Question about Optics
Its hard to crank my gammo swarm air rifle, twice it cranked okay but now have to use a lot of strength to get a single shot.
SOURCE:
  • 31 Answers
SOURCE: does not hold air to shot
try oiling
Posted on May 15, 2009
  • 3 Answers
SOURCE: Hard starting Chev 2500HD 8.1 L
i have had the same problem.the solution is the fuel pump! i know you got pressure and it runs so how can it be the fuel pump? the pump is losing its prime you are getting pressure just no volume thats why its crank off crank off the system is priming itself again kinda like a weedeater or similar motor fuel is there just not enough of it to the injector To check this hook a pressure gauge turn on key turn off key release fuel should be plenty but if tis just a few drops thats it hope this helps
Posted on Jun 09, 2009
bigcass
  • 35 Answers
SOURCE: need bolt for Springfield model 120 single shot
Gun-Parts.com Carries it, but looks as though re currently out of stock.
But it looks as though Numrich has it. As well as an "Exploded" parts list for ya.
Park Number 103950A Price: $37.25
Hope this helps.
Posted on Oct 16, 2009
dontbother10
  • 2220 Answers
SOURCE: Hard to crank,even with muffler and air filter
Starter Handle difficult to pull:
1. Was this saw perhaps operated in a lean condition (metal transfer from the piston to cylinder wall)? This may be caused by many things including but not limited to; leaky intake connections at the engine or carburetor; leaky crankcase seals; cracked fuel delivery lines; running on gasoline containing no 2-cycle oil.
· Disconnect the spark plug wire and remove the plug. Remove the muffler (clean it and the spark arrestor before reinstalling), hold a light at the plug hole and inspect the cylinder through the exhaust port. Is it smooth and shiny or does it appear speckled with dull gray spots or smears?
· Pull the starter slowly, inspect the piston as it rises and falls. Is it a dull gray without scratches and gouges?
· Hold the light at the exhaust port and look through the spark plug hole, inspect the cylinder above the exhaust port. Is it shiny and smooth or speckled with gray spots or smears?
Any spots or smears on the cylinder or deep scratches and gouges in the piston indicate the saw was operated in a lean condition. Repair of this on a home owner quality saw often exceeds replacement cost. A repair estimate by an independent saw shop should be considered.
2. The last likely possibility is the saw has jumped timing. Remove the starter cover and verify the flywheel and crankshaft keyways are aligned.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 24, 2010
daryl441918
  • 1280 Answers
SOURCE: I am trying to find
perhaps this website will help you if you follow the steps:
http://aaa-webs.com/aaa/webs/homestead/courses/RemingtonModel4/
Posted on Nov 29, 2010
I have a BSA point 22 carbine air weapon circa 1990. Could you tell me what the name of the carbine is?
Hello Jean
It is likely to be a BSA Meteor or a BSA Airsporter. I am from Birmingham UK and owned one.
Here are a number of links for you which will help identification. I will put the Google link at the very bottom of the post which lists a lot more info. Write back as a COMMENT below my post if you need any further help. I am one of the air weapon experts.
  • 1990's Air Shot Corp./BSA Catalog, Vintage Gun Catalogs www.vintageguncatalogs.com/product_info.php?products_id=57 Circa 1990 Air Shot Corp./BSA Catalog,8-1/2" x 11" with 6 pages Content: ... Air Gun Catalogs. Air Arms; Beeman; Benjamin; Brno; BSA; Crosman; Daisy; Feinwerkbau ...
  • History & Ethos ' BSA Guns - BSA Air Rifles bsaguns.co.uk/about/history.aspx BSA Guns; History & Ethos; Production ... 1962 Introduction of Merlin air rifle; 1962 Introduction of Armatic .22 self ... and Airsporter Carbine air rifles; 1990 ...
  • BSA - John Knibbs International Ltd - Airgun Spares www.airgunspares.com/store/content/87/BSA Superstar .22 : 1990 - 2004: R22: R - 10 MK1 .22 : R77: R - 10 MK1 .177 : ... BSA Standard No2 Air Rifle .22: 1936 - 1939 : T: Ralock Self Loading Sporting Rifle .22 ...
