Back to:
Tags:
JVC KD-AVX33 Car Video Player
How do i bypass the emergency brake wire on a dual... (by 7 users)
posted by 1badv6 on Dec 01, 2007
i am hooking up a dual xdvd700 in dash dvd player in my 2001 dodge ram 1500. how do i bypass the emergency brake wire so i can play a dvd at anytime.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
6 Other Users Have The Same Problem
Comment by Guest, posted on Oct 08, 2008
i have a 01 dodge neon with a xdvd700 and i have tryed everything and with the wire and the main ground hook up worked after i trun it off and back on with the car running how do i fix that?
Comment by ChadW, posted on Jun 23, 2008
i have a 1994 lumina Z34 and i have a Dual XDVD8181 and i can't figure out how to bypass the e-brake so i can watch dvds while i'm driving
Comment by Guest, posted on May 06, 2008
me too
Comment by mystyle, posted on Feb 12, 2008
I have the same problem but heres the goofy part, i stripped the wire bare and connected it to the connection prong of the brake sensor and then i disconnected the e-brake it worked fine, then after the ignition was turned off the next start it had the blue screen i released the e-brake then reset it and it worked for 3 days with out a problem then today at work i went to leave and had the blue screen and wouldn work no matter what i did then when i got home i cut the yellow e-brake wire then spliced into the sensor wire and nothing, this set up is pissing me off, im going to try this switch crap and see how long that last if at all.
Comment by chrissr, posted on Jan 12, 2008
How do I override the ebrake switch on my duel xdvd700?
Best Solution
posted on Aug 27, 2008
FixYa! (100)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Guys, the solution is staring you straight in the face.
Take the ebrake wire coming from the stereo, and attach it to the screw off nut on the rear of the stereo case to earth it.
Thats it.
Job done.
Cant believe no one tried that - took me 2 minutes to figure out.
Hope this helps :-)
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on how do i bypass the emergency brake wire on a dual xdvd700:
I don't want to Accept this solution
Solution #2
posted on Apr 10, 2008
FixYa! (100)
K_faudio
Rating: 95%, 3 votes
Play a dvd until you hear a sound. Then press stop twice. Last enter 26604 and press enter. That will solve your problem.
Thank You!
Solution #3
posted on Jan 24, 2008
FixYa! (100)
Guest
Rating: 0%, 0 votes
Ummmm that sounds retarted. Just ground the wire with a seperate ground or splice it with the home ground
Thank You!
Solution #4
posted on Jan 29, 2008
FixYa! (100)
Guest
Rating: 0%, 0 votes
just go to ground not the brake wire.
Thank You!
Solution #5
posted on Jan 13, 2008
FixYa! (100)
willcorg
Rating: 88%, 6 votes
1: Go into AM/FM mode
2: Hit "setup" on the remote control
3: Enter 543210 on the remote, listening for the beep for each number entered
4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen.
5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen.
works for my 02 dodge ram cummins
Thank You!
Solution #6
posted on Jul 21, 2008
Helpful (85)
Guest
Rating: 0%, 0 votes
e brake senor on a f 150
Thank You!
Solution #7
posted on Sep 06, 2008
Not Rated (0)
RedRum86
Rating: 70%, 1 votes
Just ground out the Ebrake wire... it will work fine then. Even if you just link the ground and ebrake wire together and ground them together it works!
Thank You!
Solution #8
posted on Aug 18, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
Basicly just get a wire from the negitive part of the battery though your firewall and connect the yellow/blue wire to it, You dont need no codes or nothing just pop the dvd in or music video and SHIBANG its there.
Thank You!
Solution #9
Not Rated (0)
Patrin
Rating: 0%, 0 votes
I'm not an xdvd700 owner, but I think, that connection e-brake wire to ignition wire in ISO connector directly will solve this problem. This helped me with JVC KD-AVX33.
But think about your safety :)
Thank You!
Solution #10
Not Rated (0)
chrissr
Rating: 85%, 2 votes
Install a toggle switch between the yellow ebrake wire and a chassis ground then when you turn on the unit when it goes to the blue screen turn the switch on then off 3 times leaving it on on the 3rd time and you'll be all set the dvd player will play while driving.
Thank You!
Can you Help with these Car Video Players problems?
Sudently my AVX33 shows all the movies with no colors,...
In the JVC KD-AVX33 manual, page 31 they wrote: "You...
I have tried other phones from nokia and samsung and they...
Hi, all I'm using my KD-AVX33 for a year. Everything...
Hi! Can anybody help me with circuit board for KD AVX33,...
6 Other Users Have The Same Problem - Continued
Comment by player101, posted on Jan 10, 2008
it well not work and im mad
Loading problems.
Repair Service
Find Car Video Player Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
