Question about Magellan RoadMate 700 GPS Receiver
Power problems and ......
Hi and thanks to any help you can give me...Power stays on for 5 min or less than cuts out...Have changed the fuse in the cig liter...The map does not move to current location when it stays on for that few mins...
  • 1 more comment
  • natekerr Dec 02, 2007
    Have the Roadmate 700 about 3 years. For the last 3 months, the unit will just power off while in motion. Most times it will not come back on unless I pull the cord from the cigarette light and put it back in. Sometimes that doesn't even get the unit on. Sometimes it powers on by itself and just turns off again. The green light on the cord remains on even when the unit goes off so I assume the lighter in my car is fine. Get this. I called Magellan. The customer service rep (in India) told me to tape or use a rubber band the cord tighter to the base unit that it sits in as a solution. Should I replace the cord or the unit?
  • johnklay Dec 11, 2007
    my power flickers on and off but then stays off
  • Anonymous Feb 01, 2008
    similar problem, my Roadmap 700 is about two year old. After it is on about two minutes the it goes off, screen is off. After few minutes, it can be turned on again, then off after couple minutes. Power from either house plug or car plug has the same problem. So the problem is not at the power but within the roadmap.
I had same problem and replaced the power cord. Now it works fine.
Posted on Feb 09, 2008
    New Friend:
  • 24 Answers
All these problem will arise when the cradle becomes faulty.
Cradle will be at the backside of the unit.Where you plug the unit .When that particular cradle becomes faulty means the unit will turns off automaticly...So to over come this problem just replace the cradle the problem will be resolved .......
Posted on Feb 03, 2008
SOURCE:
Hotpoint tcl780g overheating and cutoff after 5 min.
Disconnect dryer vent and run dryer. If runs/heats normally clean out your vent.
Apr 15, 2014 | Dryers
Dead
Better to pull up the error codes. Following areas can also be checked:
1. Fuel pump control circuit
2. Electronic throttle control system
3. Immobilizer
4. Crankshaft position sensor circuit
5. Short circuit.
7. ECM.
Feb 27, 2014 | Toyota Prius Cars & Trucks
I reversed polarity on my jumper cables and blew the main fuse on my 2010 main fuse...what do I need to do?
hello
Prius2 is not powering up after one person swapped ower polarityof battery while changing it. We changed Big fuse at the front of the car and couple of small fuses. Now when pressing power button we have engine light and power button orange light fore just one sec. After it just stays dead. While pressing power button you can hear couple relays clicking for a sec and dc to dc giving hi frequency noise for the same amount of time. Help us please. This prius was manufactured in 2003. Many Thanks
Sep 29, 2012 | Toyota Prius Cars & Trucks
I have a whirlpool fridge/freezer which after a power cut will now only register 7 on the freezer, although still seems quite cold. How can I get it back to -18 ? Thanks
If the power loss was for 5 mins of less.... just unplug it for 20 mins and plug it back in. The compressor is probably "High side cycling" and the thermal overload is tripping on the compressor every 4 - 5 minutes for about 40 seconds. Unplugging it 20 minutes will allow the coolant system to stabilize and the compressor to re-start.
Kelly
Apr 28, 2011 | Whirlpool Refrigerators
GE A730 camera cuts off
Hi doctech:
Turn on the camera, then go to the menu and set the time to shut off to 5 or 10 min. These settings are usually set to 2 min. or less. This setting is to let the camera "go to sleep" or simply shut down to save battery power.
You can also try the following:
Go to the set up menu, find the RESET ALL and reset all the settings to factory.
Then go back to the setup menu and set the setting as you want them making sure to set the shut off time to more than 2 min.
Sep 27, 2008 | GE A730 Digital Camera
Over heated hover
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=632385
Generic problem for all Vacuums
Over heated hover
Posted by blade123 on May 29, 2008
Hi there, I’ve got a upright Hoover and it cuts out after about 5 mins I think it’s over heated but if i leave it for 5 mins it works again but cuts of again how can i fix it?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It is possible that you my have a heat sensor, but as far as what you described you need to change both belts, the brushroll belt and the power drive belt as well and @ the same time. The average belt change is every 4 to 6 months on the vacuum. Does it stop completely or is it just the belt problem. Or #2 is the vacuum giving off a burning smell other than the belts and if it does it could be the motor. Other wise , please call the factory or a local Hoover warranty station in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 29, 2008 | Vacuums
Sony KV32s22
Hi: Sounds like it might be an overheating part, and the short is shutting of the set. Or it could be an intermittent connection in the pc board. Either case it would have to be repaired by a expert.
sorry.
Mar 11, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Power
this unit has a control board problem it is less expensive to get a new unit than it is to have it fixed
Nov 18, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Tv cuts off and on.
Sounds like a bad SSB(small signal board) module. Better take it to a RCA AUTHORIZED service center.
Sep 06, 2007 | RCA D56W20 56" Rear Projection Television
Magellan RoadMate 700 GPS Receiver Logo
Top Magellan GPS Experts
Marvin
Marvin
Ekse
Are you a Magellan GPS Expert? Answer questions, earn points and help others
