This problem is frequently due to corroded battery terminals inside the camera. Remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
Comments:
Aug 16, 2009
- This problem is frequently due to corroded battery terminals inside the
Aug 17, 2009
- Your problem could be the result of corrosion on the battery terminals inside the camera. Remove
the batteries and clean the battery contacts inside the camera
with a soft cloth (a heavy buildup on the contacts may require cleaning
with a fine wire brush, steel wool, or sandpaper). Remove any residue
that the cleaning leaves in the camera, clean both ends of each battery, and then reinstall the
batteries. This clears most power-on problems, but if yours persists,
