Question about Nintendo NES Console
Oringal NES I have replaced the 72 pin connector with a new one which has solved my "blinking" problem - but the games look scrambled - one has a purple screen with letters all over the place. Any suggestions??
Take it apart and remove the new pin. Clen where the pin connects with brasso, and a soft cloth. Repeat untill you dont get any more black on the cloth. Then remove brasso residue with windex and soft cloth. Make sure it is very dry. Put the pin back on and put it back together. It should now work like a charm.
Posted on Mar 02, 2009
Try cleaning your game connector with windex or on a q-tip and put some pressure when you rub it. Make sure that you rinse with a q-tips and water after and dry. if that doesn't do the trick I'm afraid you got yourself a bad connector.
repeat a few time. it happen to me. Good Luck.
Posted on Jan 19, 2008
  • 752 Answers
It's still not getting full contact with the game cartridge. Try cleaning the contacts on the games with a q-tip and rubbing alcohol.
Posted on Dec 01, 2007
SOURCE:
I have 2 Nintendo NES systems. One I thought didn't work and needed the 72 pin piece changed, but when I turned it on the other day, it sort of worked. The people in the games came up with letters and...
Secret trick: take NES cartridge, press cartridge down and waggle the cartridge inside the NES and then hold the NES down and shove the cartridge onto the pins. An alternate solution is to take a Q tip, dip it in rubbing alcohol and clean out all the dust inside your game.
Mar 23, 2015 | Nintendo NES Console
Solid yellow screen that is not flashing. I replaced my 72 pin connector and made my nes region free (4th pin from the left on the nintendo chip). I can play Super Mario/Duck Hunt but every other...
Well I think that the capacitors might be broken then and need to be replaced. Or try cleaning the gamepacks out with qutips and rubbing alcohal.
Sep 21, 2011 | Nintendo NES Console
The red light flashes on my NES and on the TV screen, it keeps on changing colors. Do you know whats wrong?
The NES is touchy like that, sadly-- your problem isn't uncommon. My NES, and the NES of nearly every friend I have who still owns one, plays this little trick on them from time to time. Here's what we do:
1. Turn off the NES console.
2. Blow into bottom of the game, near the chip that connects to the NES.
3. Wipe away any excess dust from the game itself.
4. Blow into the console of the NES.
5. Wipe away any excess dust.
6. Re-insert the game and try again.
If this doesn't work, try placing the game in more delicately, or with more force. It's just a matter of trial and error, and sometimes it will work faster than others. Hope this helped!
Mar 12, 2011 | Nintendo NES Console
My NES_oo1 powers up, but does not do anything when I press the Reset botton. Looks like the machine does not recognize the game cartridge.
Did you try blowing in the game? That used to work for me. I would look into buying a new 72 pin connector. This issue has plagued the NES and this new 72 pin connector fixes this problem for good. Just google NES 72 pin connector.
Mar 06, 2011 | Nintendo Video Game Consoles & Games
Light keeps blinking we pushed the reset button but it still keeps blinking. It is one of the first nintendo they came out with
The 72 pin connector is bad in the NES console which is why your getting the red light to constantly blink.
The connector needs to be replaced, this is one site I found thru google that sells replacement connectors. Click here.
That site happens to give you an installation guide that will show you how to take out the old connector and install the new one.
Sep 22, 2010 | Nintendo NES Console
Hi, I was wondering...how do you fix a NES which has been blinking? Like the screen flashing and restarting the game?
Replace the connector, these wear out over time. Here is a place I found thru Amazon that sells them:
http://www.amazon.com/New-Nintendo-72-pin-Connector-Guarantee-DS/dp/B000A3IA0Y
It will require you to take apart the system and to take out the old connector and replace it with the new one and then put the system back together and it will be like you have a whole new NES again.
Jan 23, 2010 | Nintendo Video Game Consoles & Games
Nes power light oes on and off
The nes does this to stop people from playing pirated games, but it can also be because the game cartridge or console is dirty. Try cleaning inside the game cartridge with a cotton bud dipped in a cleaning product of some kind. it mostly works for me!
Jul 09, 2009 | Nintendo NES Console
Nintendo NES Repair
It's as simple as unscrewing the console by removing all the screws from the bottom. Once inside take off the metal piece over the area where the game is inserted. Once under there you can remove the two screws that hold the 72 pin connector in and pull it out and slip a new one in. Put it back together in reverse.
Mar 26, 2008 | Nintendo NES Console
How to fix my nintendo (NES) without replacing anything
Yes, this is a 72 pin connector problem. The connector has become dirty or oxidized and needs replacing or cleaning. Problem can usually be solved by buying a NES console Pin cleaner which inserts like a game. The "Eliminator" is one which works great wet or dry to eliminate this problem.
Oct 09, 2007 | Nintendo NES Console
Nintendo NES Console Logo
325 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
