Question about Compaq MS Pocket PC 2002
Cant git pass the align screen on my hp2215 ipack
  • 1 more comment
  • trayy07 Dec 01, 2007
    cant git pass the align screen on my hp2215ipaq
  • Anonymous Dec 20, 2007
    i have compaq ipaq 3870. when i soft reset then a message promt that "tap the target firmly and accurately at each location on the screen. The target will continue to move untill the screen is aligned". and a cross sign is appeared and runs under the screen area when i click any where on the screen. kindly suggest me what should be the step that can help me to solve this problem.
    thank you
    ratan
  • EdwardOX Dec 21, 2007
    I have the seminar problem, pass the align screen, and get to pop-up menus, then stuck for ever. Tried hard start several times, no sucess. it seems the operating system is damaged... not sure
I have Toshiba e 350. when i hard reset it, it stuck onpop-up menus after the align screen. I ahve tried several times to hard reset it, it came out the same. kindly suggest me what should be the step that can help me to solve this problem.
It seems to me the operating system is damaged, anywhere to re-install the operating system?
Thank you
Edward
Posted on Dec 21, 2007
    Sergeant:
    Champion:
  • 317 Answers
Have you tried a Hard Reset?
This should get you through it but you will lose all of your info.
Information is here:
http://www.coldreset.com/modules.php?name=News&file=article&sid=713
Hope That Helps!
Posted on Dec 10, 2007
Cant get the color on my tv there is a dark screen and i have volum
Ya screen has blow most likely, to much to fix so may as well git yerself a new telly fer xmas.
Nov 17, 2017 | Televison & Video
My timing belt broke while i was driving..i tried to align cam , oil pump and top . i just cant get them aligned perfect..i git the top and bottom good . i started truck and it runs like pooo. can the...
When a timing belt breaks engine components tend to all come together doing alot of damage. valves bend and pistons get damaged. this usually means rebuilding the engine.Valves heads and pistons.
Jan 30, 2011 | 1996 Ford Ranger SuperCab
My i-mate pocket pc screen does not get aligned
Hi. You should tap the screen with the stylus carefully and with a little bit more pressure, accurately on the cross sign evertime it appears. When you successfully tap each cross sign once, you would be able to pass to the other settings, but in case there is a problem passing though the screen aligning, here is a small tutorial about how to bypass that screen through your PC: (http://goatechno.blogspot.com/2008/12/windows-mobile-stuck-at-screen.html) Hope this helps.
May 27, 2009 | i-mate Pocket PC
I cant get it to work!!
May 24, 2009 | Acer n35 Pocket PC
Axim x5 Won't get passed alignment screen
I've heard some keep aligning and after a time it eventually works. 200 to 300 times.
I tried 7 then took the advice of a techie that said to gently twist it like wringing out a wet rag. Put hands on the top and bottom and gently twist back and forth.
It worked for me.
Be gentle
Apr 18, 2009 | Dell Axim X5 Pocket PC
Pass the align screen
Hey :), id be happy to help. You see, I too have a Ipaq except I had Ipaq 4350. Now, I too had the same problem you are having. The reason why you can't pass the align screen step is because somehow you have damaged your screen. And I have come to the conclusion that HP Ipaq's screen is extremely sensitive, ( because I never did anything that bad to my screen for it to be damaged) soo I'd recommend for you to call HP and see if they can repair your problem or give you another one. Thank you and I hope this helps!
Sep 03, 2008 | HP iPAQ H2210 Pocket PC
Broken lcd screen
git one from ebay for $10 and do it yerself. Easy to do and save yerself some $$
Jan 06, 2018 | Samsung SPH-a800
Ipaq RX 3115 Stops at align Screen
solia, I'm sorry, I didn't mean to close the chat session on you.
Is your unit still under warranty? If so, check with the manufacturer.
They can help.
Mike
Sep 27, 2006 | HP iPAQ RX3115 Pocket PC
Computers & Internet Logo
173 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
