Hi there
Can you smell an awful burning smell as the machine shuts itself off, if this is the case then it sounds like the pump motor has overheated and and activated the over temp shut off on the smart drive 9 this causes the motor controller to cut out it will come back to life once the pump has cooled down or has been replaced.
only way to solve the problem is to replace the pump. to replace the pump, first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it, take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off putting the new pump on is as easy as taking it off.
Hi, I have a 601 model its about 14 yrs old, love it but now My hot and cold water are both...
(More)
Hi, I have a 601 model its about 14 yrs old, love it but now My hot and cold water are both trickling into the machine. The hot about 6 months ago and now the cold *** well. Someone suggested getting the soleniods replaced. The hot is cheaper than the cold one, so I was advised to use hot soleniods to replace both hot and cold what do you think? will it still work OK? ... Im desperately trying to save on money.
I have a fisher and paykel 601 smartdrive, it will not start, no lights come on, have spare parts...
(More)
I have a fisher and paykel 601 smartdrive, it will not start, no lights come on, have spare parts and changed board and switch panel but still it wont go . Is there some hidden switch. I have tried holding the lid switch closed but to no avail
hi,i have 5.5 smartdrive 9 excellence washing machine,it was alright,until i was about to start the...
(More)
hi,i have 5.5 smartdrive 9 excellence washing machine,it was alright,until i was about to start the second load,then the water supply is not filling up properly,long fill,then short fill a couple times then it stops and beep sounds with some lights comes on.the lights is the 3rd,5th,7th,and 8th on the wash progress panel.I have swapped over the solenoid for cold and hot,as i thought it was the solenoid,because i am never used the hot one.but the problem not solve yet.can anyone help me please,thank you!
F & P Smartdrive 708 has all lights showing when powering on, but will not start wash cycle....
(More)
F & P Smartdrive 708 has all lights showing when powering on, but will not start wash cycle. Have tried turning off at wall to re-set; taken lid off but still no go
