Question about Ovens
Vapor Smell When we turn our oven on we get a horrible vapor smell that burns the yese and nose. It does not smell like gas. We are not sure what it could be.
  • 290 Answers
DO NOT OPERATE THE OVEN UNTIL YOU GET SOMEONE TO CHECK IT THAT IS FAMILIAR WITH A GAS STOVE!!!
It is very possible that the oven is not burning clean and this will release carbon monixide into your home. This could be very, very dangerous.
If you have just purchased the oven, then it may need to be set up for the type of gas you are using.
If it is not new, then it may have some problem with the air intake to the burner.
It could also be something harmless such as a spill that is burning off, but if you are not sure what it is, please take the safe route and do not use the oven.
This is not a problem that can easily and safely be determined from an internet website. A competent gas repairman needs to look at it if it is burning your eyes.
I understand this answer may not qualify as a fixya rating for you, but I am more interested in your safety than my rating when it comes to a possible dangerous problem.
Please be safe.
Thanks/Mike
Posted on Dec 01, 2007
I smell something burning when the oven is on...not as "eggy" as gas but I have a pregnant wife and I'm scared to use this thing.Is it just a new oven smell?
I would have a service call made and have the service technician check for correct installation
Smells ( that cannot be attributed to burnt food, gas ) should be investigated as they are the early warning signs of a problem
at least you will have peace of mind and may be advised as to a product that can be used to remove the smell
Sep 01, 2015 | Ovens
I set my brand new GE oven to bake and it almost immediately started to smoke. It continued to smoke even after I turned it off. It smelled like burning wood. It kept smoking (15 minutes) until I unplugged...
Wherever you bought it from should have a warranty. Get them out there to look at it. The smell of burning wood is odd. Check to make sure all of the packing material was removed prior to installation. That could be burning cardboard on the outer casing of the oven.
Dec 18, 2014 | Ovens
Health issues
if oven is new. expect strange smell coming from the heating up of the new paint, just to be sure also check for gas leaks.
Mar 18, 2014 | Maytag Ovens
This just happened over night the oven is on but there is a bad gas smell when it is in use. There is a hissing noise too.this oven runs on propane
When the burner is burning, are both sides of the burner lit and is it lit all the way down the burner? If it is and you are still smelling gas you should not use the oven until you have it serviced, so you do not have an explosion. Propane is heavier than air, and will settle in low areas, so smell low by the floor around the oven before you light it to make sure you don't have a leak first. To be safe until then, close the shutoff valve on the gas line at the appliance until you get it looked at and fixed. Douglas
Jul 02, 2010 | Ovens
Gas stove When I turn on the oven, I smell gas,
This is more than likely the igniter to be sure you will need to do an amp draw on the igniter. To do this watch the video on troubleshooting a gas oven at www.appliancehelponline.com/servicemanual.html
Mar 12, 2010 | Stoves Ovens
Oven slow at starting, there is smell of gas before oven turns on
If there is a smell of gas PLEASE STOP USING IT you risk fire or explosion or both. Please get a registered Gas-fitter to look at this. If you can Turn OFF the Gas at the Wall/Outlet. Until it can be looked at. If you smell gas it is very dangerous.
Feb 11, 2010 | Ovens
Oven does not light
first check the igniter to see the color of it. if it is orange you need to replace it because it is too weak to ignite. it needs to glow white hot. second, the burning smell could be from the coil, check the coils as well near the gas valve.
Nov 08, 2009 | Ovens
Self clean for 4 hours -- do i need to leave my apt?
The first time you do a self clean it does smell weird and you do not need to do it for 4 hours change the setting to 2 or three hours. This uses allot of ellectricity to do the cleaning. I usually just use a oven clenaing product for light cleanup. If you have a pie that has spilled over or something then it works great. The Smell is a bit of ash and smoke from all the things that you are incinerating inside your oven.
Cheers
Al
Sep 11, 2009 | Bosch Ovens
Strong Foul smell coming from oven only when I turn it on
do you have mice.they will tunnel in the insulation.you know what they do next,well then you heat that up and theres your smell
Dec 31, 2008 | Magic Chef 9122 Gas Single Oven
Oven gas
For safety purposes call gas technician to check your gas pipe. If stove turn off supposed not to smell gas.
Jul 23, 2008 | Frigidaire FGB24S5A Gas Single Oven
Ovens Logo
193 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
