Question about Motorola Mobility H700 Wireless Headset
H700 i have a raz 3 and i cant get the phone to reconize the h700 what can i do?
  • Anonymous Dec 05, 2007
    well not rec h700 but will to the h500 old one delete everything
Thank you for your help. I was getting very frustrated trying to pair my new Bluetooth with my Nokia 6126. I'm all set now. You're a lifesaver!!!!!
Posted on Jan 18, 2008
    Genius:
  • 1,003 Answers
Go into menu on your phone look for bluetooth option and enable (turn on) .
Then press and hold down hook button on our headset (button with phone lcon on it) until headset light stays on solid (not flashing) your mic should still be folded in now quickly fold out mic (indicator light should remain solid now began to pair your device to phone by selecting connections in cell phone menu.
you should select add device from menu phone will now search for device when the name of your devivce shows in phones display select yes to bond device as phons bonds with bluetooth headset the light on the headset will flash confirming the bond was completed the phone will prompt you to input a password tye in 0000 then phone will activate are headset is ready to use
Posted on Jan 16, 2008
SOURCE:
How to use my H700 after charging ?
If tv is bluetooth capable, look under menus and pair with H700.
Phones if initially paired will simply need to have bluetooth 'active' (as by default it is usually off). - If not pair - you will need to go through menus under 'settings' to pair with the H700 (also at this point indicate that the H700 is 'trusted device').
Nov 25, 2014 | Motorola Mobility H700 Wireless Headset
I have a Motorola H700 but I dont have the guide and would like to hook it upto my new cell phone, PalmPre. I cant find a user manual online.
Thank you for visiting Fixya!
You can view the User Guide to your Motorola H700 at the link below. It's in PDF format. If you need a PDF reader you can download Adobe Reader for free:
H700 User Guide http://tiny.cc/fiy6G
If you found this information helpful, please give me a big thumbs up when you rare my answer. Thank you.
Jan 27, 2010 | Motorola Mobility H700 Wireless Headset
H-700 motorolla bluetooth
1. Bluetooth enabled?
Hold down the connect button on headset until steady purple light comes on, then open the boom.
Search for Bluetooth devices on the phone. When asked for a pin, use "0000". Now the H700 will show up in the Bluetooth device list, but it will not connect. Put the headset in pairing mode again, this time go to the h700 listed on the phone and select connect. Now the devices will work as normal. When you open the boom on the h700, it will connect to the phone.
Dec 19, 2008 | Motorola Mobility H500 Wireless Headset
Motorola bluetooth pairing
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H700 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Aug 09, 2008 | Motorola Mobility H700 Wireless Headset
Can't get my phone to pair with my blue tooths. I have two.
i have a sidekick lx and cant connect my bluetooth h700 can you help me.
May 26, 2008 | Motorola Mobility H700 Wireless Headset
Need a passkey lost it
The problem you are having with your H700 is not the passkey. "0000" is correct. The problem is the pairing process. I just paired mine after reading this with my blackberry curve.
1. Close the H700.
2. Hold the big button down until you see a lavender light.
3. Open the H700 while still holding the button down.
4. At this point it is ready to be paired. If the light changes color, the H700 has timed out waiting to be paired and you will have to do steps 1 thru 3 again.
5. With the lavender light on the H700 go through the pairing procedure on the blackberry.
Mar 21, 2008 | Motorola Mobility H700 Wireless Headset
Reg: H700 connection with sony ericsson 580i
You may have to get a bluetooth headset specifically used with Ericson or change bluetooth setting on your cell to handsfree
Jan 08, 2008 | Motorola Mobility H700 Wireless Headset
Bluetooth
I've noticed the same problem if I don't have the headset open. Try flipping the mic open, then pair it. Hope that helps.
Nov 07, 2007 | Motorola Mobility H700 Wireless Headset
How to do pairing
Thank you. I called a 1-800 number for tech support but they told me I had to wait 14 days from the date of purchase before they could help me. Your suggestion was right on the money. Thank you.
Jul 18, 2007 | Motorola Mobility H700 Wireless Headset
Help needed in paring my H700
In order to pair with this device you must follow these steps: 1. Close the mike on the H700 2. Hold the center call button on the H700 until the ring in the center turns violet. 3. Open the mike on the H700 4. Have your phone search for bluetooth devices and follow the propmts 5. If your phone requests a passkey, enter 0000 This is the default for all Motorola devices Hope this helps.
Apr 01, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
112 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
