Question about Belkin (F5D5231-4) Router
Belkin Router I have a wireless network using a Belkin Router. I am seeking to obtain the ip address for the Router from the pc on the network.
  • nor246 Dec 01, 2007
    Thank you. The problem seem to be that the router is connected to a Aris cable modem, which seems to be setting the ip address and not allowing access to the router ip address and settings.
  • 83 Answers
Ip adresses are SIMPLE to find, it doesn't matter what router you have, unless you are looking for local ip which doesn't seem you stated it
You could find your ip in theese following sites
www.ip-adress.com
www.ipchicken.com
www.whatsmyip.org
www.whatsmyip.net
Hope this helped!
Posted on Dec 01, 2007
How to set up
For changing the network settings in the system, open the control panel by clicking on the 'Start' button.
From the 'Network connections' option, right click on the 'Local area connection'.
Then highlight the Internet Protocol (TCP/IP) and then press the 'Properties' button.
You are recommended to ensure the boxes which say's 'Obtain an IP address automatically' and 'Obtain DNS server addresses automatically'. Get more tips and help to Setup Belkin Wireless Router . hope this will help you.
Good Luck!
Michel
May 12, 2011 | Belkin Basic Wireless Router
I cannot connect to the internet with my linksys wrtu54g hotspot. It was working until 2 weeks ago. I get error message that says - a network card is incorrectly configured. The card should be able to...
The network card should be configured to obtain a IP address automatically,
Open Control Panel - click on Network Connections - right click on the network/wireless card - select Internet Protocol (TCP/IP) and click on Properties and then enable Obtain an IP address automatically and enable Obtain DNS server address automatically.then click OK and click OK again.
Dec 21, 2009 | Linksys Wireless-G WRT54G Router
I have a belkin fsd7320 router and dlink 302 and cant get to net
It sound like youe wireless card in the laptop is not configured correctly.
The TCP/IP settings on the laptop's wireless card should be as follows :-
In the wireless card's Properties - TCP/IP
Enablw - Obtain an IP Address automatically
Enable - Obtain DNS server address automatically
This is the same for the LAN card.
Nov 21, 2009 | Belkin Computers & Internet
How to forward website to belkin n1 vision router
You would have to log into the router to configure port forwarding on port 80. You would have to know the IP address of the computer hosting the website and put that in the routers config under port forwarding.
Oct 27, 2009 | Belkin N1 Vision Router
Belkin wired voip iad not connecting to internet with macbook
Try opening the Network Control Panel on the MacBook. Select the TCP/IP tab, then click Advanced. Note the list of IP address numbers. Click the "Renew DHCP Lease" button and see what changed. Most likely all of them did, in particular the "Internet Gateway" and "DNS server" addresses. The first is the connection between the D-Link router and your ISP, and the other addresses are for servers that translate your web browser URLs into the IP addresses for the web sites you want to see. The Gateway and DNS server addresses have to match those in the upstream router(s). The routers must have current IP addresses assigned by the routers upstream, and any client computer must have a current address assigned by the first route upstream. You can check into this by logging in to the webpages for your routers and examining the status reports.
Apparently one of the devices in the chain fails to obtain a new IP address when the D-Link router is powered on. I suspect it is the Belkin router. A computer with an expired DHCP lease will probably be using the Internet gateway IP address assigned to the D-Link router when it was on before (in a busy neighborhood, that address would have been re-assigned to some other household). The Windows system may be sending a request for DHCP renewal up the line, which triggers the Belkin router to ask for the same from the D-Link unit, but it may be ignoring the signal from the MacBook or not getting one.
If the MacBook successfully gets online with a manual Renew DHCP Lease request, obtain the owner's manual for your Belkin router (find the model number, then go to the Belkin support/downloads page for that model). See what settings are available to automate the DHCP renewal process.
Jul 10, 2017 | Belkin Computers & Internet
One of five PCs not connecting to Belkin 54G router
I would connect it to the router using a lan cable to verify that it will get a IP address and connect to the internet. Write down the IP information and make a static wireless connection with that info. It should work hardwired and wirelessly with this info. If it doesn't work wirelessly you may have a bad wireless card or you may find that their is already conflicting static IP info in the connection that has to be removed. Make sure that on your internet protocol (TCP/IP) properties that you have selected "Obtain an IP address automatically" and Obtain DNS server address automatically". Clear any settings that you may see there.
Jun 22, 2009 | Toshiba Satellite Pro 6100 Notebook
Belkin G+ wireless usb
make sure your pc and router are using WEP encryption and the signal strength is GOOD .
Dec 06, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
Unable to get connected to Belkin f5d6130 AP
You need to be connected using  wired Ethernet (PC's LAN card to Router's Ethernet Port (at the back)).  This is the preferable INITIAL way to configure the router before going wireless. Also it would be to your advantage to initially set your PC (that will be used for configuring the router)  to "Specify an IP address" (static settings) and not "Obtain an IP address automatically."
For a PC connected via UTP networking cable attached to a Belkin F5D6130 AP, the networking settings could be:
IP Address 192.168.2.2
Subnet Mask 255.255.255.0
Default Gateway 19*2.168.2.1
DNS Server 192.168.2.1
Reboot
Post back results. Good luck and kind regards.
Oct 12, 2007 | Belkin (F5D6130) 802.11b Wireless Access...
Wireless modem not connecting to everything on the network
this sounds as if either the router is not set at enable DHCP which gives your pc's and x box an automatic assigned ip address, so check in the routers settings via your web browser that DHCP is enabled, also go to your wireless network card and go to the properties, select the TCP/IP line, click properties again and make sure automatically obtain ip address is ticked, ok and close window. Do the same with the Xbox in the network settings and make sure that automatically obtain ip address is highlighted and automatic DNS is set. Lastly make sure non of the pc's network setup is set in a way that other pc's connect to the internet through this computer type set up, they should all be set up using the network wizard using the 'this computer connects to the internet through a gateway' setup, which is your router, but if your laptop is Vista, then everything should have set up automatically when a connection to your router was found. Lokk in the routers DHCP clients and look to see if all your pc's and the Xbox is listed and given IP addresses.
Jun 26, 2007 | Belkin (F5D9230-4) Wireless Router...
Connection problems
Is wireless connection enabled in your routers wireless settings and not encrypted in any way until a connection is established. Make sure your router is set to enable DHCP, as this will give your wireless card an IP address automatically. Ensure your card is set to obtain an ip address automatically. If not look in your routers setup(normally by typing 192.168.2.1, in your internet browser) to see what IP address and DNS address it has given your connected pc (eg 192.168.2.3). Then go into your cards properties and use the IP address 192.168.2.4, but the same DNS address(probably 255.255.255.0); then re start the wireless pc and the router if neccasary. If you still get no connection, ensure wireless light is on; on your router, and you have no obstacles in the way of the signal. If you are using WEP encryption it is normally a Shared key setting rather than an open key setting. Please reate this solution.
Nov 20, 2006 | NetGear Wireless-G USB Adapter...
Belkin (F5D5231-4) Router Logo
166 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
