Question about Zeiss CONQUEST 3-9X40 MATTE Z PLEX
Zeiss 3 x 9
I have a zeiss scope that needs to go a repairefacitity. It has been dropped. It is difficult to adjust power setting, Can you provide a contact number here in USA?
Thanks,
Briscoe
email is:[email protected]
  • 22 Answers
Gusbear, here is the whole shebang. document.write(mdec('c#6#8#9#5m#3r#0#8#3rv#7c#3#1v#7#8#7#5#4#0z#3#7#8#8#0c#5m')) [email protected] this is for their sandiego offices
Carl Zeiss Optical, Inc., Chester document.write(getAddressCountry('US','USA')) document.write(t_phone) Phone: +1 800 441 3005
document.write(t_fax) Fax: +1 804 530 8333 zeiss 3 x 9 - form.gif document.write(t_inq) Inquiry
document.write(mdec('#8p#5r#9#8#5p#9#7c#8#1z#3#7#8#8#0c#5m')) [email protected]
external_link.gif www.zeiss.com/sports
this is for the sport optics contact you are looking for. give them a ring or drop a line, they should be able to help you out.
Posted on May 06, 2008
SOURCE:
Zeiss conquest parallax knob slips
Zeiss has a lifetime warranty on their conquest line. Contact Carl Zeiss Welcome ZEISS United States
Nov 15, 2014 | Zeiss Conquest 6.5-20x50 Hunting Turret...
Zeiss diascope coarse adjustment
sounds like you lost the locking Allen screw.
need that to sort your problem.
Jul 11, 2008 | Zeiss 528013 / 528015 Diascope 85
Visibility at Dust and Dawn
That is quite surprising because Zeiss makes very good scopes and the optical quality is quite exceptional. You are an experienced hunter and you have other scopes to compare, so I believe that things like checking to be sure that a lens cap is removed has been checked. If you need service you can contact an authorized dealer such as http://www.rcsoptics.com/zeiss-scopes or http://www.zeiss.com alternately you may call Zeiss direct at 800-441-3005
Nov 20, 2013 | Zeiss Optics
Owners manual for conquest 3-9 40 ziess scope
Sound like you are looking for an owners manual for a Zeiss Conquest scope? Check out RCS Optics, they are an authorized dealer for Zeiss and have free downloads here:
Zeiss Conquest Scope Owner Manuals
Hope that helps out!
Sep 30, 2013 | Zeiss Optics
How do you adjust the sights on a zeiss 3.5x10x50 rapid z 800
You will not detect any changes as you view through the scope. Only the impact point on your target downrange should change.
Jan 25, 2013 | Zeiss Optics
I shot my new 4.5x14x44mm conquest scope and tried to adjust the cross hairs according to my shots fired but the shots kept hitting in the same spot after a box of shells. i had it bore sited and i still...
Is the country of origin China.. Sounds like the reticle is stuck,, like from being dropped maybe in shipping. OK, Without any adjustments made shoot it one time, if you tap on the side of the scope, not the top of the turrets with a plastic/rubber hammer and point of impact changes (jumps) its faulty.. you cant fix it.
Feb 28, 2011 | Zeiss 4.5-14x44mm Conquest Target Rifle...
Will the zeiss BDC turrets fit a diavari z 3-12x56mc scope=what year was this scope made/can't find anything about it
Try contacting Zeiss directly at:
ZEISS Customer Service Contact Carl Zeiss Sports Optics – from anywhere, anytime. Whether you have a general question about ZEISS products or specific service needs, we're here to help. ecblank.gif ecblank.gifOnline
Complete this form to submit your request online!
Customer Inquiry Form
Email Us
Send your comments, questions, or suggestions to us via email at[email protected].
Call Us
If you have questions, call a Customer Service Specialist at
(800) 441-3005.
Write Us
Mail your questions, comments, or suggestions to
Attn: Customer Service Department
13005 North Kingston Avenue
Chester, VA 23836-8333
Hope this helps, Mark the Gunsmith
Please leave feedback, Thanks!
Jan 09, 2010 | Zeiss Optics
Adjustment Issue
the scope should all ways be fitted with the wind adjustment on the right as you look down the rifle, therefor the top ajuster is for up/down,
right ajuster is wind,,left/right, the easy way to set it up is to aim at some sand with the rifle on a stand or in a jig, shoot one round see were it hits and without moving the rifle, turn the turrets till the cross is over the point were the bullet landed, having a pall to move the turrets for you helps a lot here, the main point is dont move the rifle till the turrets have been moved first,, its that or bore sight it,,, jig the rifle up pointing at a target at say 200yds look down the bore aim the bore at the target lock down the rifle check it by looking down the bore again then set the cross up in the scope on what you see down the bore
you will need to tweek the scope a bit as you havent taken the bullet drop into the ajustment that way,,
Dec 17, 2009 | Zeiss 3-9x40mm Conquest Rifle Scope...
K98 scope
K98's were fitted with a Hensoldt ZF4 or ZF6 if you want a WW2 purist type of rifle. Hensoldt are part of Zeiss. Zeiss market their military scopes and binoculars under the hensoldt name. You can pick these up second hand for around 500 US Dollars.
If you are fitting a scope for shooting purposes, one with variable magnification is a good choice but you won't need a higher power than 10. Non variable a 6 power is more than adequate for the K98. Leupold have a wonderful range of tried and tested scopes in various price ranges. If you don't mind spending more than a thousand dollars on a scope Schmidt and Bender make magnificent scopes, some of which you will find attached to US Military sniper rifles.
There is a lot of choice with a lot of difference in price. Too cheap a scope will not be able to handle the recoil of the K98 and you will find yourself constantly adjusting it.
Aug 16, 2009 | Weaver Uag Mauser K98 K-98 Scout Rifle ...
New Zeiss 2.5-8 Conquest MC Riflescope. Elevation clickstop adjus
Tried google for zeiss rifle scopes I just did and see they have a suport division...try there and get it from the horsies mouth!!!
Jun 07, 2009 | Conquest Zeiss 3.5-10x50 Mc Rifle Scope :...
Zeiss CONQUEST 3-9X40 MATTE Z PLEX Logo
261 people viewed this question
Top Zeiss Optics Experts
Inky Fingers
Inky Fingers
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Zeiss Optic Expert? Answer questions, earn points and help others
