Question about SanDisk Sansa m250 MP3 Player
Sansa m250 not recognized by comp
I've put the songs I have on it currently through a friends computer just fine and the player works normally. But I tried to run it through my computer with ME and did the MSC option with a troubleshooter over the phone to no avial with that particular OS. So now I'm trying my other computer with XP but it is not recognized when I connect the USB to the player. I tried the firmware update from Sandisk.com but without the computer being able to talk to the player it is not able to update. Any suggestions to get back to ground zero with my player or solve my connectivity problem would be appriciated.
  • 3 more comments
  • ami1 Dec 01, 2007
    I have the same problem. One PC with XP OS find the Sansa m250 and indicate it by a device looks like it.The other PC with XP OS (New one) can't indicate that device.
  • Anonymous Mar 15, 2008
    hii my sansa m250 is not detected by my PC .When I put the cable into USB port player is showing 'USB connected'.....but my system is not detected.could anyone show me the solution.
  • Anonymous Mar 24, 2008
    I have kind of the same problem. My comp isn't recognising the player as a drive, and earlier today it was. I'm not sure what happened, it just won't recognise it. But my WMP recognises it. Only thing is, I can't get the songs to show up on my player. I can put songs on it, and take up the memory, but I can't get them to show up.
  • emu5088 Jun 21, 2008
    Thanks groman. The other USB option is MSC. (The default is MTP). Your suggestion is all fine and dandy if you put your music on the MSC mode. However, MTP mode is the default and the preferred mode to put music on.
    So for me, it wont recognize it when it's in MTP mode, but it recognizes it when it's in MSC mode, but none of my music is on that mode!
    Here's my situation.. I have 2 other PC's in my house and they all recognize it fine. My laptop used to have Vista on it, and that recognized it fine. But I reformatted and put xp on here, and it doesn't recognize it. This is frustrating. Any other suggestions?
    -emu5088
  • SLAVAY1 Jun 29, 2008
  • 3 Answers
All you have to do is go to menu, settings, theres a usb option, choose the one that isnt auto detect, and plug it in, make sure you uninstalled the brokendriver first, and it will do it for you
Posted on May 27, 2008
  • gromanknight May 27, 2008
    oh and turn off the mp3 before you plug it in
Sandisk sansa m250 mp3 player problem
try formatting it or updating the firmware
Feb 11, 2010 | SanDisk Sansa m250 MP3 Player
How to remove music from sansa m250 that is no longer on computer
ok, plug the mp3 into your computer, click on my computer, then where it says removable devices you should see your mp3 listed, double click it. browse the folders listed until you find the songs that you want to delete , when you find one you want gone RIGHT click it then click delete/ It should then remove the song from your mp3 and put it into your recycling bin.
Jun 23, 2009 | SanDisk Sansa m250 MP3 Player
Delete songs off my sansa m250 mp3 player
I just delete stuff from my WMP screen. View the list of songs you have on the device currently and then right click and 'delete from playlist'.
May 30, 2009 | SanDisk Sansa m250 MP3 Player
My playlists from sansa m250 disappeared but when i connected ..
When transfering the songs from computer to player. First, sync device before transfering. Only do this the very first time. If you try to sync with songs already on the player, they will be erased.
To test the device. Open your comuters music file folder, keep folder open, than go to start menu, go to my computer and open the folder (D: or F: folder) It will have your player listed there.
Now with both folders open, take a song from the music folder, drag it to the sansa folder and drop it in there. It should be added to player.
May 05, 2009 | SanDisk Sansa m250 MP3 Player
Cannot Copy Music
u want to convert the song into mp3format using real player.
Sep 18, 2008 | SanDisk Sansa m250 MP3 Player
Sansa m250 won't finish "finalizing update"
Ummmmm.... What are you doing exactly if your trying to download the music, Download using limewire, bearshare,
Its not going to work on Itunes most of the time so just use Limewire or bearshare. Connect the Mp3 using the Usb thing and try to put it in front of the cpu or behind either 1 of them.
After you should probably get a pop up scroll down and go to view folders or whatever and open it and put the music you want in the mp3 and when yur done beside the clock look for a Safetly USB remover or whatever and disconnect it.
I hope it works
Give me some Credit
and click the Button XD
Mar 13, 2008 | SanDisk Sansa m250 MP3 Player
The pc doesn't recognize the m250
http://www.sandisk.com/Retail/Default.aspx?CatID=1532
download the sansa connect recovery tool
download the manual and it will tell you how to reset your mp3
Feb 26, 2008 | SanDisk Sansa m250 MP3 Player
Mp3 Songs are not visible.
Go to the menu in you mp3 player. In the menu, under settings, make sure that "advanced" is set to off. Then it should show that the USB is MSC, not MTP, and you should be able to view your songs when you hook back up to the computer.
Nov 19, 2007 | SanDisk Sansa m250 MP3 Player
M250 does not recognize some songs in the playlist
Use Windows Media Player to do this, not winamp
Nov 03, 2007 | SanDisk Sansa m250 MP3 Player
Not enough space to listen
If it''s any consolation, the same thing happened to me after I loaded about 1.6 GB (~250 MB left) of music on my Sansa m250. I tried to delete the required 8MB, but the directory structure got destroyed to the point where my computer wouldn''t recognize the device. I called their technical support and they''re having me send it back to them for a replacement! It''s not you, but the player! I don''t know if there''s anything that can be done from a consumer standpoint.
Jul 09, 2007 | SanDisk Sansa m250 MP3 Player
SanDisk Sansa m250 MP3 Player Logo
429 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
