Question about Kenmore 91112 / 91114 / 91117 Electric Kitchen Range
Kenmore electric range 911.9369181
We have a Kenmore electric range model 911.9369181. Every time we try to use the oven, we set the temperature and turn it on. Within a minute, it will shut down on its own. We have tried setting the cook time and then setting the temperature, and that worked once, but now that will not work either. Any time we try and turn on the oven, it shuts off on its own within a minute. HELP!
    Sergeant:
    Champion:
  • 310 Answers
F8 Failure of Electronic Range Control (ERC) Replace Electronic Range Control/Clock (ERC)
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Posted on Jan 01, 2008
F-8 ERROR ON DISPLA AND INCESSENT BEEPING.
PLEASE HELP ME. I have tried clear and pressed timmer and all nothing stop it from beeping.
I HAVE AN OLD BIG KENMORE STOVE. ALL 4 BURNERS WORK, BUT THE OVEN STOPPED WORKING, BUT OVEN DOES NOT. AND I CANNOT USE IT BECAUSE OF INCESSENT BEEPING, THE ONLY WAY TO STOP BEEPING IS TO DISCONNECT FROM THE WALL UNIT. THE ERROR ON DISPLY IF F-8, I cannot clear the display, no matter what I do.
Posted on Dec 05, 2007
SOURCE:
Kenmore oven error code f10
on that type of range F10 indicates a problem within the electronic control, but it could possible be caused by a faulty temperature sensor.
I would recommend service from a technician
May 27, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Range Cleaning Cycle not Working
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 22, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidiare electric range time bake and self cleaning
F3 The oven temperature sensor is open Check for open wire connection between EOC (Electronic Oven Control - Clock) and the oven temperature sensor. Replace sensor if no wiring problem. F3 Oven temperature sensor open Check oven temperature sensor, 1100 ohms F3 Oven temperature sensor open Replace oven temperature sensor F3 Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor and control
Nov 26, 2008 | Frigidaire FEF336BC Electric Kitchen Range
790/9546/1990 Kenmore Electric Range
Here's a link that you can order your manual from: http://www3.sears.com/. Good luck!
Jul 17, 2008 | Kenmore 47722 / 47724 / 47729 Electric...
F3 and F2 Error Codes
If hitting clear/cancel won't clear it try unplugging and then plug it back in. My guess is the oven control is bad. Here are the fault codes for this model.
Failure
Code
Condition Check/Repair F0 or F1 Failed transistor in control If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad F2 Oven over temp - exceeded 590F with door in unlocked position or 990F with door locked If actual temp condition occurred, look for welded relay contacts or high resistance connection or any cause in the oven temperature sensor circuit F3 Open oven temperature sensor circuit Measure oven temperature sensor circuit at oven temperature sensor (should be approx 1100 ohms at room temp); check for cut or pinched wire or loss of contact F4 Shorted oven temperature sensor circuit Same as above; check for melted connector or both leads shorted to ground F8 Component failure within Electronic Range Control (ERC) effecting temp processing circuits Replace Electronic Range Control (ERC) F9 Problem with door lock circuit such as pinched wire between Electronic Range Control (ERC) and door lock switch Check wiring and test operation of switch
Jul 15, 2008 | Ovens
Kenmore range oven will not hold temperature
You're glow bar ignitor is on its way out. I had this exact problem and swapped mine out with its identical sibling that runs the broiler element. Problem fixed.
Jun 22, 2008 | Tappan TGF320 Gas Kitchen Range
Kenmore electric range F5 and F3 warnings
May 13, 2008 | Kenmore 30169 Electric Single Oven
Oven gives me an -F3- message and stops working
F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse
May 21, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Kenmore 91112 / 91114 / 91117 Electric Kitchen Range Logo
593 people viewed this question
Top Kenmore Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
