Question about Magic Chef CER3760 Electric Kitchen Range
F1 on display, oven not working
Set oven to self clean, about an hour into it, heard beeping and f1 displayed, now oven doesn't work,,stovetop is okany suggestions?
4 Suggested Answers
SOURCE: have a magic chef oven, f1 display after self cleaning
Your sugestion does not work.I press CLEAR/OFF and power off several times, the F1 error and beeping is continue every 2 minutes. Any other suggestion?
Posted on Jan 02, 2008
  • 2651 Answers
SOURCE: magic chef gas range; oven takes about an hour or so to preheat.
most common issue, and it sounds like what your experiencing here, is a faulty ignitor, replace the bake ignitor ( located under teh oven floor, attached to the burner bar)
Posted on Feb 27, 2009
  • 530 Answers
SOURCE: Magic Chef oven & broiler do not work
you know i am thinking more towards a bad temp probe.
Posted on May 28, 2009
  • 1772 Answers
SOURCE: after self cleaning oven, door lock light remains
Sorry to read about your problem, I hope this helps you out.
you may just have to turn off at your ckt breaker, more easy than unpluging
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Posted on Dec 26, 2010
0 characters
1 Points
My oven keeps displaying the symbol "F1" and continuing to auto-clean
Try pressing the stop/cancel button, if this does not work unplug stove and wait five minutes and then plug back in, this should clear the display
Nov 16, 2009 | Frigidaire FEF366EC 30" Freestanding...
F1 llight on, oven locked, stove beeps every few seconds
My stove did the same thing after I cleaned it. I had to have the sensor replaced. That is what the F1 code is.
Oct 01, 2009 | Frigidaire Gallery GLEFM397DS Electric...
F1 the key board does not work
Your keypad is stuck.
Jiggle all the pads and try it again.
If that does not work, replace your keypad.
Feb 24, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Does not go into self clean only beeps
here is a link for your owners manual click here
To set Self-Clean:
1. Close the oven door.
2. Press the appropriate Clean pad.
• CLEAN flashes.
• SET and UPPER or LOWER flash in the display.
3. Press the Autoset pad.
• “MEd” (Medium Soil, 3 hours) is displayed.
4. Press the Autoset pad to scroll through the self-cleaning
“HVy” (Heavy Soil, 4 hours)
“MEd” (Medium soil, 3 hours)
“LITE” ( Light Soil, 2 hours)
Choosing the soil level of the oven automatically programs
the self-cleaning time.
5. After four seconds, the oven will start cleaning.
• If the door is not closed, beeps will sound and ‘door’ will
display. If the door is not closed within 30 seconds, the
self-cleaning operation will be canceled and the display
will return to the time of day.
• CLEAN will appear in the display.
• LOCK will flash in the display. Once the door locks,
LOCK will remain steady.
• The cleaning time will start counting down in the
Please take the time to rate this solution
Jan 30, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Oven will not work displays f1 error code
I have a Frigidaire self cleaning range model PFEF385JHB1. The range is beeping and the display reads F1 locked. I can not find my user's manual. Please help! Nothing is working.
Nov 01, 2008 | Frigidaire Kitchen Ranges
Maytag Model # MES5770AAB F1 error
Hi was using the oven and as soon as it reached the tempurture i set it to the F1 went on and beeped. I hit cancel and resumed it to see if it would finish cooking and it did. I just dont know what f1-1 means and its almost Thanksgiving. Has anyone found out what F1-1 means??
Setauket mom
Jul 28, 2008 | Maytag MER5770 Electric Kitchen Range
Problem codes for self-cleaning ranges
My experience (Kenmore Ultra-bake Model 665-72002102) was that E1 F5 meant an error with the oven lock switch. In our case, the latch was partly stuck from food or other debris. Just moving the latch back and forth loosened the scale that was making it stick, and it worked again.
Dec 05, 2007 | Kitchen Ranges
Have a magic chef oven, f1 display after self cleaning, stove top works fine, any thoughts
F-1 is a fault code.
Disconnect the power plug or turn range power off at circuit breaker. Wait a couple of minutes, then plug the range in or flip the range circuit breaker to ON.
Oven control beeps & displays any F  code error (for example
F11) - Electronic control has detected a fault condition. Press
CLEAR/OFF to clear the display & stop beeping. Reprogram
oven. If fault recurs, record fault number. Press CLEAR/OFF
contact an authorized service agent.
Dec 01, 2007 | Magic Chef CER3725AA Electric Kitchen...
What does "F1" mean? The oven is out!
I think f1 is a problem with the oven control board. Look on the back of the oven for a tech sheet and it will tell you what the codes mean and what to check.
Sep 24, 2007 | Crosley CE35111AA Electric Kitchen Range
Magic Chef CER3760 Electric Kitchen Range Logo
26 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Barrett Palumbo
Barrett Palumbo
Michael Thomas
Michael Thomas
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
