no factory service manual,
in or outside of car is the engine?/////?????
i guess you are not looking at it: (no shared photos so?>?)
on most cars, (belt or chine off, or none)
you see a bolt, see that? i guess not?
turn bolt ccw, and it come off, (lock crankpulley first.
if in car, put m/t box in 5th gear?
now bolt off, use gear puller to pull gear. it has a key,dont loose it
why not watch 10,000 youtubes on that. its endless,
the fsm covers this
in USA< so does, alldata.com step by step, and shows tools.
all cars made.
need to remove harmonic balancer remove timing cover remove timong chine and gear and inatall the new one the timing markas are on the gear need to face the points aND REINSTALL ALL PARTS REMOVER BEFORE
Really not enough info on the the car like what year it is and how many miles are on the car and More importantly, Did the timing belt break on you or did you replace it at the 80K miles as most cars Should..
But,, I would ... 1 Check Compression for each Spark plug, 2 Check the EGR valve, "If stuck open or closed you get a lot of problems.. 3, Also sounds like you might have some what or an Vacuum leak..
However Something sounds wrong Since I would assume that a shop did the Timing belt/chine in the first place, Your timing belt Could have pit in 180 degrees off, Your car will run and drive But it will 95% of the time Give the problems your having.. Good luck.. BCB...
