Question about White Sewing Speedylock 1600 Mechanical Sewing Machine
Brand new-has not sewn first stitch
Several experienced sewers have threaded the machine following supplied instructions/video. It cuts fabric fine but does not make a stitch.
  • White Sewing Master
  • 1,388 Answers
Phone the store you bought it from and arrange to return it for instruction on use, or a refund.....if it is brand new, it is under warantee and you are entitled to a product that does what it should......if it is you who has done something wrong in the threading, a quick lesson with someone should solve the issue. Either way, call them and get it sorted out.
Posted on May 29, 2008
I have a B350, i want to sew with just straight ordinary stitch, but the top stitch is too lose, the bottom stitch looks great. IN other words, i can pull the top thread out without any problem.
You need to tighten the upper tension--higher the number, the tighter the tension. Be sure you are using the appropriate needle and thread for the fabric being sewn.
If using 100% polyester thread, be sure it is a good brand--not Coats & Clark, bargain bin threads, or old thread.
Oct 08, 2017 | Sewing Machines
I am having trouble with my Singer sewing machine 367. I can't seem to get the tension right.
You really need to get a manual. Trying to figure out the problems is difficult if you are not an experienced sewer. There is a manual on eBay right now for your machine.
A little about tension. 95% of the time it is the top thread tension. It will be the thread on the bottom of the fabric affected. If the the thread on the top is loose it is the bobbin tension. Do not adjust both at the same time. Start with the top tension making small adjustments and then doing a test on scrap fabric.
Check to see if it is threaded correctly, without a manual it may not be obvious if it is or isn't. Check that the thread is between the tension discs correctly.
Jul 11, 2017 | Singer Sewing Machines
How to sew Lycra on my necchi 522? I'm using a stretch needle. It goes up and down, fabric advances, but does not pick up bobbin thread - so no stitches!
Knit fabric sometimes plays a little havoc with machines. Be sure you are using a brand new needle. Also, ballpoint/jersey needles will usually work better with knit fabrics like t-shirt fabric. For very stretchy fabric like Lycra, you might want to try a Stretch Needle.
Schmetz Needles Needle Guide
Sewing Spandex Tips
If it still will not stitch, check your machine on regular woven fabric with a universal needle. Could be your machine is slightly out of time, especially if you have recently sewn over & hit a pin.
Oct 26, 2016 | Necchi Sewing Machines
Upper thread always cuts. Straight stitch doesn't work. The upper thread always cuts. The tension is No. 3. The stitches is adjusted to no, 2. The fabric is thin, soft and Lacey . Please advice.
Be sure to install a brand new needle of the type suitable for the fabric you are sewing.
All About Needles
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwiJuN_Np6bMAhVJKWMKHSGmDvAQFggjMAE&url=http%3A%2F%2Fwww.schmetzneedles.com%2Flearning%2Fpdf%2Fschmetz-needle-chart.pdf&usg=AFQjCNHTR52AmqwzvyCjbXmD5Ch52Va5_Q
Use a thread that is suitable for the fabric. If you are sewing fine, light-weight fabric, use a fine thread--avoid old or bargain bin thread. Use the same upper thread in the bobbin.
When threading, always raise the presser foot so the thread will seat properly in the thread tension and verify that the thread path is correct (consult the manual).
Standard tension is usually the midway point between high & low number. The stitch length could be set a little higher than a 2--maybe a 2.25 or 2.5 for light fabric.
Since you are sewing fine fabric, it sometimes helps to use a removable stabilizer to give the fabric some extra body while stitching--perhaps a wash-away stabilizer if the fabric is washable.
Test your machine on scraps of the fabric you will be sewing. Re-adjust the tension as needed. The correct tension is when both upper and bobbin threads meet in the middle of the fabric.
If the thread continues to break, then there could be a burr or nick somewhere that is catching the thread and causing it to break. Could also be a needle/hook timing issue.
Apr 24, 2016 | Sewing Machines
My Kenmore Mini Ultra sewing machine won't sew the button stitch. I have followed the instructions on the manual but still the thread does not get sewn onto the fabric. Simple straight stitches are ok
it's possible that there could be a problem with the gear or cam that does the button hole stitch
try a different needle--one for the fabric being sewed
try a different bobbin --make sure the bobbin is not warped or damaged
try different thread-- use EVERY thread guide
make sure the bobbin is wound correctly--inserted correctly in to the bobbin case--and turned the right way.
May 14, 2015 | Kenmore Sewing Machines
When I try to sew, the machine will not make a stitch. The thread balls up. Have tried everything I can think of. Yes I read the instructions but it just won't make a stitch. As well I have tried t
It sounds like you have checked most common things that would cause this problem, and I assume you have double checked to be sure the top thread is traveling through the take up lever and following the correct path. If the rotary hook is not meeting right with the needle, it can't create a stitch. If the needle isn't bent, it's possible you may need to have the machine timed or there may be some other issue occurring in the bobbin area.
Feb 09, 2015 | Sewing Machines
How do I back stitch and fix a goof?
if you aren't pleased with what you have sewn, make sure hand wheel is turn toward you. Raise presser foot. Remove fabric, and use seam ripper to remove stitches by carefully cutting into one stitch, turning fabric to underside of garment and gently pulling bobbin thread until stitches easily pull out. Re-sew what you were dissatisfied with. Jimmy
Apr 04, 2012 | Brother PE770 Computerized Sewing Machine
Machine has quit stiching on any fabric. The needle is in motion however thread is not locking. The needle and thread goes through the fabric it just will not leave a line of stich. I've tried several...
I have never known a sewer that hasn't experienced this before. First: make sure the upper thread is correctly threaded through the tension disks, take up lever, and thread guides. Sometimes, just missing one little thread guide makes everything mess up!. Next, make sure the groove on the needle is FACING YOU. The groove is actually a thread guide as well and if the needle is in backwards, it will cause stitch problems. Then, be sure the bobbin is inserted the right way. Your manual should show you how the thread should come off the bobbin (clockwise or counterclockwise). I have been sewing for over 50 years and there are days when I'm so eager to finish my "creation" I plop the bobbin in going the wrong direction and wonder what's wrong with my machine. While you're checking all this, be sure and use your machine brush to remove all lint in the bobbin case and between the feed dogs. Dust in the bed can cause stitches to mess up! I hope this helps. If it does, please come back and rate my suggestion!
Jun 07, 2011 | Singer 2638 Mechanical Sewing Machine
I have a baby lock imagine machine. I'm sewing with streatch velvet, and the stitches are off the fabric, or the loopers are too loose. I tried tighting the looper thread fine tuning screw, adjusting the...
Stretch fabric is made for using the differential feed on your machine, sergers love stretchy things. Try widening the stitch you are using and turn your differential feed down one notch to allow the machine to get a good grip on the fabric, you may need to bump the differential feed up more if it still doesn't stitch nice, keep trying on a piece of scrap fabric of the same as you are using until you are happy with the stitch.Another solution is to put some lightweight tissue paper under the seams and then tear it off after you have sewn the seams, this works but will dull your blades over time.
Oct 30, 2008 | Baby Lock Eclipse Serger
White Sewing Speedylock 1600 Mechanical Sewing Machine Logo
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
