Belkin F5D8631-4 Router
Problem for Belkin F5D8631-4 Router (F5D8631au4A)
CONTINUAL DROP OFF OF INTERNET
By birdjonesg on Aug 16, 2009
Continual internet drop off
Solution #1
posted on Aug 16, 2009
Not Rated)
redhaze89
Rank: Guru
Rating: 85%, 207 votes
Getting an intermittent wireless connection can be attributed to the following factors:
a. 2.4 GHz wireless interference
b. Wireless settings of your router
c. Location of the devices
d. Obstacles
You may also refer to the common causes of interference:
Window in brick wall 2dB
Metal frame, glass wall into building 6dB
Office wall 6dB
Metal door in office wall 6dB
Cinder wall 4dB
Metal door in brick wall 12.4dB
Brick wall next to metal door 3dB
In order for us to isolate the problem, please refer to the steps below:
1. Avoid obstacles.
a. Try to move the router to different locations in order to get better connectivity. We suggest placing the router on high location to avoid obstacles that may be blocking the signal.
2. Reduce wireless interference in the area.
a. Try to move the router away from devices that are operating on 2.4 GHz frequency like your cordless phones and microwave ovens.
b. Try to move the router away from windows. Windows let in interference from the outside world.
3. Adjust the wireless settings on the router.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. For security reasons, the router has its own username and password. When prompted, enter admin for the Username and password for the Password, both in lower case letters.
Note: If it doesn't take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you can't remember the password, you need to reset the router and run the Setup CD to reconfigure it.
d. Click on Wireless Settings under Setup tab.
e. Change the Network name or SSID to your preference.
f. Change the Mode to g and b only.
g. Change the Channel to 11, 1, 6 or 9.
h. Click on the Apply button.
i. Reconnect your computer to the wireless network and see if it fixes the problem.
Note: If the problem persists, you may need to upgrade the firmware of the router.
4. Upgrade the firmware.
a. Please verify the router version and model either underneath or at its side panel.
b. Go to http://kbserver.NETGEAR.com/downloads_support.asp and please select the model of the router.
c. Click the appropriate version of the router.
d. Select the link of the latest firmware. Click the button Right-click and Save to Download. Save the file to the Desktop.
Note: Please perform firmware upgrade with wired or Ethernet connection only. If your computer has wireless connection, then please disable it first.
e. Before upgrading, please write down all current settings since you need to enter them manually.
f. Using the computer hardwired on the router, please access the router’s setup page again by going to http://192.168.1.1 or http://192.168.0.1 or http://192.168.2.1
g. Click on Maintenance and then Router Upgrade.
h. Click on Browse and locate the upgraded file in your Desktop. Then click on Upload.
i. Please wait for the router to reboot.
5. After a successful firmware upgrade, you need to reset the router.
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
Note: Resetting the router will erase all the settings so it needs to be reconfigured afterwards.
The router can be reconfigured using the setup CD or by manual configuration.
Was this helpful?
Yes
No
Popular Solutions for Belkin F5D8631-4 Router
Questions and Unsolved Problems for Belkin F5D8631-4 Router
Do you recommend Belkin F5D8631-4 Router (F5D8631au4A)?
Answer
Answer
I update my Dell Studio Desktop from Vista to Window 7. Now I cannot get an Internet connection... (More)
Answer
I have a F5D8631-4 Router which works extremely well for the 3 computers in the house. I cant seem... (More)
Answer
my router started it too, just recently. my computer seems slower as well. is it getting hacked?
Answer
i hv just bought a new belkin wireless router, i hv followed all the instructions and did my best to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Routers Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
