Question about Acer Aspire 1642WLMi Notebook
Yellow stripe down the screen.?
I have a acer aspire 1642 with a crystalBright screen.
In the left hand side of the screen a yellow stripe goes from top to the bottom of the screen. You can still see through but it distorts the colour. Its about 300mm wide.
When you squeese the plastic trim, (at the top) that surounds the screen the affected area goes sky blue. Again, you can see through it and it distorts the colour. However, when you loosen your grip it goes back to the annoying yellow.
Do you have an idea on whats wrong and how I can repair it?
  • 1 more comment
  • M Royds Dec 03, 2007
    Cheers Ron.
    Thanks for finding the time to deal with my problem. I would be gratefull for a copy of the Service Manual as I dont want to be taking of the wrong connecters.
    Once again thank you.
    M
    Thanks Ron,
    My email is [email protected]
    many thanks
  • twerk Feb 27, 2008
    sounds like i have the same problem... monitor is discoloured for a single band (3cm wide) from top to bottom of screen...
    just to the left of the camera... if i squeeze the trim lightly directly above the discoloured band it will turn back to normal...
    trying to open the trim as we speak... that chapter of disassembly would be a great help.
    email is [email protected] thanks in advance.
    Sergeant:
  • 324 Answers
And a good evening to you!
It is possible that you have a bad LCD assembly, or possibly the LCD cable connector is loose. The only way to find out is to remove the LCD assembly from the top cover so that you can access the connector. It is located behind the LCD screen.
If you want a copy of a service manual for the disassembly process, let me know and I'll see what I can do for you.
Ron-
Posted on Dec 01, 2007
  • Ron Roske Dec 03, 2007
    Such a deal I got for you!
    Wasn't able to score a complete service manual for you, but can send you a copy of Chapter 3 (Disassembly procedures). That sounds like what you need, for now.
    If you would be so kind as to provide me with your email address, I'll get it on the way.
    Ron-
    OK! It's on the way...
    If you need
    any additional information, please feel free to ask. If this information has
    assisted you in the resolution of you problem, please return here to give my
    assistance an appropriate final rating. If this information has answered your
    question and/or lead to a resolution, please rate it as "Fixya!".
    Thank you, and have a super day!
    Ron-
    New Friend:
Hi, I too have the exact same problem with an Acer Aspire 1642 ... An 8cm vertical band of distortion on the right side of the screen, which goes away when you touch/squeeze the plastic rim at the top right corner. Unfortunately it is becoming more and more persistent lately.
Could someone email me Chapter 3 at [email protected] And also could someone report back on whether they where actually able to fix this problem. Don't wanna start disassembling anything without knowing I have a fighting chance of making it work.
Cheers
Posted on Sep 10, 2010
I don't have the answer, I have the same problem. How do you comment around here? Could I also get a copy of Chapter 3? My email is [email protected]
Many thanks
Posted on Aug 04, 2010
  • cliodhna Aug 04, 2010
    Aha, here it is. I have the same problem. Could I also get a copy of Chapter 3? My email is [email protected]
    Many thanks
    Now I'm commenting on my own comment. Yikes. Have I entered the Matrix or something?
SOURCE:
Yellow Stripe Down Middle of Screen on Laptop
This system has a VGA port so you can plug in an external monitor. You can buy one for less than $130 based on the Sunday ads. Other than that, it is new laptop time.
Jul 31, 2010 | Acer Computers & Internet
For the Clarion DXZ945MP CD Player for car audio, I do not know the the wire harness color wire diagram? The wiring harness on my Monte Carlo 2000 reads what color wire goes to what, on the side of the...
3amp yellow battery for deck
15 amp yellow is another battery wire
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
red accessory
hope this helps
pls rate cause people arnt rating
Nov 05, 2009 | Clarion DXZ945MP CD Player
My acer aspire 5720-4126 won't stay powered up
That means that your power adapter is faulty and needs to be replaced.
Hope this helps.
Aug 19, 2009 | Acer Aspire 5500 5570-2609 Laptop
About 2 inch yellow stripe appears on the LCD screen
This typically is a sign of either a problem with the monitor itself, the cable, or the computer.
Fault isolation is key here. If you have access to another monitor, I would suggest connecting that to the computer, or vice versa. That way you can figure out what's broken.
If it's the computer, you might be able to purchase a replacement video card. If it's the monitor - you're out of luck, and likely need to purchase a new one.
Nov 15, 2017 | E-Machines 19" Widescreen Flat Panel TFT...
Cahrging problems on Acer Aspire 1642
u shud contact your vendor..and for more info contact http://tinyurl.com/m7ghqz
Jun 16, 2009 | Acer Aspire 1642WLMi Notebook
Acer Aspire 1640 screen problem
There could be a motherboard problem or a screen problem, but everyproblem with the screen on my acer laptop was fixed on the motherboard, so you should probably take it in a repair shop
May 15, 2017 | Acer Aspire 1640Z Notebook
I have a honda civic 1992 and i buy a sony car stero i have problem with de wiring like red goes with red black goes with black but de others color from my honda civic are difent can i have an ide
Battery
White/Yellow Stripe
or White/Blue Stripe
Accessory Yellow/Red Stripe Ground Black Illumination Red Dimmer Red/Black Stripe Power Antenna Yellow/White Stripe Left Front Speaker (+) Blue/Green Stripe Left Front Speaker (-) Gray/Black Stripe Right Front Speaker (+) Red/Green Stripe Right Front Speaker (-) Brown/Black Stripe Left Rear Speaker (+) Blue/Yellow Stripe Left Rear Speaker (-) Gray/White Stripe Right Rear Speaker (+) Red/Yellow Stripe Right Rear Speaker (-) Brown/White Stripe
Oct 19, 2008 | Pie Hon03 F/Mm Car Stereo Wiring Harness...
Yellow stripe
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
12
Aug 29, 2008 | Acer Aspire 1642WLMi Notebook
Grey cable in dash
Hi again,
Appreciate the update and additional information. If I understand it right, your vehicle then has two connectors at the back: 1 big black/red/gray plug:
  • Yellow/light Green - always ON B+12;
  • Yellow/Black stripe - ACC B+12 goes to the IGN switch;
  • Black - chassis/ground;
  • Blue - remote trigger for add-on amplifier (if connected);
  • Blue/Red stripe - illumination (can go to parklight switch).
and the 2nd smaller gray 8pin plug:
  • White/Red Stripe Right Front +
  • Brown right front -
  • Green Left Front +
  • White/Orange Stripe Left Front -
  • Light Blue/Black Stripe Left Rear +
  • Yellow Left Rear -
  • White/Blue Stripe Right Rear +
  • Light Blue Right Rear -
Cheers.
Aug 28, 2008 | 1994 Ford Explorer Limited
Distributor pinout diagram...
go to autozone.com and you will be hable to buy a progam called alldata just for your car.
May 27, 2008 | 1998 Acura CL
Acer Aspire 1642WLMi Notebook Logo
1,471 people viewed this question
Ekse
Alun Cox
