TV wont come on
TV will not turn on, is my picture tube out? the tv was playing and went off and will not come on nothing on tv works checked electrical plug and wall outlet and they are ok batteries in remote are ok
  • dllawton Jan 18, 2009
    Same problem does anyone know hoe to change a fuse which I am assuming is the problem --no power
  • jaragon195 Feb 17, 2009
    the t.v. was working and then I went to turn it on it nothing, no picture, no sound, no power. Nothing. My television is less than 3 years old
  • 99 Answers
Try changing the fuse located inside your tv cabinet.
good luck---------------tomtaso
Posted on Dec 01, 2007
SOURCE:
My TV has a green / purple tint on the corners. Help?
It might be due to picture tube problem... As its too old, the picture tube might be weak and hence you might get colors at the edges.. Better replace the picture tube with a new one to solve this problem
Apr 01, 2012 | Bush Televison & Video
Picture and sound went out. quickflash across the screen. then nothing. tv still has power. model number 46ex2b. couldn't find it listed
the problem may be in the heater supply, there are 3 picture tubes in projection tv. remove the back cover, switch on the tv & observe the heaters are glowing inside picture tubes. if not unplug the tv wait for 2 minutes, & trace the picture tubes' heater wires. there may be dry solders in heater power supply.
Aug 25, 2011 | Hitachi Televison & Video
I have a sears tv thats a tube tv.I have digital cable and i programed the remote.I pressed PIP on off button and my tv went dark and wont shut off.I have to unplug it.Now when i turn it on the tv it is...
Old-timey tube TVs can't handle PIP. In fact, some old DLP TVs would be in danger of physical damage should you even attempt to output progressive signal.
As such, it's likely that your TV has given up the ghost. Might be time for an upgrade.
May 06, 2011 | Televison & Video
My philips tv keeps losing the picture, still have the sound in the background but no pic, this has happened before and then went back to working fine, but yesterday turned on the tv, it worked for 5 secs...
Check if the tube lights up at the rear, the fillament must glow.If not check for badly soldered joints at the picture tube connection or the HT transformer.
Aug 15, 2010 | Philips Televison & Video
Wii froze and wont Turn off after playing game
dead disc? or disc reader? also why woulf turning the tv off help? did the wii overheat? or anything strange?
Apr 05, 2010 | Nintendo Wii Console
Ive got a 29'' tube flatscreen that wont work no more
seems to be an issue with picture tube.Please try after changing picture tube
Jul 28, 2009 | Televison & Video
Samsung TTB 1320 Picture Tube worth replacing?
Toss it Even if the tube is not broke chances are it will cost to much to repair and chances are even greater the metal part of the tube, (called the shadow mask) is warped and you will never get good color on it again I have been in the tv service business for 40 years and have not replaced picture tube for the last five years.
Feb 07, 2009 | Hannspree (K206-10U1-005) Television
No picture, but power light is on
THE POWER SUPPLY OF YOUR TV WAS THE PROBLEM,YOU COLD SOLDER THE MAINBOARD OF YOUR TV,AND THE CRT SOCKET CONNECT TO THE TUBE IS ALSO COLDSOLDER,.
Mar 13, 2008 | RCA 27F530T 27" TV
No picture or sound
If you had a burning smell, well the board is toast. These sets are made to replace the entire board at one time. Before installing the replacement module, the picture tube should be checked. A defective picture tube ( such as a G1 short) may cause a failure in the power supply section.
Sep 07, 2006 | Zenith C32V36 32" TV
Tv wont turn on
That same thing just happened to my t.v. The repair person will be here on 10/10/06. I will let you know what they say.
Aug 22, 2006 | Mitsubishi WS-55511 55" Rear Projection...
Televison & Video Logo
279 people viewed this question
Top Televison & Video Experts
Ekse
