Question about HP LaserJet 4100n Printer
Printer is putting a crease in the middle of the paper
My laserjet printer is creasing the center of the paper and leaving smudges when it does this
  • HP Master
  • 1,113 Answers
You need to have the fuser replaced, it comes out easy on these back cover just pulls off, and there is two tabs or long silver screws to undo fuser, remove it anf you will see that upper roller is worn, buy a maintence kit for this model which includes fuser and fit it yourself easy done instructions are included with kit.
Posted on Dec 01, 2007
Hp laser jet P2035N has a crease down the center of the page as the paper exits it is actually slightly raised so the print is smearing
Check to make certain that the fuser unit is not damaged. Often a crease or dimple is caused by foreign material on the fuser roller or the fuser is damaged. If the fuser is damaged, look into replacing the device, it may be cheaper than repairing the fuser.
Jan 31, 2013 | HEWLETT PACKARD - LASER JETS New - Hp...
The printer creases the paper top left hand corner
hi just check the inside one paper gear will be if it is creases measn that is problem
Dec 16, 2010 | HP LaserJet 1300n Printer
Paper comes out creased on one side
If the printed image is smudged, as well as creased, you might have a torn Fuser fixing film.
You will need a technician to fix that.
If it is just a crease, just check that
1. Your paper is not damp. Try a fresh packet of paper
2. The paper input tray guides are set to the width of the apaer, to prevent the paper skewing as it feeds.
Good luck.
Jun 21, 2010 | HP LaserJet 1012 Printer
Hp 3030 laserjet paper creasing when printing
if the print is also smudged the fuser needs replacing
Jan 12, 2010 | HP LaserJet 3030 All-In-One Printer
Paper is crumpled, toner is not adhering in certain areas
The fuser is shot....this is the unit that uses heat and pressure to fuse the toner to the page. It is primarily when the pressure roller wears that you get crinkling and bad fusing, but I'm sure the upper sleeve has seen better days as well.
These days it is (sadly) cheaper to replace this printer with a new little HP -only around $100 or so.
*please rate me :)
Mar 17, 2009 | HP LaserJet 1300 Printer
Printer is creating a crease and smudge down center of page.
There sounds like there is somthing in the path of the printhead. Using a flash light, remove back cover of machine and look for a small piece of paper,etc. Be careful not to jam anything in to th machine. It may take running a thick piece of paper through manually with your hands to remove the object.
Feb 12, 2009 | HP LaserJet 1012 Printer
Appears to be a roller crease on the paper
i want the installation cd fo my printer HP PSC 1410
Jan 01, 2008 | HP PSC 1410 All-In-One InkJet Printer
HP LaserJet 4100n Printer Logo
367 people viewed this question
Ben Johnson
