Question about Philips MX5471C 54 in. Rear Projection Television
Directions on replacing coolent
Need directions on replacing coolent on a philps MX5471C 54 IN. REAR PROJECTION TV
    Genius:
  • 1,153 Answers
  1. Must be careful, projection coolent must not get on circuit board. It will short out. You must have a pump to suck coolent out of tv. Use alot of towels to catch dripping fluid.
  2. first take off lense
  3. then take out drain plug
  4. suck out coolent, be sure to either raise tv up to level off or have towel out to capture all fluid lost.
5 then when all out, clean all parts with windex or glass cleaner.
6 check gasket if bad replace.
7 refill with new coolent, remember to fill all the way.
Posted on Dec 01, 2007
Samsung PCL545R 54 in. Rear Projection Television
Ur tv have a problems known as a convergence problems,it dead.The tv covergence board must have it 2 STK Convergence ICS and some or all resistors be rreplaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 05, 2010 | Samsung PCL545R 54" Rear Projection...
Cannot manually Converge Samsung PCL545R 54 in. Rear Projection Television. Perfect focus doesn't work either.
Try website like Tv repair World.com to buy a whole convergence board to replaced.Samsung/Akai use the same convergence board.
Apr 26, 2010 | Samsung PCL545R 54" Rear Projection...
54" Mitsubishi Rear Projection TV HD
Need more infomation of the syptom and check weather the convergance IC's are working properly?
Sep 28, 2009 | Televison & Video
My samsung pcl542r has a red tinge to it adjustments do not seem to help
the picture tubes (green&blue) are the problem
they either have bad liquid or coolent pad
Jun 07, 2009 | Samsung PCL545R 54" Rear Projection...
Akai PT5492S 54" Rear Projection TV
Your set needs to have both Convergence ICs replaced they are Both STK392-010 you can get new ICs at the following link and they provide free step by step instructions with pics so you can do the job yourself which takes about 45 minutes. Heres the link.
http://servicemanuals.vstore.ca/
May 10, 2008 | Akai PT5492S 54" Rear Projection...
PCL542r convergence
Samsung part number AA95-00706C its available at www.partsstore.com
Mar 13, 2008 | Samsung PCL545R 54" Rear Projection...
Rear projection tv coolent replacement
If you're NOT still under warrantee you should at least open the TV and look for a blown fuse near where the power cable enters the set. A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace.
Check the fuse. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs.
You can also check the board where the components are mounted and resoled any that look bad. Brief power outages may cause the TV to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet.
In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer.
All can be replaced at a local electronic or hardware store and they're easy to replace
If this does not correct the problem, you may need to have your TV serviced.
good luck!
Dec 01, 2007 | Televison & Video
AKAI 54" rear projection TV
The convergence sensors either need to be re-initilized or one of them is bad. The service menus needs to be acsessed to re-initilize the sensors.
Apr 08, 2007 | Akai PT5492S 54" Rear Projection...
Philps 30pf9946
Is this on all inputs? or just the antenna input conected to cable?
Feb 28, 2007 | Philips 9P6040C 60" Rear Projection...
Open Questions:
See all Philips MX5471C 54 in. Rear Projection Television Questions
Televison & Video Logo
56 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
