Question about Sony ICF-SW77 AM/FM/SW Radio
No Battery Power
For some reason, my ICF-SW77 won't operate on batteries. Even with brand new batteries, I still get the flashing dead battery symbol in the display. I disassemblied it and couldn't find any visible problems. I thought I read somewhere long time ago that you need to plug it into an AC outlet periodically if you're not going to use it for a long time. Would that have something to do with the problem?? Any solution would be appreciated. Thanks!!
  • 494 Answers
Late with this answer.... Battery tabs sometimes loose contact with signal board near volume slide, possible solution is to reapply solder and bend contacts slightly.
Posted on Feb 06, 2012
3 Suggested Answers
SOURCE:
SOURCE: Sony ICF-SW77 no Audio
you can get the service manual online at www.mods.dk
Posted on Aug 12, 2009
SOURCE: I wont to buy the antenna of sony icf-sw77?
You can but online. Google for sony part number 1-501-505-11 (replaced by 1-501-505-21)
Posted on Sep 28, 2011
Sony icf sw7600gr won't power up on battery power and showing exhausted battery symbol,only on ac adapter will work
check the connection inside the radio, switch of AC-DC connector maybe loose contact.( leak diode more probability replace it)
Nov 09, 2015 | Sony ICF-SW7600 AM/FM/SW Radio
New battery In mercedes no power
I'm not a car mechanic, but, it sounds like you might want to check the fuse to the ignition switch, and, if that fails, it might be a problem with the Start Safety Switch on the transmission. Good luck.
May 02, 2017 | Mercedes-Benz S-Class Cars & Trucks
Lenovo Y550 has been sitting without being used for many months. I tried to power up today. It starts, the disk drive symbol flashes for a second or two, and then it stops. I've tried removing the...
If it works with the AC cord plugged in and not on battery, then you have a dead battery. Even when plugging in the battery it's going to try and charge the battery and THEN provide the computer with power. Get a new battery.
Oct 25, 2013 | Lenovo Y550 Notebook
Canon 600ex-rt speedlite won't turn on with new batteries
I was having exactly the same issue with my 600EX-RT. This is what solved the problem for me. With the power turned off. Hold down the 2 clear buttons for approximately 5 seconds, then turn the power on and hopefully, you should have a fully operational Flash.
Apr 14, 2013 | Canon Speedlite 600EX-RT 5296B002 Norman...
My dell inspiron mini 10 won't boot.There is just a flash of white light then a flash of amber light when I press the power button. That's it, nothing else.
Remove the main battery and try again, also! the power adapter charger should be checked for correct voltage, if okay! pull one stick of ram and test, and the second piece not forgetting to put the first one back and power up, if all this fails you will need to get it assessed.
Mar 25, 2012 | Dell Inspiron Mini Netbooks
Hi my Pavilion dv3 refuses to start unless I connect it with the adapter. Even then, the battery won't charge and it will stay "55% Plugged in, Not charging". I figured that my battery is...
There is only one reason why this is so because the battery is dead finally. There is no other possible cause to this. The battery lights keep blinking because the battery does not hold power anymore.
hope this solution has been helpful?
Jun 20, 2011 | Computers & Internet
My polaris 700 4x4 would not start, dead battery, charged it. now it backfires and loses all power...Any ideas? TIA
You def need a brand new battery . There isn't enough power in the battery to operate bike .Charging will be ok if battery still has half of it's life left but after that it's only enough to flash it up and not actually take it out into the woods .
May 27, 2009 | Polaris ATV
Time
Indicated the memory is lost, usually this points to back up battery that needs replacing. I do this service.... contact me here .... poikaa(at)yahoo(dot)com
Oct 17, 2008 | Sony ICF-SW77 AM/FM/SW Radio
Sony ICF-SW77 AM/FM/SW Radio Logo
174 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
