Question about Breville CT20 Retro Classic 2-Slice Toaster
Broken plastic sliding lug
The blue plastic lug that slides with the bread support arm to lock into a rotating clear plastic lug that holds the bread down was cracked so I glued it.
However another piece of plastic fell out of place while I did this.
Where does it go? Description: Brown plastic 25 m.m. square in the shape of a "u" with straight sides and a cut out in the same "u" shape with straight sides. A 12 m.m. tube is attached to the bottom!
I cannot detach the bottom of the toaster from the circuit board section after removing the 3 screws at bottom of toaster! Any advice other than to throw the whole thing out greatly appreciated!
    Problem Solver:
  • 11 Answers
Please send a picture, I cannot tell were it goes unless I know what it looks like, your discription is very discriptive, but please send a picture to the following e-mail address:
li199065@hotmail.com
Posted on Dec 06, 2007
Pt cruiser lock cylinder change
On most cars the lock cylinder slides thru the door and a clip slides onto it to hold it in place. You have to, obviously, remove the rod that connects to the lock mechanism as wll
Jul 30, 2016 | 2005 Chrysler PT Cruiser
How to replace window 2001 renault laguna
driver side window. first you need to take off door card. 2 torx screws at base or dooe and one behind the door handle under a little tab. then pull the door card towards you from the bottom, this takes some time to ease off due to being glued. unclip the door wire from the door pull. twist the bulb hold at base of door and pull bulb holder out of door. next pull the door window switched out and unplug the 3 plugs and feed out of door card. next pull the mirror control towards you and up and unplug it wire loom and feed out of door card.
now with your door card out of the way. you can see that you have 2 runners that will move up and down each will have a plastic lug sticking out which your window with its plastic guards will sit on.
slide your new window in through the window opening having removed both internal and external trim pieces. until the window is sitting in the rear of door groove and next to the lugs.
wiggle the window until both the window holes and plastic covers are sitting around the lugs, then slide the locking clips over the end of the lug.
replace trim pieces inside and out then reverse the fitting of door card as above
Nov 12, 2012 | Cars & Trucks
Swan SB1020 Bread Maker, how do you fit the kneading arm on the axle.
I take it from your post that you're have a bit of trouble attaching the two kneading arms to the two drive axles. That happens sometimes. The quality control for kneading arms is somewhat lacking and as such the holes somtimes have areas that need to be shaved down a bit more before they can slide down onto the axles all the way. In your perticular case and for your perticular model I suggest you rotate the arms upside down then push them down into the axles. Of course they won't go down all they way but this step will help open up the two lock notches cast into the tops of the arms. Once that is done, remove the arms, rotate them to their normal positions, then press them down onto the axles all the way to the bottom of the bread pan.
Hope this helps!
Jun 14, 2011 | Kitchen Appliances - Others
Front door will not close
On the 3000/3600/3800 there are two sliding guides, one on each side of the printer that tend to break. There is also an expired service bulletin for the locking arms that hold the cartidges in. most likely the sliding guides and possibly the surrounding plastics are broken. RC1-6643-020CN Right guide, RC1-6636-000CN Left guide, RC1-6638-000CN Left slide cam are the three most common parts outside of the cartidge locks Q5982-67925. The tear down to get to these parts is fairly intensive for a non-tech, and requires some attention to alignment during reassembly or you'll get issues with the color printouts.
Apr 28, 2011 | HP LaserJet 3800dtn Printer
How to remove and replace a printer roller on HP Laserjet p3005
Hi Adam,
I suspect that you are talking about the tray 2 pick up roller. Here are the directions for that:
1.)Remove paper tray
2.)Unlock left locking tab and rotate forward untill bushing slides off
3.)Remove black plastic roller retaining bracket
4.)Slide roller to the left untill right side of shaft clears the bushing
5.)Lift roller out of printer
6.)Place spring loaded end of roller shaft into left housing
7.)Slide roller to the right and rotate until roller locks into pickup shaft
8.)Reinstall black plastic roller retaining bracket. Left side first.
9.)Reinstall left bushing and lock into place
Let me know if you where sucessfull,
Printer Piete
www.allprotech.com
Dec 28, 2010 | HP LaserJet P3005 Printer
How do you remove Tailgate interior PANEL on Ford Freestar 2004 tailgate door
Remove the 2 bolts from handle, #2 from picture. Remove 2 screws from either side of door pane(#4) now just the clips hold it on, pull panel off at one corner and work your way around until its completely removed.
Thank you and good luck,
Lee
Jun 03, 2010 | 2004 Ford Freestar
How to remove the wiper arm on a 1966 Catalina. Please don't tell me to pull up the plastic tab and remove the nut. These don't have the plastic covers and I can't get the metal off to see if there is a...
Look for a tiny lever right over where the arm slides down on the motor cam. If you see it take a screw driver and work it out. It a slide that holds the arm on the slide sets in a groove when the slide is pulled away the arm is ready to lift up. It is spring loaded wo you will need to slide pull up on the back side of the arm to relieve the binding. If this is not it there is something like it that locks the arm to the motor cam.
May 10, 2010 | Pontiac Catalina Cars & Trucks
When turning on the Sansa e260 it is now in the Key LOCKED mode
I had a similar problem with my e250. The problem was that one of the plastic arms on the lock switch had broken off. The one that locked it was still in place but the other wasn't, so I could always lock it but never unlock it.
Since you already know how to open the case, take a look at the switch at the top. Use a pen or something and slide it to the unlocked position (away from the headphone jack). Put it back together and see if it works. If it does, just remember never to lock it again.
Mar 10, 2010 | SanDisk Sansa e260 MP3 Player
Replacing front wiper blades
If they're standard Chrysler (and they should be), feel the underside of the blade at the pivot. Inward, there's a plastic strip...press that down and slide the wiper blade toward the base of the arm (inward). Pretty much, the wiper arm terminates in a hook. When you press down on that plastic strip, you free a small peg from a hole that holds the wiper on that hook...then you just slide it off. To put the new one on, just slide the new blade on that same hook until it locks into place.
Jan 24, 2010 | 2007 Chrysler Pacifica FWD New Cars
TRIMMER STAYS IN OPEN POSITION
I had this problem, and it was due to the breakage of a plastic part.  If you slide the trimmer open you can see a piece of spring wire beyond the end of the word 'trimmer'.  The broken piece should locate the end of this spring; if it fails then the spring no longer forces the trimmer blade fully shut.  As the trimmer was opened and closed I could see that the spring did not stay symmetrically placed.  I could also see one end of the spring inside the mechanism, rubbing on the surface under the slider - but not the other.
To help with the instructions, let me identify some parts: "A" is the sliding part that your thumb pushes to open the trimmer; it carries the word 'trimmer'.  "B" is the hinged part that carries the trimmer blade itself and the word 'washable'.  "C" is the flexible piece of black plastic that connects A to B and on which the central section of the spring pushes.
To fix, first remove the sliding section A: slide the trimmer open and push a thin screwdriver down one edge of the slider.  Prise the lugs that hold A in place, away from their slots. Disconnect the connector C from the blade part B (gently push the lugs outwards, one at a time). Turn over the slider A and you should be able to see that one or both lugs that are intended to keep the ends of the spring in place, have broken.  (They are on a silver moulding fixed to the underside of slider A).  I fixed both ends in place with some two-part epoxy - be careful not to get glue on the other parts!  Allow to dry completely and reassemble.
Aug 20, 2008 | Braun 9595CC Electric Shaver
Breville CT20 Retro Classic 2-Slice Toaster Logo
175 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
