Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
2003 road king fuel injected
The bike runs great,within the past 2wks the bike starts out running fine,
then out of know where seems when i accearate it boggs down like not getting fuel...in the last couple of days after starting the red engine light
will appear, then goes out..engine light has never came on before after starting engine...could it be vacume control censor? where is it located??
hard to start after running...
thanks,crazy keith
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 221 Answers
The light should come on when you first turn the ignition on four four sec.then go out and if it comes on again this means you have a trouble code. to get the code you can hold in the speedometer reset button and turn on ignition swicth and use reset button to move curser
Posted on Dec 31, 2009
SOURCE:
2003 annv. roadking...starts and runs fine with a full tank of gas...when it gets to half a tank its hard to start and stalls at stops.
If this is the model with a fuel tap you in tank filter is blocked. If you have the injected model you fuel level switch is faulty
Sep 04, 2014 | 2003 Harley Davidson FLHRCI Road King...
I have a 2002 Road King , fuel injection and having issues with the starting. Seems if the bike sets overnight its hard to start. Takes about 3 or 4 times to start. Once started it runs like its not...
Check fuel pressure .. when you have 1/2 tank do you hear a hiss check w/ cap off..the plastic line in tank gets a hole in it from rubbing replace line from pump to tank outlet.. This is what i have heard.. For more help go to harleytalking.com the have helped me good luck ';';';';
Jun 23, 2011 | Harley Davidson FLHR - FLHRCI Road king...
02 road king fuel problems have a half tank of fuel starts misfires and back fires though exhaust and starts hard
If you have a carb equipped bike and the bike has been lowered in the rear, you could be running out of gas on your main fuel switch position. You may have to go to reserve at that point. If the petcock is located at the front of the tank, the fuel is more to the back end of the tanks if the rear end of the bike has been lower. If it's fuel injected, I have no idea.
Good Luck
Steve
Mar 14, 2011 | 2002 Harley Davidson FLHR - FLHRCI Road...
My 2003 roadking just stopped running and the oil light is on. Can you tell me why it might be on? I've been riding for about half an hour and am now pulled over on the side of the road.
Did the oil light come on while the engine was still running? Do you have power to the rest of the bike? If not, have you checked the battery cables yet to be sure that they are tight? Is the "RUN" switch in the RUN position? Is it carburetted or fuel injected?
Nov 04, 2010 | 2003 Harley Davidson FLHR Road king
2003 HD Road King - starts fine, idle normal. Once it is warm, idles at 2000 rpm. Does not come back down, even after riding for an hour or two. Only idles normal when cold. Help??
If you bike is equipped with a carburetor, the idle stop screw is located at the top of the carb on the right side. Counterclockwise turn slows the idle speed.
If you bike is fuel injected, a dealer or shop will have to set the idle speed electronically.
Good Luck
Steve
Sep 16, 2010 | 2003 Harley Davidson FLHRCI Road King...
I'm looking at buying a 2004 Road King Custom with 8000 km on it...just wondering what I should look for as far as any troubles with the bike??that may be expected??
A 2004 RK with 8K on the clock shouldn't have anything wrong with it other than it may have been sitting for an extended period of time. In that case, the carb or the fuel injection system my need to be serviced with a thorough disassembly and cleaning. But, if the bike runs good at idle and highway speeds, I'd change the lubricatants and ride that bike. Something that it really needs.
Good Luck
Steve
Sep 05, 2010 | 2003 Harley Davidson FLHR Road king
My harley davidson road king keeps cutting out like its running out of gas or vapor locking any ideas?
I had the same problem on my 06' (Fuel injected). It was the copper filament inside one of the wire going to the injectors. It took 3 visits to the dealer and 4 hours of investigation to find it.
May 15, 2010 | Harley Davidson Harley-Davidson FLHR Road...
Fiited a k and n filter to my 2000 road king but it would not start first thing in the morning and run **** until i put the old back in again, do i have to put on the fuel pack just to have sports air...
Although I don't do fuel injected bikes, if it were a carbed bike, I would say that you would probably have to rejet the carb when you changed the air filter to a free flowing model. The same applies to a fuel injected model too, I would suspect. But, it may be within the "range" of the onboard computer you have. Take it by a shop and ask if the fuel map can be changed to accommodate the K&N Filter.
Oct 25, 2009 | 2000 Harley Davidson FLHRCI Road King...
2001 Road King Classic EFI model sputters on hot days
Oil has nothing to do with it. That guy must sell ams oil or something..anyway its your temp sensor on your bike. change it out. You guys running injected correct?
May 18, 2009 | 2000 Harley Davidson FLHR-FLHRI Road king
Lands Phones Logo
184 people viewed this question
Top Harley Davidson Lands Phones Experts
Tom Diffin
Gar
Gar
Sheldon Dedek
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
