Question about Reddy R70ET Utility Heater
Clicks but wont fire
I have a reddy heater 55 that clicks and get fuel (kerosine) but wont ignite.
I replace the spark plug already, but no luck.
the las time it fired a big puff of smoke came out and it ran fine, but the next time I tried to fire it up, just clicking. Help please!
Bob
  • 1 more comment
  • Anonymous Dec 18, 2007
    reddy 60.000 wont't fire no fuel
  • cobreather Jan 16, 2008
    Heater does not seem to click, spark not evident. fuel pressure appears ok because cone is wet. no heat, no glow, nothing. Did try to clean plug but did not change operation. worked fine last termostat cycle.
  • dogz81 Feb 01, 2008
    i have a reddy heater 55, kerosene. the plug gets spark, and has a small flame, but wont ignite heater, and then trips overload button. i cleaned all parts and put new coil,filters.
    Genius:
  • 1,665 Answers
Motor starts and runs but heater does not ignite
POSSIBLE CAUSE:
1. No fuel in tank
2. Pump pressure incorrect
3. Dirty fuel filter
4. Obstruction in nozzle
5. Water in fuel tank
REMEDY:
1. Fill tank with kerosene
2. See Pump Pressure Adjustment, page 9
3. See Fuel Filter, page 9
4. See Nozzle Assembly, pages 11 and 12
5. Drain and flush fuel tank with clean kerosene.
Posted on Mar 22, 2008
  • 625 Answers
Make sure the high voltage lead to the sparkplug isn't touching anything metal on its way to the plug. the clicking may be the high voltage discharging to a metal part, not the plug. those wires age during use.
Posted on Dec 01, 2007
Heater blows smoke out front, wont ignite...please help!
Two things cause it ,No fire at Spark plug or low air pressure
Jan 22, 2011 | Reddy Kerosene Heater with Thermostat:...
I have a 2E511C heater that wont fire up but the spark plug is firing
You probably already know this . The 2E511C was manufactured by DESA for Grainger, so you must follow these Reddy Heater troubleshooting tips.
It sounds like the heater is not getting fuel or the fuel is not hitting the spark and you must troubleshoot and find out why.
Contact me for a Dayton to DESA parts cross reference chart.
Oct 27, 2010 | Dayton E51 Oil Filled Utility Heater
When filled with kerosene then plugged in, the heater will kick on for about 3 seconds and the fan will run but it will not ignite, then it shuts off. reddy heater 55, 55000btu. runs on K1 or fuel oil.
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
HAVE REDDY 55, I GET NO FIRE TO THE SPARK PLUG,
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Nov 20, 2009 | Reddy Kerosene Heater with Thermostat:...
Heater turns off leaving lots of smoke and is hard starting
If this is a kerosene heater,the wick is most likely not adjusted up enough,or the wick is contaminated.The fuel could be contaminated also.Remove the old wick and replace it,and refuel it with clean kerosene,after you pour the old out.
Oct 14, 2009 | Heating & Cooling
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater 55 wont Fire
heatman101
Feb 03, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy heater won't stay on
What is the model number? Could be a number of things, depending on which technology is used on your particular 55,000 btu heater.
Nov 19, 2008 | Reddy Heater-30-55,000 BTU Variable
Reddy kerosine space heater
bucklehead...I assume you discarded the 2 year old fuel... if not do so. Your fuel delivery problem could be caused by a number of things. 1. Incorrect air pump pressure, 2. worn or restricted nozzle, 3. deteriorated fuel line or air line, which in turn is creating the ignition problem, 4. the spark plug is bad OR you may not have a fuel delivery problem at all - just a photocell that has gone bad or has a wasp nest built betweem the eye and the flame (check this first). If the photocell can't see the flame it will shut the heater down. That's it's only job.
More troubleshooting tips
Apr 11, 2008 | Scheu (K50-FA) Heater
Garage Heater
the kerosine heater uses a spark plug for ignition and a photocell to detect flame. at the back end of the blower motor is an air compressor. it is a vane and diaphragm compressor that supposed to put out 3.6 psi of air to the fuel nozzle. the fuel nozzle is a venturi type that creates a vacuum across the orifice to suck fuel from the tank. try this site for spare parts www dot desatech dot com. its the same place I get parts for repairing heaters.
Nov 29, 2007 | All-Pro Kerosene Garage Shop Heaters - All...
Reddy R70ET Utility Heater Logo
351 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
