Question about Maytag Dryers
Getting a fault code F70 on our 3000 series dryer? What does it mean and how do i fix it?
  • 15,935 Answers
F70 = Overheating sensed causing dryer stop until temperature reaches(drops) below set level - determined by manufacturer
Can be caused by different contributing factors;
1. poor airflow
2. blocked air flow screen inside tumbler
3. clogged lint screen
4. slow tumbler (low revolutions)
NOTE;
Ironically, the fourth factor has been lurking behind the popular discussions on this problem that has exhibited itself on both the whirlpool and kenmore products with the main triage to have included inspection of the electrical connections made by the installer.
These electrical connections not followed properly with accordance to '4prong' NEMA 14-30R (30amp, 2-phase circuit outlet) with separate ground and neutral posts, as exhibited in the standard dryer installation manual, will cause your tumbler to run slow. Hence, the 4th factor which caused the 'F70' code stops the dryer from operating.
Now, you have corrected the wiring as necessary and eagerly place some stuff's in there and all seems well. But as soon as you place something large and wet (HEAVY/BUNDLE), you get the error code again, Geeeezzzzz, you thought you had it!
Okay, this is what you need to do;
1. make sure your air flow is adequate by really cleaning the duct (I stuck my hand through the wall duct and scraped off old hard lint that can collect humidity & even cut my finger). Also make sure your vent hose does not have any unnecessary elbows or squiggles in it ( I had an elbow/pan type and it is not good as the heat seems to reflect too much ). KEEP IT AS SHORT AS POSSIBLE - I KNOW IT'S HARD, BUT IT IS NECESSARY.
2. Refrain from using too many softener sheets as they can & will restrict the air flow screen inside the tumbler.
3. Make sure your lint screen is clean - wash it periodically as lint particles collect moisture and this in turn raised humidity.
4. Once you have verified your electrical connections as stated earlier in this posting, run a normal cycle with towels or something of the like so as to reset the sensors in the dryer.
What my wife keeps doing is to put a back in after it's Heavy Buncle cycle (because it's not fluffy) and the dryer start up with high heat and then senses over heat and then SHE GET'S THE FAMOUS F70. In cases like this, use the damp dry selection and that works great - or better yet just use the timed dry selection with low heat.
We just have to understand that someone sat down and figured out what and how they wanted to program the computer that determines how this particular machine is going to react.
THE MAIN THING TO REMEMBER IS THAT 'F70' SEEMS TO BE THERE TO PROTECT AGAINST OVERHEATING WHICH IN TURN CAN TURN TO A FIRE HAZARD!
Posted on Mar 03, 2010
  • 1 more comment
  • blueextc3221
    blueextc3221 Mar 03, 2010
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
  • Shelby Smith-Sanclare
    Shelby Smith-Sanclare Sep 29, 2017
    Very thorough answer. Even a layman like myself understood, even though I will have to hire someone to do the work, at least I will know what is going on. Thanks!
  • Kevin Thomas
    Kevin Thomas Jun 25, 2018
    I believe F70 for the 3000 series Maytag dryer is an "overheating" issue (as stated here) - some other answers I've seen online indicate a communications error between control boards. Anyway, I had the same issue with my dryer where it would not work at all on "Normal" and would only run a few minutes (5 or so) on "Timed" before a restart was required. I checked my lint basket, dryer exhaust hose and roof vent - all appeared to be clear, i.e., no obvious blockage. The dryer body did seem to be fairly hot though. I bought a new dryer exhaust hose and routed it out my side door to the outside (no obstructions) to see if it would work. It did, even on Normal. When I put the new hose on, I noticed that the dryer exhaust pipe is removable (it is about 16" - 18" long). I removed it (exhaust pipe) to more easily put the exhaust hose on with the hose clamp. I looked inside the vent area and could not believe all the lint that was collecting there inside the dryer. I came to realize that my exhaust pipe was not fully inserted into the dryer (the last 2 or so inches on the inserted end connect the exhaust from the drum area, through the back of the dryer body, and out to the exhaust hose. I cleaned out the stray lint, re-inserted the exhaust hose and pipe into the dryer, and re-connected the hose to the roof vent and it has worked fine ever since. When fully inserted, the exhaust pipe should only extend 1-2" from the dryer body. There should also be a clip next to the hole where the exhaust pipe penetrates the outer dryer body. This clip slips over a ridge on the exhaust pipe when it is fully inserted and helps keep it in place and fully inserted. Bottom line...believe your indications. F70 indicates "Overheating"...I had "Overheating". We now notice much more lint collecting in the lint screen. Unplug dryer before reaching in to clean out the “stray” lint-there are some wires and relays in that area. On another note, I am very happy with the new exhaust hose I bought from home depot as it is very flexible, tear resistant, and somewhat insulated.
