I put it the ip adress, router, and dns numbers that I use on my Iphone into the ps3 but always get DNS error 80710102 when I try to connect to internet.
Re: get dns error when i try to connect ot internet
Try entering all your info manually, Disable Auto IP,DNS and DHCP on your PS3. If that does not work, many help gurus claim that entering
4.2.2.1 and 4.2.2.2 will work, NO GARUTEE
Check to make sure that your router is not preventing the ps3 to connect. Typically caused by a firewall. You can type in your ps3's ip address on the routers permission tab to allow access to the internet.
Well, I'm not completely sure how to help exactly. This problem sometimes prompts as "DNS" error followed by an error code. If it displays a DNS error, then your problem is that the PS3 cannot find the modem (and router if you have it connected that way).
DNS errors on the PS3 simply means that it cannot find (see) the modem/router.
One way of correcting this would be to reset your modem (and router if you have it connected that way)by unplugging it (from wall and power port). Keep it unplugged for 1 minute or so. Power down your PS3 at the same time.
Plug in your modem (and router if you have it connected that way) and allow for it to reset.
Now power on your PS3 and go to the network settings and establish a new wired connection. Follow the prompts and test the connection afterwards.
Mind you, this is a general means to solving the problem. Try this first to see if you are successful.
I do hope that this helps you.
Check to make sure that your router has gotten an IP Address from your ISP. Because you PS3 is telling you that it has an IP from your router. This means that the Router to PS3 connection has layer 3 connectivity, but what about from your router to your ISP? check that in the router by logging into the router's web page and going to the status page it should have your information from your ISP if it does not make sure that the main page is set to the proper settings either get IP automatically (Cable Modem) or Get PPPOE (DSL) connection (Make sure that your password information is correct to).
Now after checking these items make sure that you set the router up as the DNS for your network buy setting this on the status page then in your PS3 (set the DNS setting to point to your router, and set your router up as a caching DNS server). Then power cycle the router after saving everything, and power cycle your PS3 after setting everything. This should clear up your problem.
First of all, how is your network configured? Are you behind a router? What's it's IP adress, does it act as a DHCP server?
If so try to set up a new network connection and put everything to automatic.. When the routers acts as a DHCP server it will give the PlayStation 3 an IP adress. DNS however is something else. DNS is a system that allows you to browse by a website or hosts name. For example: it allows you to type www.google.com in your browser instead of it's IP.
DNS is essential for Internet. Your router should be your DNS server and your router itself also needs to know a DNS server, this would be the server from your ISP. All these settings are automatically configured via DHCP.
OK IF YOU HAVE PS3, and you get the ERROR DNS while trying to login into PSN, all u need to do is, shutdown the console, then restart it by holding down the ON button on the PS# not the controller till you hear 2 beeps, then try to login again, should work.
