Mitsubishi WS-65807 65 in. Rear Projection Television
Problem for Mitsubishi WS-65807 65 in. Rear Projection Television
NO Sound
By Bigg Sterl on Dec 01, 2007
Have no sound, my email address is biggsterl@bellsouth.net
Same Problem
Jan 02, 2008
-   Hi, I just experienced the same problem with the same TV for New Years Day-- what a bummer-- I have no sound what so ever, even when I disconnected all of the other equipement and just had the tv hooked up to the cable wire. It was working fine the other night then today no sound at all. I have gone into the menu screen and tried to adjust the audio from SAP to surround sound it looks like it takes the new adjustment, but when I go to the info button it shows ant A, and SAP. I read in the manual that having the audio set to SAP could be the problem, but the adjustment just doesnt take. I have also done the reset. So now what do I do, any ideas on how much this is to fix and if it is worth it?-   Guest
Solution #1
posted on Dec 26, 2007
Not Rated)
brainded
Rank: Guide
Rating: 100%, 1 votes
Sorry, you need to try and add some more detail to the problem. It could be anything from a bad connection however your TV is setup or the speakers died.
Things you could answer to help, does sound work on any source, or does it only not work on one in particular? What were the circumstances around it? What changed around the same time? Have you tried resetting the tv to factory settings?
Was this helpful?
Yes
No
Popular Solutions for Mitsubishi WS-65807 65 in.
Questions and Unsolved Problems for Mitsubishi WS-65807 65 in.
Do you recommend Mitsubishi WS-65807 65 in. Rear Projection Television?
Answer
Answer
The picture is not aligned on the both sides of the tv. The middle seems fine it's the two sides... (More)
Answer
has lines across the whole screen and black isnt dark enough
Answer
when I use my xbox on the tv and the tv is set to 1080 picture is cut off !!
Answer
all colors are good except for the blue green! things that are blue looks green
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