  • BSA .22 Air Rifles and Pellets ' Wonderland Models https://www.wonderlandmodels.com/bb-air-guns/air-guns/rifles/bsa BSA .22 Air Rifles and Pellets. Wonderland Models are an Online Model Shop specialising in BSA .22 Air Rifles and Pellets and ... BSA Rifles Meteor Evo Air Rifle.
  • JC Militaria ' Air Weapons www.jcmilitaria.com/air_weapons.asp?Start=10 At JC Militaria we stock a number of Air Weapons. ... 22 Calibre Bolt Action Single Shot Air Rifle ... BSA launched a centenary air rifle to ...
  • BSA Air Rifle Combinations - The Airgun Centre https://www.theairguncentre.com/rifle-combinations/bsa BSA Guns are at the cutting edge of Air Rifle design and manufacturing and have a history going back over 150 years.
  • Blue Book of Airgun Values - BSA GUNS (U.K.), LTD. RIFLES ... bluebookofgunvalues.com/Airgun_Values/Airgun_Manufacturer_Models... ... LTD. RIFLES: MODIFIED REAR/UNDER LEVER COCKING airgun ... RIFLES: MODIFIED REAR/UNDER LEVER COCKING . ... faucet tap loading, Marked: "THE BSA AIR RIFLE ...
  • http://www.bing.com/search?q=BSA+22+air+rifle+circa+1990&FORM=HDRSC1
    Jul 05, 2016 | BSA Optics
    How do i mount my 650 laser sight to my bone collector rifle.
    Red Laser Sight 650nm Weaver rail mount - Gamo USA
    www.gamousa.com > Optics > Airgun Lasers and Lights
    650nm Red Laser Sight with Weaver style rail mount.
    Gamo airgun accessories, spare parts and products ' Gamo ...
    www.gamousa.com/category.aspx?catID=4
    Air Rifle Scope Mounts/Rails. Air Rifle Scope Mounts/Rails. Air Rifle Sights. Replaceable sights for air rifles. Air Rifle Spare Parts. Replaceable parts for air rifles.
    Dec 25, 2015 | Laser Optics
    Need Rossi 243 single shot rifle sights
    gunsmith is the only place I KNOW
    Feb 18, 2015 | Optics
    Gammo pellet rifle cocked and will not fire
    Check to make sure the safety is not on. Check for an obstruction in the trigger mech. Check to ensure that the barrel is locked closed.
    Nov 28, 2013 | Optics
    I need your expert advice. I live in Katy Texas and house backs up to the largest park in this part of texas. We have larger game animals but my problem is I am being runover by larger varmits. ...
    WalMart carries a nice 22 caliber air rifle by Crossman. They also carry the 22 caliber pellets. 1200 fps for this rifle should take care of your varmints.
    Dec 13, 2010 | Optics
    I have a Beeman air rifile that I think is the greatest thing since sliced bread. I has taken down ground hogs at 50 yards. The rifle has a 4-14x56 Accushot scope mounted on it. When the rfile is working...
    Unfortunately air rifles are hard on scopes due to the recoil...Suggest replacing the scope with something more of a brand model , like Bushnell or something like that..
    Nov 07, 2010 | Beeman Optics
    2002 ford taurus won't start at first crank in the morning
    remove the air filter housing from the throttle body, or if its mult-ported injection, remove the large air duct. Do this the night before. The next day, before cranking and having a spray can of carb. cleaner, spray a couple of shots of carb cleaner either into the large air duct, spray towards the engine, or if its single body injection, spray directly on to the throttle body.
    Crank engine immediately, preferrably have some one else sitting in the car to start it after you spray.
    If the car even tries to start, replace cold start relay.
    Nov 22, 2008 | 2003 Ford Taurus
    Optics Logo
    18 people viewed this question
    Top Optics Experts
    Marvin
    Marvin
    james laughton
    james laughton
    ray gallant
    ray gallant
    Are you an Optic Expert? Answer questions, earn points and help others
