Question about Canon imageCLASS MF6530 Monochrome Laser Copier/Printer
Canon imageClass MF6530
Have a problem with double sided printing... I want my documents to be printed out in both sides of one sheet of paper... and the other problem is with colour printing...
  • Canon Master
  • 1,113 Answers
This is a "monochome printer" ie B/W, double sided is called duplex select this option on printer driver on pc
Posted on Dec 01, 2007
SOURCE:
Can I print on both sides of the page
Here are the instructions for duplex printing.
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
1. Open the printer driver setup window, and check the Duplex Printing check box on the Page Setup tab.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note
sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper or Photo Paper Plus Double Sided is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
You can download a users manual for your MX310 at
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx310#BrochuresAndManuals
Please rate this solution. Thanks.
Sep 27, 2011 | Canon PIXMA MX310 All-In-One Printer
I use my MF6530 Laser Copier Printer to print checks and it will frequently print on the reverse side of the paper.
hai I give print to printer 2 side in single page, first two page print well but another two page print in opposite direction in the same paper (example1,2 page one side and 3 ,4 pages in other side but reverse direction. it mean you turn the paper to next side, you see opposite direction ) please help me to avoid this problem.
Jul 22, 2011 | Canon imageCLASS MF6530 Monochrome Laser...
Can not get printer to print information that on top to be copy on bottom of same page.
  1. Select 'Properties' from the Print dialog.
    Note: Properties may be indicated as Advanced, depending on the application software.
  2. Click the Page Setup tab.
  3. In the Printing Type section, select 'Normal-size Printing', 'Fit-to-Page Printing', 'Scaled Printing', or 'Page Layout Printing'.
  4. Select 'Duplex Printing'.
    Note: When a media type other than Plain Paper, Photo Paper Plus Double Sided, or Postcard is selected in the Media Type menu, duplex printing cannot be performed.
  5. Specify Staple Side.
    1. The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position.
    2. Click the Staple Side drop-down arrow and select the setting. If you want to change the setting, select another value from the list.
    3. If necessary, click Specify Margin... and set the Margin width
  6. When the setting is completed, click the OK button at the bottom of the window.
    Note:
    The document will be printed on one side of a sheet of paper when printing starts. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
    The document will be printed front and back alternately for one sheet at a time, when printing starts. Load the paper according to the displayed messages.
  7. You will be prompted, while printing, to remove the printed page and reload it in the ASF.
  8. Dependent on the number of pages to print, you will need to repeat step 7 until all pages have printed.
Feb 10, 2011 | Canon PIXMA MP150 All-In-One InkJet...
How to get a Canon MG5220 printer to print 2-sided copies
If you have a Canon MG5220 you certainly can print two-sided. I have one and I print two=sided pages. When you bring up your print menu underneath "Orientation" is a small window that likely says "layout". Click that window and you will have various options to choose from; color matching, paper handling, cover page, quality media color options. borderless printing and duplex printing & margin. Choose Duplex & Margin. Once you've clicked that you'll see a check box for duplex printing, click that box. You have other options for for reduced or normal printing (your choice) and then if you're stapling there's options for the side you'd prefer but the point is once you've checked off that box for duplex printing you're set to go.
Feb 05, 2011 | Canon imageCLASS MF7480 Laser Printer
Canon mf6530 crumples paper and makes grinding noise when trying to print.
I pressume that paper is wrinkled in fixing section. Probably the fixing bushings are worn out. The grinding noise could be from paper when it stuckes, but also from gears.Call service.
There is a trick if paper is moisturized. Flip paper in cass. up side down, and try again.
Jun 14, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
Paper not printing on correct side
...possible. go to the printer's website for trouble shooting answers. if nothing found on website, go to there contact page and write them, they may have quick answer for you. 2nd unplug printer and replug in-sometimes this helps.
Apr 29, 2010 | Canon imageCLASS MF6530 All-In-One...
Do pixma Mp610 support duplex printing
The MP610 does support duplex printing.
Duplex Printing
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the document may not fit on one page.
sub.gifTo print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
1. Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
5. Click OK.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagaki is selected from the Media Type list.
sub.gifAfter printing the front page, there is an ink drying wait time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex printing, check the Duplex Printing check box.
sub.gifIf the Media Type dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
Aug 17, 2009 | Canon PIXMA MP610 InkJet Printer
Canon imageCLASS MF6530; can't set up duplex (2sided) printing
hi there
there are 2 ways to copy 2 sided
one is full duplex which means your copier must have a duplex attatchment fitted on the copier lid
the other if it hasn't got a duplexer is to copy in 1 to 2 mode which means you have to turn the copy over. it sounds like your machine has not got a duplexer fitted but it can still do double sided using 1 to 2.
hope this helps
beergut707
Oct 15, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Canon Imageclass MF6530
the imageclass MF6530 cannot print in color it can only print in black and white. the only thing that this machine can do with color is to scan color documents to your computer otherwise it is a black and white copier and printer with color scan.
Jan 02, 2008 | Office Equipment & Supplies
Printing envelopes
You will probably have to change your paper settings on the printer itself to proceed without an error. In the additional settings>Paper Size> change it from Ltr to Envelope.
Sep 17, 2007 | Canon imageCLASS MF6530 Monochrome Laser...
Canon imageCLASS MF6530 Monochrome Laser Copier/Printer Logo
208 people viewed this question
Clive
Clive
old marine
old marine
Ekse
