Question about Memorex MVDR2102
Replaying a time recording program. Why does it replay in Spanish not English
I set two programs to be recorded. The first program when I replalyed it, it replayed in Spanish not English. The second program when I replayed it, it was in English but contains voice overs for people who are blind. Please tell me what settings need to be reset to solve these problems
  • lefty66 Dec 03, 2007
    I need more help with my problem. You tell me that channel setting was incorrect. How do I correct channel setting? You tell me that the sound over for a blind viewer was because I had "captions on". No, I have captions turned off. Again, please help me record programs in Engish; not Spanish.
  • 1,113 Answers
Channel setting is incorrect I'd say
Posted on Dec 01, 2007
  • Soulvisitor
    Soulvisitor Dec 03, 2007
    Link to manual ....when you permormed inital setup the channels would of been stored you need to select correct stored channel to record from.
    link to memorex support email
  • Soulvisitor
    test correct channel by viewing in arial mode first
  • 83 Answers
Well, it seems like it is already in English, but the spanish wasn't translated because of malfunctions that who knows what happened, for setting caption should be off unless you want text, voices of blind people sounds like the program on t.v. you recorded.
SOURCE:
I have bought the video recorder from a charity shop, but I haven't got the manuels to go with it
This device is a digital video recorder used by security firms to record cameras. It is not designed to be used to record TV programs like a Tivo DVR. Here is the brochure for it.
The User's Manual can be found here. it is in Spanish, French and English. English is the last section of the manual. You'll need Adobe's free Reader program to view / print this manual.
I hope this helps & good luck! Please rate my reply. Than you.
Apr 01, 2011 | Samsung SVR1620N Video Recorder
Can't watch my videos recording of my business from home , triedfrom two different computers.
If you have recorded a video file using 1 computer, you need to make sure that you have the correct codecs for replaying the video. best option is to install the same programe onto at least one of your home pcs.
Apr 04, 2010 | Mace DVR-1600HP Video Recorder
Want to stop VCR from using Spanish language on programs it records
Use SAP (or SAP/HI-FI) button on remote to cycle through the choices until you get to English or OFF.  Or use Setup Menu to select English language.
May 30, 2009 | Panasonic PV-V4525 VHS VCR
Bars across picture when replaying tapes.
The tapes were recorded in LP mode and the replay is set to SP mode. Switch from "EASY" to "P" and replay and you should be OK
Apr 27, 2009 | Canon MV800i Mini DV Digital Camcorder
Recorded programs in english come out in Spanish
Make sure your TV hasn't been set for SAP (you'll find it in the audio settings menu). Second audio programming is often used to carry alternate languages, and if it's turned on you won't know it until you watch a program where it's being used. There may be a single button labeled SAP on the remote. If so, it's easy to change the TV setting without realizing it.
Feb 06, 2009 | JVC AV27F476 27" TV
Sanyo DRW 500 DVD RECORDER
check partstore.com for a manual on your dvd recorder.good luck
Sep 08, 2007 | Sanyo DRW-500 DVD Recorder
I need help
Simply goto the menu and go into the time section and put the correct time in first. then find the programming section and put in date and time the show comes on and don't forget timer when finished.
Sep 05, 2007 | Sanyo DRW-500 DVD Recorder
DVD Player/Video Cassette Recorder
Hi It sounds like possibly there is stray RF getting into your video signal from your DVD/VCR combo to your tv. Check that your cables are ok, but also, if you can, try moving the unit in relation to the tv, if it is underneath, try putting it on top or beside the tv, I've seen the effect you describe be cause by lack of sheilding in both the tv and DVD/VCR, and moving the unit could cure it. Good Luck!
Apr 02, 2007 | Sanyo VWM-900 VHS VCR
Answering service
I have 27996 phones too. I lost my manual. Here is the website to get the manual. www.thomsonnetwork.com At the bottom type in 27996 and it will bring up a pdf file that you can download to your computer. Here are the directions for your problem. Display Language 1. Press the FLASH/program button until 1ENG 2FRA 3ESP shows in the display. 2. Use the CID/VOL (left or right arrow) button or the handset number pad to select 1 (English), 2 (French), or 3 (Spanish). The default setting is ?1ENG?. 3. Press the FLASH/program button to confirm and to advance to the next menu feature.
Mar 29, 2007 | GE 27996 Twin Cordless Phone
Memorex MVDR2102 Logo
131 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Steve Allison
Steve Allison
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
