Question about Palm Treo 650 Handheld
Bluetooth Problem why doesn't my treo 650 connect to my bluetooth headset. it finds it but won't connect.
I had that problem once. I had to hard reset it and that fixed it.
Posted on Dec 02, 2007
SOURCE:
How to pair motorola H700 wireless Headset with my treo 650
Open the headset boom: it will flash steadily purple, it it's not paired ever. If it was paired turn that devices off; open the headset boom, blue will steadily lit; after 5 seconds, it will steadily purple lit. Now find Motorola H700 on bluetooth and type password: 0000. Done!
Dec 18, 2010 | Motorola Mobility H700 Wireless Headset
Unable to pair Blueaction Wireless Headset BAE-825 with iPhone, and I cannot locate a user manual, either.
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode (usually you have to hold the power button for 7-10 seconds).
Your phone will find the device, and you will be prompted to enter the devises PIN number (often 0-0-0-0). Your phone should pair with the device then.
Dec 13, 2010 | MyNetDeals BlueAction Wireless Bluetooth...
Passcode
The Motorola H700 has Bluetooth v1.2 which is backward compatible with v1.1. The headset works with both Hands-free and Headset profiles and is easy to pair with devices running various operating systems and software. We tested the headset with the Motorola SLVR, Palm Treo 650, the Nokia 9500, the Cingular 8125 and the Cingular 2125, and the headset paired with all devices with ease. To pair the Motorola, turn off the headset first then hold the Call button until the LED ring turns purple, quickly open the boom so that the LED stays solid purple, the headset is now in pairing mode. Use your mobile phone to discover and pair with the headset using “0000” as the default pass code. Call handling between the phone and the headset transferred smoothly and the headset will play notification or a ring tone when a call comes in. When working with the Treo 650, the H700 has an uncomfortably long delay in notifying an incoming call. It starts to ring after the Treo 650 has already ringed 2-3 times. The connection between the phone and the headset is solid. When we paired the Treo 650 to both the Motorola H700 and the Parrot 322 car kit, we can pick up calls on either one and the Motorola H700 worked reliably in this set up.
Hope I helped Dr Reed
Apr 06, 2010 | Motorola Mobility H700 Wireless Headset
I have a Mac laptop, a Palm Treo Wx and am now using a Motorola H700. I need to know how to sync my H700 with my Treo so I can dial via my headset and not need to use the actual cell phone. It has now...
Hi, i'm not sure what the Mac has to do with your Headset. You can register your blue tooth headset with any device that supports bluetooth. In fact, you can use your headset with multiple devices. Even your Mac can use bluetooth to connect to a headset (if you have bluetooth turned on, and not all Macs have factory bluetooth).
To 'register' your headset with the Treo is a two step process.
on the Treo, make sure bluetooth connectivity is turned on, then you should have a menu that allows you to find/enroll a new bluetooth device. Before you tell it to find a bluetooth device, turn on your headset. Now tell the Treo to search for devices. If it doesn't find your headset, then press and hold the button on the side and it will send out signals that your Treo will see. The Treo might give you a password code and ask you to confirm this is the device you want to synch to. Usually '0000', but in any case say yes, so long nobody else is around trying to do the same thing you are within 30'.
That should do it.
I don't think the Treo has voice recognition, which makes dialing on my Nokia a breeze, for true hands-free operation, nothing beats it.
Also note, the Treo has been know to have issues loosing bluetooth connectivity with the headset and not reconnecting with a re-boot.
so long you keep the two devices near each other, this shouldn't be a problem.
stephen
Jul 05, 2008 | Palm Treo 700w Smartphone
GE Bluetooth Telephone Adaptor
There is an undocumented solution to link difficult devices. Instead of pushing ad releasing, hold either button down until you get a FAST BLINK and then try linking again.
Jun 29, 2008 | GE Bluetooth In-ear Headset Wireless...
Palm Treo 650 doesn't see bluetooth headsets, AND wired headphone jack is shorted
Had a similar problems. Throw out wired headsets with shorting problems. Their too cheap to try and fix.
Try rebooting the phone, then make sure the wireless headset is on. The trick is to get it into "trusted devices", so when you get the phone to seek new or nearby devices, you need to push the button on the earpiece so it sends a signal at the time the phone is trying to find it. It took me a number of trys, but finally got it to work. I use Verizon and they were quite helpful, even though the phone was "out of warrenty". I was re-activating my phone after not using it for a couple of years.
Mar 08, 2008 | Palm Treo 650 Handheld
LG HBM-730 Won't Connect to Treo 650
Actually it's a Treo 680. Finally took the battery out of the phone. That seemed to clear everything so that I pair the bluetooth with no problem.
Feb 22, 2008 | LG HBM-730 Wireless Headset
Logitech HS04 V01 connection
Try turning off the headset. Then setting your phone to look for bluetooth device. Touch and hold for ten seconds the larger button on the headset, should flash blue light rapidly. then command phone to find device, (commands differ from one phone to another). When phone "finds" headset blue light should change to intermediate flashing (three flashes every five seconds aprox.) Hope this helps..
May 08, 2007 | Logitech (980408) Wireless Headset
Palm Treo 650 Handheld Logo
113 people viewed this question
Top Palm Computers & Internet Experts
Ekse
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
