Question about Proview PL926WBi 19" LCD Monitor
PL926WSi LCD monitor will not turn on. Have tried same PC with another Monitor and the second monitor works fine.
  • 1 more comment
  • Darkane Dec 01, 2007
    The power light will not come on.
  • brodskyjl Jan 31, 2009
    I have the same problem where nothing appears on my screen and the little led does not turn on when i push the power button. Is there a way to repair the c317 and C318 capacitor on the board like you said in solution 2?
  • vkath56 Feb 05, 2009
    My monitor turns on and off. Is it fixable? It is a 19" Proview monitor only 2 years old.
  • 3 Answers
It most likly has blown the C317 and C318 capacitor on the board inside
looks like a common problem
Posted on Dec 07, 2008
    Genius:
  • 1,601 Answers
Does the light come on?
If so the back light or inverter board are bad.
Posted on Dec 01, 2007
  • Thomas Christopher
    Thomas Christopher Dec 01, 2007
    you probably did these.
    No Power.
    Answer:
    • Set the LCD panel power switch to ON. The LED will light up on the front of the panel.
    • Make sure the power cord in the back of the panel is securely connected into a power outlet.
    • Check the power source using another electrical device to make sure the power source is supplying sufficient voltage.
    If so then the internal power supply is bad.
My monitor works fine for weeks than suddenly just goes black! I turn it off and back on and it only stays on for about three seconds than goes black again! The power light stays on!
take off the monitor data cable from pc and try to turn monitor on if appears a smal square on the screen that mean your monitor is ok , and the black screen reason maybe data cable or vga card.
note : your monitor resolution is 1680x1050 some times wrong resolution cause like this problems
if you see that is helpful please don't forget to vote me
best regards
Apr 22, 2011 | Acer P221W LCD Monitor
When I first turn on the monitor I get a picture for about 1 second then it goes black. If I turn the monitor off then right back on I get the same 1 second pic then black. A different monitor works fine...
Make sure you are on the correct video setting on the monitor using the menu button.
If you are hooked up to dvi you need to make sure the monitor is on the dvi component. VGA same thing.
Hope this helps
Positive feeback always welcome
Mar 03, 2011 | Dell E198FP 19" LCD Monitor
Hi i have a problem about my lcd viewsonic va702, when starting my computer i can see the image for 1 sec then it turn black ...lcd light is ok and computer too already tried with other lcd all works fine...
this works for Dell monitors with a similar problem: shut down, turn off monitor and pc, turn off at wall socket, and remove power plugs from wall socket. wait about 30 seconds. plug back in, turn on, and all should be well? I have used this 3 times on a Dell PC with a Viewsonic monitor.
Dec 23, 2010 | ViewSonic VA702b 17" LCD Monitor
Proview monitor PL926WSi Screen goes out after about 5 seconds
Hello Joe,
A red or pink coloration on the screen indicates bad backlight bulbs. They are just like standard fluorescent bulbs just much smaller. When they start failing they light up with a pink color and that will make the screen look pink or red. You can change them but it may not be worth the trouble. You can do a Google search for compact fluorescent tubes and check prices.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Oct 18, 2009 | Computers & Internet
Computer monitor screen stays black
please check the signal cable..... sometimes the signal cable gets faulty and it would be best if you replace it..
Jun 02, 2009 | LG Flatron L1710S 17" LCD Monitor
Monitor black with green light on
did you changed frequency of that monitor? if it is out of factory setting that could be the problem, try to connect it again as secondary and set Hz to default, if that does n't work try same settings on both monitors? i have connected two monitors i had same problems , my secondary monitor was clone for tv if you are using secondary monitor for clone to ty (with s-video or whateever) if tv is old it must be 60HZ 800x600...
Apr 27, 2009 | Computers & Internet
I have a 20 sceptre widescreen lcd monitor
Have you tried any other monitor connected to your computer since your current problem? Check your connections, make sure your VGA cable/DVI cable are in good condition. If none of that works try to RMA it to sceptre if your still within the 1 year period.
Apr 07, 2009 | Sceptre X20g-Naga III 20.1" LCD Monitor
most common lcd monitor break down, check all electrolytic capacitors for leakage and loose board solder specially on the ccfl inverter section.
May 26, 2008 | LG Flatron L1710S 17" LCD Monitor
Proview PL926WBi 19" LCD Monitor Logo
124 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Frank Russell
Frank Russell
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
