Back to:
Tags:
JVC SR-V10U S-VHS VCR
Neither deck will open to insert tapes in my dual...
posted by minispender on Dec 01, 2007
I just purchased a supposedly "refurbished dual deck vcr" and found when I received that the decks doors won't open. I can force them with my fingers but they will not accept the tapes, I get "error" and then I pull them out. Everything else works fine. The doors seem stuck, then when I force them open they will open fine when I try them but as soon as I try to insert a tape they seem to just stop. help!
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jan 03, 2008
Not Rated (0)
DARKLORD1
Rank:Wiz Wiz
Rating: 85%, 376 votes
It seems they didnt refirbish it, you should return it..
If for some reason you cant return it.
The problem is your carriage unit is damaged
The carriage unit is the parts that load the tape into the vcr
If you think you are able you can open it up and look if any springs have fallen out. If not then change the unit.
If you cant fix it your self a technician can easily do it for you since it isnt that hard and somplicated to repair, you just need good retainence
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on neither deck will open to insert tapes in my dual deck vcr:
I don't want to Accept this solution
Can you Help with these VCRs problems?
VCRs
I have connect my SD-V394 Toshiba DVD/VCR combo to my Sony...
VCRs
Does anyone have the new codes for the ntl box in ireland?...
VCRs
before going on direct tv i was able to record programs on...
when i start recording from the beginning of a 6 hr vhs...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
