Question about Simplicity for Children 4-in-1 Convertible 3045 Bassinet
Missing side rail.
We lost side rail that is removed to make it a cosleeper' Hood will not fasten w/o it. Also cannot use as a regular bassinet. Where do I find the part?
Thanks, Mamaw in WV
    Genius:
  • 1,601 Answers
  • Thomas Christopher
    Thomas Christopher Dec 01, 2007
    did this solve your problem?
    Please rate this as a FIXYA
    Thanks,
    Thomas Christopher Dec 05, 2007
    Thanks,
Does anyone know where i can find the instruction manual for my crib model #343-8420-0018?
Found this :
Can you help with this Cribs Cradles Bassinets question posted on FixYa
  1. Take out four screws (two on each side) of the front railing and top bar. They are the screws holding the front railing and the top bar to the side of the crib and the dresser.
  2. Lower the mattress to the lowest setting.
  3. Place the toddler bed railing in place. It can go either way depending on which side of the crib your toddler sleeps. We put the taller part of the toddler railing closest to the dresser because that is where our son's head usually is.
  4. You'll need 4 1.5 inch hexagonal screws to screw in the toddler railing. After 2.5 years, I could only find two of them, so I used two 1.5 inch regular screws that came with the crib. On the taller part of the toddler railing -- the screws go into the 1st and the fifth holes. On the shorter side of the railing, the screws go into the 3rd and the 5th holes.
If this doesn't help you can try contacting the store you bought it from.
Apr 11, 2014 | JCPenney All-in-One Nursery Crib
We have a Morigeau-Lepine convertable crib-day bed-full size bed, but we are missing the instructions to convert it to the full-size. It's model number is DA722-BC & the model is somewhere between...
I can't offer the exact answer, but hopefully my suggestions will be helpful...
Converting the crib to a full-size bed should actually be a fairly simple process of detaching the 4 sides that make the crib, and replacing the 2 short sides with the full-size bed rails that were sold separately in a conversion kit. The 2 long sides of the crib become the headboard and footboard of the full-size bed.
Unfortunately, it's only a simple process if you already have the full-size conversion kit bed rails. And since Morigeau-Lepine went out of business, they aren't making any more conversion kits. If you don't have the full-size bed rails, then this could be quite difficult.
It's possible that some stores that used to sell Morigeau-Lepine cribs might still have a conversion kit hidden somewhere in the back of their stock room or warehouse. You could try calling around to a few of your local stores to ask if they would check for you. It's a long shot, but it doesn't hurt to ask.
If you have the rails, or are lucky enough to find them, then it should be as simple as locating the screws that hold the crib sides together, removing them (most likely with an appropriatly sized hex-key,) and putting the screws back through the headboard and footboard into the bed rails. (I'm really just assuming that it works the same as the Babi Italia conversion.) If no screws are visible, or if removing them doesn't detach the crib sides, then they are probably also held together with locking bed rail fasteners. To release the fasteners, remove any visible screws, then push upwards on the short side rail while pushing down on the long side rail. You might have to tap the rail up with a rubber mallot to get it moving.
If you don't have the full-size bed rails, and you can't find them anywhere, your only option may be to build them yourself, or find a woodworker to build them for you. Search online for "Bed Rail Fasteners" and you'll see several options for hardware, but they might require modifying the headboard and footboard as well. Full-size matresses are 75 inches long, so you'll want the length of your rails to accomodate (ours are 77 inches long.)
I hope I've been helpful. Good luck!
Jan 19, 2011 | Baby Gear
I have an evenflo jenny lind crib, what do I need to make the one side go up and down? i think I am missing some parts. model # 012614
do you have a bar on the bottom of the side of the crib - if you do, all you do is push it in and the rail will come down. If you don't have this rail, then you are missing that part.
Sep 19, 2009 | Evenflo Jenny Lind Crib
Lost the hardware to reassemble the crib - what do I need?
Products America supplies all replacement hardware for Kinderkraft cribs, including the Vermont model. This model uses moving side hardware as well as a series of fasteners to attach the non- moving side and mattress support to the head and footboard of the crib. We also have the original assembly instructions available with parts list for you to determine exactly which parts may be missing. Please call us at 800.205.9642 or 800.772.1041 from 8am to 6pm Central Time M-F for direct asisstance or email parts@productsamerica.com to request the assembly instructions.
Sep 10, 2009 | Kinderkraft Vermont Crib
Trying to turn our crib into a toddler bed
Part needed: Allen Wrench
Safety rail
Safety rail bolt
Make sure the mattress support in in lowest position. Remove the front top rail and front panel. Attach both safety rails ( small side pieces) to the crib end leg using the safety rail bolts.
Mar 25, 2009 | Delta Enterprise Baby Gear
Missing hardware to White Delta Lauren crib
Try www.productsamerica.com. They have many crib parts.
Apr 23, 2008 | Delta Luv Lauren 4341
Crib locks
if you're missing the lock parts from the ends of the side rails(end caps), I was to. I borrowed the cap from the youth bed rail
since when it's configured as a crib, that rail is extra anyway.
when it was time to go with the youth bed I simply put the end
caps back onto the other rail. GOOD LUCK!
Apr 10, 2008 | Childesigns Carrollton Crib
Lost parts
Go to www.afgbabyfurniture.com and you can order what you need. Mary
Mar 06, 2008 | AFG Daphne Crib
Childesign Shelby crib replacement parts
You know I just purchased a Childesigns crib from a garage sale thatI thought had everything needed. When I got home, we found it was missing one top plastic rod. Of course nothing will work without that. I found this webpage that sells a VERY similar product. http://www.productsamerica.com/page65.html. It is not exact, but to be able to use the crib, this was a good option for us. Hope this helps.
Sep 06, 2007 | Childesigns Shelby Crib
Simplicity for Children 4-in-1 Convertible 3045 Bassinet Logo
44 people viewed this question
Top Simplicity Baby Gear Experts
Charles T Nevin
Charles T Nevin
Marvin
Marvin
ray gallant
Are you a Simplicity Baby Gear Expert? Answer questions, earn points and help others
