Question about RCA RP8078 5-Disc CD Changer
I have got a rca 5 disc changer rp 8055c it want play my cd
It will come on but thats it
    New Friend:
RCA 5 DISK CD PLAYER AND RADIO CANT HERE MUSIC LIGHTS COME ON CD PLAYS BUT NO SOUND.
HELP
Posted on Aug 24, 2014
SOURCE:
  • 11 Answers
SOURCE: It is a 5 disc
THis happens when the drawer is jammed. Turn off the unit and turn it on and then use the disc skip from the remote so that the cds inside will change and then press the Open button.
Posted on Aug 21, 2010
sams_trix
  • 93 Answers
SOURCE: Music plays normally at first then begins to cut
There is a problem with the laser pic-up assembly(eye) 1st,2nd, 3rd,4rth music/track are recorded on disc from the center to edge.As the laser moves toward the edge the laser can't read perfectly the stored data on the disc. possible cause:the disc is in figure of 8, the lens needs cleaning, the suspension of the laser assembly,poor recording speed,spindle motor and voltage fluctuation of VCC
Posted on Sep 01, 2009
lock123
  • 6831 Answers
SOURCE: I need an instruction manual for an RCA RS 2650 5
Hello
OK, you will be able to download the manual at the link below.
Click HERE.
Let me know if this was helpful.
Kind regards
Andrea
Posted on Sep 06, 2010
earlnuton
  • 39 Answers
SOURCE: Re a RCA RS2663 audio
get a new one problem solved
Posted on Dec 20, 2010
Ironfist109
  • 3018 Answers
SOURCE: RCA 5 DISC RTD250 AND
  • There is a major malfunction in the unit that is making this happen. This is not a simple fix. Unfortunately no button pressing sequence will fix this either. I suggest getting a quote from a reliable shop and be prepared to buy a new disk player as repairs can often out price buying a new disk player.
  • Hope this helps and thank you for using FixYa.
regards, Tony
Posted on Jun 19, 2011
BRAND NEW TILLER WIRE HANGING DOWN BY CARBUREATOR BOWL WHERE DOES IT GO.
David try this there should be a piece of flat metal that is horizontal by the carb. bowl that you can push back and forth, it should have a hole in it. The end of that wire should go into that hole and you need to crimp that wire so that it stays in the hole attached to that piece I described that moves horizontally. Based by the picture of your tiller this wire is going control your throttle so that your tines turn.
May 01, 2016 | Yard Machines Tiller 208cc 18in Tilling...
My amcor turn on but immedatly cut the house power off
Check the rating plate on the ac; the rating plate may be on the back, bottom, just inside the front grille on the ac. It probably has to much current draw for the electrical circuit that it is on. There also may be other electrical devices that are on that same circuit and all of those devices together are to much for that circuit. Check the fuse or circuit breaker that it is tripping/blowing and compare that to all the devices that go off when the ac trips the circuit. Place the ac on another circuit by itself of remove some things from the other circuit that it is already on so that it does not draw to much current. The circuit that it is on now is probably just 15 or 20 amps. That 15 or 20 amp circuit has to run all the devices that are on that circuit. Some ac can draw that much current alone depending on how many btu's it is. Unplug everything from that circuit except the ac and see if it will then start up and if it does that just means that to many things are on the circuit. If the ac still does not start up and run, then the ac itself may have a problem.
Jul 24, 2012 | Heating & Cooling
The word is "Reserve''. When
this means that this person listed with a minimum amount that they would accept, that the reserve, when the reserve has not been met, usualy the seller will relist the item and try again. if you had saved that item listing in your watched list and you try to go to it, it should tell you that the auction for that item ended and will indicate if seller has relisted..hope that helps..
Sep 13, 2011 | eBay Auctions
What do you mean by Dogma
Dogma is belief that is held by religion or any organisation that cannot be speaken against.
For example,if a person have a belief in their family that taking bath on tuesday is wrong and if that person forces that belief upon their family saying that anyone who speaks against this belief or teases it would be expelled from family,then that 'taking bath on tuesday' is the Dogma.
Dogma is something that should not be spoken against by its believers and people practising that dogma should not deviate from the principles laid out by man who framed the belief,that is,Dogma.
Aug 15, 2011 | Computers & Internet
Give me reason why i should study health and socialcare at uk?
Anything that you can learn is never wasted.
Anything that you can learn that might prolong your own life is a gift.
Anything that you can learn that will prolong the lives of others is a gift that can truly keep on giving.
I see it as a win-win. You get knowledge that has the potential to help yourself and others. Why short-change yourself this early in the game??
I took a lot of classes that I thought would have a dubious outcome. Without exception, I have learned and kept some of each class with me. You will, too. You never know when that one thing will come along that will change the way you look at things. Now THAT'S education.
With the greatest regard, I remain,
Your humble servant, --W/D--
Feb 07, 2011 | Health & Beauty
MY CAM BELT IS BAD IS THAT BACK THE GEAR ON THE
thats the balancer shaft gear, its LOCKED UP??? thats bad, never had that happen. a shop that does a lot of HONDA work should look at that for you, the engine may need to come out. sorry for the bad news ; (
Oct 20, 2009 | 1996 Honda Accord
Subaru forester 1997
All around good car with great ground clearance and use-ability. Be aware of used ones that have high miles due to the fact that the 2.5 that was used is prone to head gasket failure. Make Certain that when puchacing one, that records are included that illustrate that both head gaskets have been replaced and that new ones meeting updated OEM standards where used. Run Subaru coolant conditioner and service regularly and this car will run 200k+
Oct 06, 2009 | 1998 Subaru Forester
When i start my broadband , google gives me message
Sounds like a website that is blocking your access, this is not all that uncommon. Is it actually www.google.com that comes back with that message, or a website you looked up on google, and when you click on that site it gives you the message. If that is the case then there is nothing that can be done on that end. If you feel you should have access to that site you can contact the owner of the site. If you need information on how to get ahold of the owner pleaes let me know.
Jun 25, 2009 | Computers & Internet
I want to transfer Office 2000 from my old computer to a new one which I am buying. I downloaded Office directly from Microsoft and don't have the CD. How do I find a validation code or Key #?
I would suggest that if you have a computer that you can dowload a program that will write/burn that program to a cd or make a flashdrive bootable(auto run) that you should do that and save it on a media device(bootable cd, storage device, etc) After that all you should have to do is use a computer that has true microsoft operating system go to the microsoft download website and download that official microsoft validation application save it, then install it to the cpu that you want to Install whatever microsoft program that ask for microsoft validation to install.
Dec 05, 2008 | Computers & Internet
Sim registration filed on my nokia 3230
please try that sim in another mobile if it still get error message then that means ur simcard is faulty. but if that work fine in another then that means your 3230 is faulty and you have to format that. format with following code: *#7370# after that it will ask for another code then insert 12345, your mobile get formatted now. keep in mind that your all data on phone memory of that mobile get lost, if you that. if nothin get right for you then you have to go nokia service centre at last.
May 15, 2007 | Nokia 3230
RCA RP8078 5-Disc CD Changer Logo
638 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