SOURCE:
What is fault code 6 mean?
Hi Darrell, The link below is about how to trouble shoot and fix your dryer.....I hope this helps.....CHEERS..
http://removeandreplace.com/2013/09/21/fix-clothes-dryer-heating-drying-clothing/
The most common causes for an electric or gas dryer to stop drying or heating is:
1. The dryer lint screen (lint trap) has not been cleaned (poor or restricted airflow).
2. A clogged or kinked (bent) dryer air vent hose (inadequate or no airflow).
3. Drum has stopped turning, broken drum drive belt.
4. Overheated or bad motor (possible thermal overload).
5. Thermal fuse or thermostat (could be caused from dryer air vent hose lint buildup)
6. Heating element burnt out.
7. Loose electrical plug or power socket.
8. Other mechanical issue, fault or malfunction.
Mar 31, 2016 | Fisher and Paykel DGGX2 Dryer
What does fault 55 mean?
Hi dear,
I do not know what sort of machine you have but following may help.
F55 Overriding time control overruned
That code blongs following machines.
Washing machine WT series
Tumble dryers TR-HH TR-GW series
Cooking Appliances H series.
If you be more specific about your machine (Type of appliance-Model number-Serial number) I can help more. Thanks.
Jan 11, 2016 | Miele Washing Machines
Fault code on my bmw 318i 2737 ews what does it mean
IT MEANS IT WILL COST ABOUT THAT MUCH TO REPAIR. BMW CODES ARE CROSS REFERENCED TO THE AMOUNT THE DEALER CHARGES TO FIX.
Oct 15, 2014 | 2002 BMW 3 Series
I am getting an error code of El followed by F3 on my 8600 series Kenmore Electronic dryer. The care and use manual is of NO assistance. Can you tell me what this means?
Your thermistor is shorted out, maybe due to the vent hose being clogged or kinked. No model so I can not give you the part number,
Jan 29, 2014 | Kenmore Dryers
Fisher Paykel Dryer Fault Code 22 Info
That is a fault for the "Door Actuator Open Circuit". You may have not had the door closed completely and when you opened the door to check it out, you closed it completely. Another possibility is the sensor module is going bad.
Feb 10, 2012 | Fisher and Paykel DE27CW1 Electric Dryer
Maytag 3000 series dryer fault code f22. what does it mean? dryer is just over a year old so i think i'm outside warranty.
F22 is an exhaust blockage. Machine shuts off to prevent overheating and causing a fire. Check the exhaust in the back for blockage. Also clean lint screen before each load to decrease the chance of exhaust blockage
Oct 03, 2010 | Maytag Dryers
PLEASE HELP! Dryer cuts off and gives an E68 code.
e68 code
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Good luck
Oct 05, 2009 | Frigidaire Dryers
Sounds identical.
This is what the fault means:
Motor Drive System Failure F-26 flashes if there is a motor drive system
failure. See TEST #3 in manual
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Aug 03, 2009 | Dryers
GE Dryer error code E61
E61 means you have the neutral and the L2 wire either reversed or in the wrong position. ENTER TEST MODE SEQUENCE by doing the following . 1.Disconnect thepower for 30 seconds.2.Reconnect the power and within 30 seconds press the sequence of buttons listed below.3.Press the "SIGNAL"button.4.Press the "DELAY START"button.5.Press the "SIGNAL"button.6.Press the "DELAY START"button. Now after you have fixed the reveresed wiring problem you will need to remove the fault code fromt he memory otherwise the machine will not work. To remove the fault code do the following ENTER TEST MODE
SEQUENCE (cont.)
You will notice "t01". To choose the test mode that you want toverify, turn the knob to the desired test mode setting.
Push the start/pause button.To cancel the test mode, press on "power".
You will be able to choose another test mode and again press on "start/pause".
The display error codes test allows the service technician to examine and clear the fault log.
DISPLAY ERROR CODES TEST
(t02)
The control shall display the most recent error in the fault logupon entry into the display error codes test. If there are no errors in the fault log, the no error code “E00”shall be displayed on the 7-segment display.
The control shall clear the displayed error from the fault log if the start key is pressed during the display error codes test. After clearing thedisplayed error from the fault log, the appliance shall display the next most recent error from the fault log.
After clearing all errors from the fault log, the control shall display the no error “E00”code on the 7-segment display.
The control shall log the last 8 error codes in the non-volatile memory stored in a circular list.
The control shall avoid logging multiple instances of the same error code. now unplug the appliance for about 30 seconds and replug and everything should be fine
Mar 16, 2007 | GE DBVH512EFWW Dryer
Dryers Logo
6,103 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Archie Ferrarini
Archie Ferrarini
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
