main unit? If so, does it look any different than the original counterpart to it?
Apr 18, 2017 | LG Microwave Ovens
How to remove the outter door frame on the GE Microwave
http://www.repairfaq.org/sam/micfaq.htm
for both queries this site would help somethin i think.. tpugh information is very huge please see if it is useful for u
Dec 25, 2007 | GE Advantium 120 Convection/Microwave Oven
Sharp carousel 1200 watts microwave manual
They is one of the DOOR SWITCH need to replace
Aug 17, 2014 | Sharp R-1480 Microwave Oven
My sharp carousel microwave only works when I depress the door knob halfway down. What could be wrong ?
All microwaves have a safety lever or switch that prevents the unit from working if door is not closed all the way. Most of them you have to take the unit apart as access to it is from inside--what happens is when door is closed the latch or door moves the lever--seen a number where lever is loose or even the holder for it cracked.
Most shops are familiar with this and it should if the problem not be a real expensive repair.
Jun 16, 2012 | Sharp Carousel R530EST Microwave Oven
There is a whirlpool Microwave (model:MH1150XMB4) in our apartment. Unfortunately, there is a crack in the door. Although the crack is only in the plastic frame of the door, the landlord asked us to...
Got the same problem. Still inquiring but I might have found a solution here : http://midwestapplianceparts.com/microwave-parts-537/whirlpool-microwave-parts-648/microwave-door-panel-663/whirlpool-microwave-door-panel-w-glass-4212.html
$79 for the panel only
Jul 01, 2010 | Whirlpool MH1150XMQ Microwave Oven
Wattage Sharp Microwave Ovens Carousel Model R-3A35
i just checked my R-3A36 manual to find out the wattage. it's 800 watts. i make pralines in my microwave. i am always asked for the recipe. so i needed to be able to tell people the wattage of my oven so they can adjust the recipe to their oven.
garry, metairie,la.
Oct 06, 2009 | Sharp Microwave Ovens
Sharp Carousel Microwave R-1460A no power, door switch went first
You will want to replace the fuse and door switches. You will not be able to run it without replacing door switches. You do not need a new microwave. Door switches go bad, it has nothing to do with radiation.
Feb 19, 2009 | Sharp R-1460 Microwave Oven
Dec 01, 2007 | Sharp R-1480 Microwave Oven
You need to use the entire correct model number at their site, but you can find a helpful exploded view PDF diagram by searching for "Repair Part" at the GE parts site: http://www.geappliances.com/shop/prts/ Normally you can separate the door panels without removing the door. I've included a diagram from a Sharp model that might help. If you do have to remove the door, you have to be sure you reinstall it exactly where and how it was, or you may get microwave leakage. You should definititely mark the locations of all the hardware before disassembly.
Nov 06, 2006 | GE JVM1650 1000 Watts Microwave Oven
Sharp R-1480 Microwave Oven Logo
624 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
