Question about Valco Runabout Deluxe Jogger
EXTRA VALCRO wE JUST PUT TOGETHER THE VALCO RUNABOUT STROLLER AND THERE SEEMS TO BE A LOT OF EXTRA VALCRO ON THE HOOD AS WELL AS LARGE OPEN SPACES THAT SEEM SHOULD BE ABLE TO BE CLOSED IF KNEW WHERE TO ATTACH THE VALCRO- THE INSTRUCTIONS LEAVE OUT ALL OF THIS INFORMATION THANKS
If you put the seat into the recline position you should be able to see where all the valcro attaches to.
Posted on Jan 08, 2008
SOURCE:
Installing graco carseat to valco tri mode stroller
http://www.gracobaby.com/catalog/what_is_latch.aspx
Hope this helped you
Mar 02, 2008 | Valco Runabout Tri Mode Jogger
How do you fold down the valco runabout trimode stroller? I bought a used model and I can get the top half to fold over but that's it. Can it fold over more compactly? I'd like to travel with it. Thanks!
hi!!
to fold the stroller yo need to:
1.fold the hood back up against the handle.
2.release the locking clamps at either side of the stroller.
3.simultaneously lift the secondary safety catch and swing the handle forward.
4.holding the frame at the rear, press down on the rear basket tube.
5.you also can lock the frame with the strap next to the frame.
here you have the manual, could be easy with de graphics!
http://valcobaby.com/uploads/tx_productcatalog/Tri-mode_2007_Instructions.pdf
hope to being helpful!!
(if so, dont forget to rate me!)
Sep 25, 2010 | Valco Runabout TriMode Single - Stone...
How do you fold this twin stroller?
1. Loosen the plastic catches on both sides
2. Push up the red safety lever and fold the seats in half
3. Step on the top rim of the rubberized, lower compartment of the buggy to fold the frame
Jul 25, 2010 | Valco Twin Runabout ATS Jogger
Replacement parts.
Many Valco Baby models are equipped with 12 inch tires. Just like a car or bike, punctures can occur. A 12 inch inner tube or bicycle tire repair kit would be all you need to seal the puncture. If need be, tubes can be purchased from your local retailer or contact them at (USA) 800 610 7850 or email [email protected] Tubes are not covered under warranty.
Aug 29, 2009 | Valco Twin Runabout - Blue Jogger Stroller
Front wheels keep getting stuck in swivel postion
There is a company called Buggy Pit stop which valets as well as repairs pushchairs. I used them when i gave my old dusty broken pushchair to my sister. I had it repaired and valetted by them. They did a great job and they were not that expensive either.Hope this helps. Their number is 020 8861 0038.
Feb 15, 2009 | Valco Runabout Tri Mode Jogger
I need a replacement tyre for the front wheel of runabout deluxe
You can buy replacmet tire at any bike store make sure you know what size you need.
Jan 28, 2009 | Valco Runabout Deluxe Jogger
Our Valco Runabout pram (about 3 years old and a 3 wheeler)does not steer properly. The front wheel does not pivot when trying o turn
I have just removed the front wheel and liberally greased the inside top to bottom with specific aluminium lubricant (which the bike shop told me was good for bearings) and immediate improvement. fingers crossed that it lasts. looking at other posts, make sure that you put the front wheel back on securely.
Aug 18, 2008 | Valco Runabout Single DLX - Ebony Check...
Putting the stroller back together
I have the opposite problem, as i am looking to buy a bassinet to fit the pram. I actually pulled the stroller apart today to clean it all, and it is quite easy. It is literally a case of matching all of the press studs together - the lining to the frame. At the bottom, the hard plastic part velcros underneath and also clips. The steel rod from the hood then fits in to the holes provided. Dont' know if that makes sense or helps in any way. Good luck.
Jan 24, 2008 | Valco Runabout Tri Mode Jogger
Valco Runabout Deluxe Jogger Logo
142 people viewed this question
Top Valco Baby Gear Experts
Andrew Taylor
Andrew Taylor
Dorel UK
Dorel UK
Tom Chichester
Are you a Valco Baby Gear Expert? Answer questions, earn points and help others
