InFocus LP 600 Multimedia Projector Logo
Posted on Dec 01, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lamp didnt strike
I have replace the lamp infocus 540 still will not fire up what is wrong
  • Anonymous Feb 11, 2008
    SAME HERE
A
Anonymous
How do you reset the timer?
Anonymous
Level 2:
  • Expert 563 Answers
  • Posted on Mar 26, 2008
Anonymous
Expert
Level 2:
Answers
563
Questions
0
Helped
290461
Points
928
Hi there
You should reset the lamp timer as this LCD Projector's counter counts down the hours and will not fire up if this has not been done.
If you have reset the lamp timer and the problem stil occurs , you'll have to replace the Ballastboard ( lamp's powersupply )
1 Related Answer
projdoc
jasbo
  • 2239 Answers
  • Posted on Aug 03, 2009
SOURCE: Infocus 540 lamp didnt strike keep trying
bad lamp, bad colorwheel, or bad ballast.
4helpful
How to tell if lamp is dead? Lamp strikes 5, Red LED flashes once over and over. All whirs and whines as normal. Removed bulb housing, one side half-caked with dust, vacuumed it. Removed bulb, looks fine...
the lamp needs replacement.as per the manual.
the light flashes 5 times.this is the indication to replace lamp.
replacing the lamp should solve the lamp.
Lamp strikes 5, Red LED flashes once over and over the solution is lamp replacement.
for getting lamp you can get it from
www.partstore.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
2answers
Lp600 won't strike
If you replace the lamp but do not reset the lamp hours then the projector will not ignite the lamp to stop it blowing up the lamp and causing further problems. You can reset the hours without the image, on the x2 version you turned on for 1 minute then held down the volume up and down buttons for 10 seconds but all versions vary. The infocus website can usually tell you how though you may have to look for it a bit. Failing that try a firmware update available from the infocus website that should erase its brain so you can start again, hopefully you have kept the original leads it was shipped with to do this otherwise it will cost you another £20
Hi, I have an LP Infocus Projector. The fan kicks on but light does not come on. Green light on top keeps flashing, what could be the problem?
it can't strike the lamp. either the lamp is dead or the ballast has dried-up caps. a colorwheel malfunction will also cause the lamp to not strike, but you would get a red led, not a green. if the lamp center has bulges, cloudyness, and/or black spots, replace the lamp. otherwise, you'll want to replace the ballast. you can send it in for repair (or buy the part and do it yourself) from an infocus service center. try av solutions in ny. they're really good. www.avsolutionsny.com
I have an Infocus SP5000. The unit turns on,but
I use an infocus for my church. I don't believe there is a counter shut off, or a reset that would revent the light from operating. I sugest you go ahead and replace the lamp.
2answers
In-Focus LP-130 and it turns on but the lamp wont fire up, it sounds like the cooling fan goes on and then stops, its a brand new bulb also.. some one said its daughter board that controls the cooling lamp...
the ballast is bad. the fan turns on for the colorwheel, but when the lamp doesn't strike, the fan and colorwheel turn off until it tries again. unfortunately, there are no replacement parts for the lp130.
1helpful
Infocus x1a shuts down after 5 minutes
3 red flashing is a lamp error, not the fans. the lamp has a problem striking. make sure it's pushed in and plugged in all the way. if the lamp is not that old, the power supply needs replacing.
Infocus lp 540
Also having this problem."Warming up" then "lamp didn't strike" then "retrying" stuck in a loop. It's at a school where I work and nobody has reported any messages regarding the lamp hours.
3answers
if mains is ok and fan running ok, could be a bulb service issue, all lcd projectors have an internal lamp life counter which counts down and once the lamp has reached the end of its life it will not fire up and a new bulb will be required.
Yo
I believe that does mean the lamp is dead. If your model is the LP600, you need the SP-LAMP-019. A quick search on eBay found one for $320 new. From the InFocus website it is $499 so that is not a bad deal. InFocus offers a 6 month warranty, so that is something you will want to keep in mind.
Please help
Top InFocus Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
