Question about Car Audio & Video
Pulsar VX50 x227 Nummer 610345 welche Batterie ?
I just got the aiwa cdc-x227 and the mute is on.how do you unmute it?
check for a logo that shows a speaker with a cross(X) across. just switch this back. this is also available on the remote. You could normally find this on the top side so as to mute easily when in a traffic junction. Check if this button is jammed. Also check if the display shows a mute , if not the sound reduction could be a different issue related to the audio output. check if any speaker connections are short, or speakers connections touching the body. Chek on the wiring once again with a multimeter , for any shorting, correct positve voltage and good ground. hope this helps. Good day
Jul 07, 2010 | Aiwa CDC-X227 CD Player
I have an UPS MGE Pulsar EX30. One batterie was with zero volts. The others are with 13 Volts. I changed the bad batterie, but when I connect the batteries, I get a spark like as in short circuit. I don't...
make sure the UPS is off when you connect the battery and make sure the polarity is correct. Look for the signs on the casing. Check the other batteries to see if they are connected in serial or parallel. Should be in series if it is a mains voltage UPS from 12v batteries so the negative of one goes to the positive of another and they daisy-chain together
Nov 05, 2017 | MGE UPS Pulsar EX15 Rack (89015R) UPS...
Baccio vx50 won't start, no sound, crank at all.
where are you located? i may be able to help with your baccio vx50
Apr 16, 2010 | Peg Perego Vespa Scooter
AiWa stuck on mute - no sound from subs.
have you tried powering down unit and seeing what happens?
Dec 02, 2009 | Aiwa CDC-X227 CD Player
Hi my zebra printer can print but when I scan it doesn't read. It only read nummer but don't read any letter. And all the barcode of mine is in letter en nummer. Can u solve this
If this is a normal LP2844 and you can't scan the barcodes it is printing, you will have a faulty printhead with a pixel or two blown.
Oct 02, 2009 | Zebra LP 2844 Thermal Printer
Welch Allyn error codes
hi
I have a error code E038 spot welch allyn
thank you
Dixon
my email dixon@coqui.net
Apr 09, 2009 | Welch Allyn Spot Vital Signs Monitor
I need a mauual for car stereo radio cdc-x227
Are you asking for Instruction Manual or Service Manual, please mention it.
Nov 28, 2008 | Aiwa CDC-X227 CD Player
Won't take cd
All U can do is cry - no warranty and not cost effective to repair the DOA. Tough break.
Aug 12, 2017 | Aiwa CDC-X227 CD Player
Car Audio & Video Logo
19 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
