Question about Sony KV-27S22 27" TV
Sony KV27S22 27" tv wont turn on
I opened the unit and found a burnt fuse and C615 shattered. The fuse is easy enough to replace but the number on the shattered capacitor is 393 J (S) 630 C. where can I get a replacement?
Most likely a 39000 value or .039 mfd @ 630 vdc ( 39 + add (3)0's
Posted on Dec 01, 2007
Sony standard tv wont power on
Check the main fuse on the power supply regualtor board of your tV. If found opened, check and find out the reason for failure to present fuse, before put an other in place.
Apr 25, 2012 | Sony KV-36XBR400 36" TV
Wont turn on
Hello
Check the On/OFF switch first. Then check the AC cord. If both are OK, open the TV, and check the fuse. There is a glass cartridge type, replaceable fuse on the power regulator section. If found opened, replace it with same type and number.
Mar 11, 2012 | Panasonic Televison & Video
I turned on my tv this morning and it started smoking and of course smelling like something inside was burning. We took off the back and can see nothing that looks burnt or melted but the tv still wont...
hi,
may be ur tvs lamp side have some problem. may be the lamp over heated and burned. just open its lamp cover ann check it.
also check its power supply input point(near fuse) there is an MOV (used for voltage surge protection) is burned or not. if there is any voltage surge it will get shorted and the fuse will blow off, protect the power supply for any further damage. check the fuse also. if found open then check the MOV. insert fuse only after replacing the MOV.
ok
Dec 22, 2010 | Samsung HL-S5087W DLP TV
Vizeo 42 hd plasma tv (model v42hdtv10a)won't turn on. I checked the fuses and found one burnt out on the upper left board (when looking from the back of the tv.) I replaced this fuse (4 amp 250v...
Hi, do you know from what area the smoke came from?
4 Amps seems a little high. Sounds like power transistors have blown, maybe even a capacitop or a main filter cap has gone short.
Sorry i can't help much, is there anywhere inside that would indicate a different manufacturer?
Board numbers, chassis numbers , i will try and help.
Regards - Anthony
Feb 08, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
Power window on drivers side won't roll up. Passenger side will. Right turn light blinking very fast. Think I may blown a fuse?
This doesn't sound like a blown fuse. It sound like you have two different problems. One... your turn signal going fast is usually a sign that your light is out and needs to be replaced. Two... your automatic window sounds like it probably came off its track. Does it make kind of a grinding noise when you try to pull it up?... When you have the outside cover of the door off you can see whether or not your window support is either off it's track or is broken. Last time I checked I believe they were around $110 at Autozone for the complete assembly. It's all one unit so it is easy enough to replace if you have to. Generally, the motors on power windows won't burn up... If you do replace the window track assembly make sure to be careful about removing the pins out of the bottom of the window. The curve of the window makes it very easy to shatter with very little pressure and if you are not careful about removing those pins you will shatter the window. Hope this helps. Let me know how it goes and whether or not I can help clarify some of this for you. Goodluck.
Apr 29, 2009 | 2000 Ford Mustang
Off and on switch
Check for burnt capacitor C514 near flyback = 102K / 3KV
Sony part # 1-161-754-00 and open pico fuse in power supply.
Nov 07, 2007 | Sony KP-51WS500 51" Rear Projection...
Tv don't come on
Your main power fuse is probably burnt out. Take off the back of your tv and check for the burnt fuse or burnt connections
Nov 01, 2007 | Sony KV-32S45 32" TV
There is a blinking light in front of my tv blinks 8times turns off for 4seconds and starts again
Check C514 next to flyback xformer.If shorted,burnt,replace
with part # 1-161-754-00 102K / 3KV capacitor.May also have open
2 amp pico fuse in power supply......T
Oct 25, 2007 | Sony KP-53S70 53" Rear Projection...
Tv wont turn on
check if the main fuse blew up. good luck!
Feb 09, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Televison & Video Logo
302 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
